Question about Dewalt Saws
Height and angle adjusters are not locking tightly.
What is the deal with the locking knobs for the adjustment wheels? it seems to have only a fractin of throw which is not allowing it to lock the wheel. I have checked to see if it was assembled properly and it appears fine. the bushing spring washer and washer are behind the pin in that order.
  • 22 Answers
Some saws have an adjustment screw to tighten locks
Posted on Dec 13, 2008
How to repair the front left wheel and height adjustment assembly on a Kirby G10 vacuum cleaner
The wheels are held on by a screw behind the wheel guard, i suspect your height adjuster has come loose off the spline, this can be simply tapped back onto the axle
Jul 21, 2017 | Kirby G10 Sentria Vacuum Cleaner...
How do I adjust the height of the drafting table?
You should loosen the knobs, adjust the height and then tighten the knobs once you are happy with the height. Screw it tightly and lock them in place.
Jan 07, 2013 | Furniture
Front wheels on manual mower lock when pushing for awhile.
1 Locate the height adjustment lever on the inside of the left rear wheel.
2 Kneel next to the mower and push the left height adjustment lever toward the center of the mower. This will unlock the lever from the locking pin on which the height is currently set.
Read more: How do I Adjust the Height on a Great States Reel Mower? ' eHow.com http://www.ehow.com/how_6834215_do-great-states-reel-mower_.html#ixzz21NOr1e8d
3Rotate the lever toward the front of the mower to lower the height of cut, or toward the rear of the mower to raise the height of cut.
4 Release the lever over the locking pin closest to the desired height of cut.
5 Repeat these steps with the adjustment lever on the right-side rear wheel. Be sure to set the right wheel lever to the same position as the left-side wheel's lever for an even cut.
Jul 22, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Poulan pro front wheel drive 22 inch mower. With height adjuster set to highest level, right front wheel keeps slipping out of the adjuster notch. Is there an adjustment screw somewhere?
Is the height adjuster tight on both sides? if loose the bolt holes may be elongated, both sides set the same? any wheel wobble indicating worn out wheels?.if it checks out as good put the machine an a known hard level surface such as a garage floor and check the clearance by turning the wheels by hand without putting pressure on them, If the wheel still slips the mowing deck may be warped or bent. if all wheels are original there shouldn`t be a question of mismatched wheels ie:different sizes.
Jul 03, 2011 | Poulan Pro " Pro" Self Propelled Mower
I want to know how to fix the alignment on my 1995 honda accord ex.
Before making wheel alignment adjustment, perform the following checks:
  1. Tires should be equal in size and runout must not be excessive. Tires and wheels should be in balance, and inflated to manufacturer's specifications.
  2. Wheel bearings must be properly adjusted. Steering linkage and suspension must not have excessive looseness. Check for wear in tie rod ends and ball joints.
  3. Steering gear box must not have excessive play. Check and adjust to manufacturer's specifications.
  4. Vehicle must be at curb height with full fuel load and spare tire in vehicle. No extra load should be on vehicle.
  5. Vehicle must be level with floor and with suspension settled. Jounce front and rear of vehicle several times and allow it to settle to normal curb height.
  6. If steering wheel is not centered with front wheels in straight-ahead position, correct by shortening one tie rod adjusting sleeve and lengthening opposite sleeve equal amounts.
  7. Ensure wheel lug nuts are tightened to torque specifications
Ride Height Adjustment
Before adjusting alignment, check riding height. Riding height must be checked with vehicle on level floor and tires properly inflated. Passenger and luggage compartments must be unloaded. Bounce vehicle several times, and allow suspension to settle. Visually inspect vehicle from front to rear and from side to side for signs of abnormal height.
Measure riding height. See figure. Riding height between left and right sides of vehicle should vary less than 1′ (25.4 mm). If riding height is not within specification, check suspension components and repair or replace them as necessary.
Wheel Alignment Procedures
Honda recommends using commercially available computerized 4-wheel alignment equipment. Follow equipment manufacturer instructions to obtain vehicle alignment settings. Use following procedures for necessary adjustments.
Civic Camber Adjustment
Compare camber settings with vehicle manufacturer recommendations. If camber is incorrect, check for bent or damaged front suspension components. Replace faulty components. Recheck camber.
Civic Caster Adjustment
DO NOT use more than 2 shims. If more than 2 shims are required to adjust caster angle, check for bent or damaged suspension components.
