Question about GE GTS12BBPLCC Top Freezer Refrigerator
GE refridgerator Water is dripping down the inside of the refridgerator and pooling on the bottom. Need towel to soak it up. raised the inside temp to 9... worked for a few days; now, I have frozen water on the bottom of the crisper area. HELP!
  • 3 more comments
  • redjem Aug 14, 2008
    I have the same problem my model # is TBC18GPB. Its a GE. Someone told me to take the tube off the back of the fridge and blow it out. I don't know how to do this can someone help a little lady figure it out.
    I have water underneath my crisper and I have to soak it up with a towel. I'm kind of getting tired of it.
  • Anonymous Mar 13, 2014
    water drips
  • Anonymous Mar 17, 2014
    Behind the bottom crisper there is a water pack. It seems to be dripping what is that part no.
  • Anonymous Mar 20, 2014
    I have water in the bottom of my refridgerator which keeps pooling.
  • Anonymous Mar 22, 2014
    You said there was a condenser linr pluged. How do I get to it? From the inside of the refridgerator or the freezer?
  • 237 Answers
If the unit has an ice maker or water dispensor, etc. there's always a chance a connection is loose or a valve is leaking by. If no other water is hooked up to the refer, then the defrost cycle water that should drain down to the bottom underneath pan is what is likely. You may have to take the inside rear panels off to see if the drain line is plugged up, that would allow water from the defrosting of the coils to drip inside the fridge vice outside like it should.
Posted on Jan 02, 2007
    Problem Solver:
  • 3 Answers
I have the same problem. The above answer is right, I think. A friend told me to defrost the entire freezer/fridge once a year to keep the ice from clogging the drain line.
Posted on Nov 18, 2007
Water keeps drain into the refridgerator but it still freezes and still keeps food cold in the ice box I just replaced the filter about a month ago.I also have been keeping a towel in there to soak up the...
Take out the back panel inside your freezer and locate the drip line in there, it should be some where under the coils, check if its blocked up with ice, if it is you need to unclog it. there should also be a wire that runs into that drip line (it helps defrost that line) you might need to replace that wire.
Feb 20, 2013 | Kenmore 64802 Top Freezer Refrigerator
My fridge is leaking, I don't know from where. I have a towel across the bottom on the inside so it won't leak on the floor. Is there any way I can correct this. There was no change in the temps.
Probably the defrost overflow tube is blocked. That water dripping out of the fridge should be siphoned by the tube to the rear outside of the fridge where the heat from the motor will evaporate the water from the defrost cycle. You need to remove the cover from the inside rear of the freezer andcheck that water can flow down the tube without spilling over the edges of the collection trough.
Nov 08, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
Ice on bottom of freezer and small leak on right coner
There have to be a hole to drain the water down .You might need to take the cover off tof get to drain
May 17, 2017 | GE Profile PDS22SCRL Stainless Steel...
Model TBX21KLK water pooling UNDER vegetable bins
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 21, 2009 | Refrigerators
Water is pooling in the bottom of my roper refridgerator.
check door gasket all the way around , check water line inside frige behind crisper drawers
Jun 25, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Water build up back of freezer inside drips to bottom and leaks from under door.Looks like their is some sort of tray with hole in back then it overflows drips to bottom of freezer some of water freezes...
Our GE Profile leaked from the freezer door and this is what I was told by a service man to try before he came and it worked. There should be a "well" on the bottom of your freezer floor where the water runs when it defrosts. Yours is probably now covered with a sheet of ice. You can melt the ice with a hairdryer using dry towels to soak up the water as you work or really hot wet rags and ring them out in the sink. After all the ice is removed pour a small amount of warm water into the "well" and stick your finger in there and "plunge" it - like you would a clogged toilet - with your finger. This will purge the ice that blocked the drain. Check on this every couple of months to make sure you don't end up with the same problem in a year or so.
Jun 12, 2009 | GE GSS25JFM Side by Side Refrigerator
GE regrigerator not cooling or freezing
first defrost it by turning it off for 1\2 to 1 full day,put towels on the floor to catch the water,when a refridgerator gets frosted up it cant circulate the cold air,and if its one with the freezer on top then the cold air cant blow down into the refridgerator,check inside the refridgerator at the top where the thermostat cover is there will be a vent hole,it could have ice built up so much that its totally blocking the air flow.This usually happens when hot food is put in the refridgerator and causes steam,or the refridgerator runs too much caused by bad door seals,or the cooling fins on the back or bottom underneath plugged with dust and the freon gets too hot causing condensation inside the freezer which causes it to frost up,a plugged drain hole will back up water and freeze,the fan in the freezer may have stopped working,which is about a $60.00 part,and finally a bad defrost element (about a $40.00 part)which is a glass tube inside the freezer with a coiled up wire inside it that heats up at certain times to defrost any ice build up,(which is the last thing to check)
May 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice and water on the bottom shelf
the blower motor of your fridge which is located at the back panel of your fridge is not running
Mar 06, 2009 | Refrigerators
Ice maker not making ice. Water disp inside frig disp water.
the line that gives water to the ice maker, every time the water comes down it lives a drip of water that turns to ice blocking the line, get some hot water and a towel and place the hot wet towel on top of the line intel it melts the ice in side the line. it happens to my frige at list once a year. if that is not the problem the valve that supplies water tho the ice maker needs replacing, it's behind the frige at the bottom, where the line coming from the house meets the frige.
Dec 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE GTS12BBPLCC Top Freezer Refrigerator Logo
318 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
