Question about Kenmore Dryers
Dryer won't keep running after start button is released
When we press the start button on our Kenmore dryer, it starts, but as soon as I let go of the start button, it immediately stops. It did this several times last week, now it does it everytime
  • rpearce Dec 01, 2008
    I haven't been able to identify the where the spring loaded switch is. Do I need to take the back off the dryer to follow the wires, or do I need to take the drum out? The back is spot welded on, so I did not take it off. I took the top and front off, but I don't think I got to the correct spot.
    Thanks for your help.
    Genius:
  • 1,198 Answers
On the motor is a spring loaded switch. When the motor spins fast enough, it moves and keeps the motor going. It could be stuck with lint. The spring loaded part moves parts inside where all the wires go. Look carefully, the wire locations should be marked. Don't open that part unless you're really good at putting little things back together. That part should be replaceable if it's gone bad. A little wd-40 can do a lot of wonders.
Posted on Nov 25, 2008
  • mike kirschbaum
    mike kirschbaum Dec 05, 2008
    Yeah, you'll have to remove the drum to find the motor. Carefully release the belt, there should be an access door for that. Study how it goes, make a sketch if one is not on the back of the machine. The switch is part of the motor. Right behind where the wires go to the motor is this plastic part that moves up and down the motor shaft when the motor spins. You should be able to move it back and forth. Make sure all the wires are connected. The sliding switch pushes a small button on the back of the place where the wires go. If that area is full of lint, it could keep the switch from working.
    You might be able to take the whole motor to a repair shop to be fixed. They might be in the yellow pages as motor rewinders. That way they could check out the whole motor.
  • mike kirschbaum
    mike kirschbaum Apr 21, 2009
    The motor is under and behind the drum, which must come out. Photo or note how the belt goes, it's a bear to put back on.
My kenmore gas dryer (#73952) will start when the button is pressed, but as soon as it is released it stops. Can you help?
check the door safety switch, you can bypass it by jumping the 2 wires together, if it runs then just replace the door switch
Aug 23, 2011 | Kenmore 73952 Gas Dryer
I have a Kenmore Dryer Model 11063942101. When I press the start button the dryer starts but stops as soon as I release the start button.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 10, 2011 | Kenmore 63942 Dryer
I have a Kenmore Dryer Model #110.73942101. Lately it has been taking longer to dry than normal. Just yesterday, when we pressed the button to start the dryer, it starts, but as soon as you release the...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Jan 05, 2011 | Kenmore Dryers
Press start button and dryshuts off when start button is released
There is a switch assembly on the motor that activates when the motor is running. Centrifugal switch. It keeps it running when you release the switch. That is where to start. Eric
Jun 11, 2009 | Kenmore 74992 Gas Dryer
Kenmore dryer won't heat and must hold button down
Switch on fan motor not working sw must prove that fan is running! bad motor sw or loose wireing motor sw will by pass start button is released if working!
Jan 04, 2009 | Kenmore Dryers
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryer starts when start button is pressed and held but will not stay running when button is released
there is a holding contact at the motor wiring, check the schematics and trace that holding contact. it should hold the motor running as soon as it starts.
tnx 4 using fixya,
drcool
Sep 14, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 73954 : Only runs when the START button is continuously pressed
The start button starts the motor heater and energizes a relay that latches closed to keep the motor and heater running untill the timer switch or door switch cut the power to the relay and the relay opens.
The latching relay has failed or disconnected
if all the cables are attached to the relay
replace relay
not an expensive item, usualoly good for 10years
dryer circuits look like this, the start switch and relay are drawn just to the right of the motor, this diagram has no relevance to the physical position of the parts
Aug 22, 2008 | Kenmore 63942 Dryer
Dryers Logo
87 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