Compare caster settings with vehicle manufacturer recommendations. If caster is incorrect, check for bent or damaged front suspension components. Replace faulty components. Recheck caster.
Civic Toe-In Adjustment
  1. Secure steering wheel in straight-ahead position. Measure front wheel toe-in. If adjustment is needed, loosen tie rod lock nuts. Turn both tie rods equally in the same direction until front wheels are in straight-ahead position and toe-in reading is correct. Tighten tie rod lock nuts. Reposition tie rod boots if twisted.
  2. Ensure parking brake is released. Check rear wheel toe-in. If adjustment is needed, hold adjusting bolt on rear compensator arm and loosen lock nut. See figure. Adjust rear toe-in by sliding rear control arm until rear toe-in is correct. Install NEW lock nut, and tighten it while holding adjusting bolt.
Wheel Alignment Specifications
  • Camber - Measurement in degrees.
    • Front: 0 (range -1 to 1)
    • Rear: 0.33 (range -1.33 to 0.67)
  • Caster - Measurement in degrees.
    • 1.17 (range 0.17 to 2.17)
  • Toe-In - Measurement in inches (mm).
    • Front: -0 (0)
    • Rear: 0.08 (2.0)
  • Toe-In - Measurement in degrees.
    • Front: 0.00 (range - 0.16 to 0.16)
  • Toe-Out On Turns - Measurement in degrees.
    • Inner: 41.00
    • Outer: 33.50
Torque Specifications Ft. Lbs (N.m)
  • Rear Control Arm Adjusting Bolt: 48 (65)
  • Spindle Nut: 136 (185)
  • Tie Rod Lock Nut: 41 (55)
  • Wheel Lug Nuts: 80 (108)
hope this helps you out.
May 09, 2011 | 1995 Honda Accord
How to adjust height on tractor mower model no. 917.270812? I turn the adjustment knob and it will lock in only on the highest and lowest heights and nowhere in between.
You need to turn that knob to its highest point with the deck height lever to its highest setting. Now turn that knob counter clockwise a few turns and let the deck lever all the way down. That knob will stop the lever part way down. If it mowes to high rase that deck lever again and turn that knob counter clockwise some more and let that deck lever down again. Repete till you have the correct cutting height. If you were cutting to low turn the knob clockwise insted of counter clockwise in the instruction above. The knob only set the stop of the deck lever. Once set the deck lever lifts the deck up and holds it but when you let that lever down it returns to its mowing set height.
Aug 12, 2009 | Craftsman Garden
I have a Yamaha DT125R 2003 and am looking to increase the ride height. On either side of the back wheel there is a cog with numbers on, I presume if I loosen the bolt and adjust this it will change the...
the cog as you discribe it is the chain tensioner for the back wheel. look at the rear shocker and you will see 2 castlated locking nuts this is how you adjust the rear suspension,by undoing 1 of them you adjust the other then tighten the other onto it making sure they are both tight together
May 15, 2009 | 2003 Yamaha DT 125 R
Bought model 3400 skil table saw. have no manual. can't find control for tilting blade. how do i tilt blade
This model does not have a knob on the side.
There is only a locking lever on the front next to a single rotating wheel for height adjustments. To tilt the blade simply twist the locking lever to the left and push the height adjustment wheel to the right. It can be a bit stiff at times to move.
Feb 26, 2009 | Skil 10" Table Saw 3400
Picture is too wide, how can I adjust the width?
Can't you set/adjust that on menu settings? If not, and no adjustable knob inside for width adjustment. You are now dealing its adjustment with MCU, or its eeprom ic. Check its required power supply it should be within spec. Better to have an schematic if you deals within its electronics parts.
Nov 15, 2008 | Sanyo DS27910 27" TV
Carpet Height Adjusment
In addition to the tab that contacts the bottom of the slider, there are 2 protusions on the adjustable wheel plate that move through holes in the housing, but only when the handle is tilted to begin vacuuming. The wheel plate has a spring that forces the tab against the slider. As the handle is moved to the upright position, the protusions move back through the holes, taking the tab away from the slider and the wheel plate locks in its highest position. Therefore, the position of the slider has no effect while the handle is upright and locked. Hope this helps.
Aug 19, 2007 | Hoover U5753-900 WindTunnel Bagless...
Saws Logo
115 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
