Question about HP Compaq Presario V2000 Notebook
Compaq Presario V2000 keeps freezing up
My Compaq Presario V2403NR keeps freezing up, usually within 30 minutes to an hour after starting up. Once it freezes up, you have to turn it off using the power button and if you start it back up again immediately, it starts freezing up more quickly, i.e. every 10 minutes or so. If you can let it cool completely down and start it up again, you can get about 30 minutes to an hour of usage out of it but then it will begin the freezing up cycle again. The problem started about 6 months ago and I have tried everything to fix it including replacing the hard drive, reloading the operating system, putting in new RAM and increasing the RAM from the pathetic 256MB that came with it to 1.5GB. The cooling fan operates fine so I don't think that is the problem and the computer has been babied since it was new, which is just over a year old. I have run out of options with the Compaq tech support folks and they now believe it is a hardware issue, i.e. motherboard, etc. Any suggestions are much appreciated.
  • William Horton Jan 02, 2007
    Actually, I had read a couple of months ago about the graphics problem and downloaded the most up to date drivers but to no avail. In terms of the fan and heat issues, I am always mindful to keep it well ventilated and even purchased one of those fan bases that has 3 built in fans to get the laptop better ventilation but that hasn't helped either.
    President:
  • 2,961 Answers
It could be something as simple as a corrupt graphics driver. If you have currently run a Windows update for hardware, there is a chance that a generic Windows driver has been installed and is not working correctly. Go to your task bar, as there is normally a graphics programme running enabling you to set the external monitor etc. If it's there and you have lost all the usual tabs for changing different properties, then the driver will need to be downloaded from your notebook manufacturer. If all in that looks ok then click Start>Run then type 'dxdiag' and hit enter and let windows do a diagnostic test on sound and video. If it's an intermitent problem, this is normally down to overheating, so check the vents around your fan and gently give them a hoover out. Failing all; keep an eye on your processor temperature, you can download allsorts of different free programmes that will run in your taskbar.
Posted on Jan 02, 2007
Replacing hard drive, just want to know if a WD400...
If you want to replace your hard drive, use WD3200BEVE. Its a 320GIG hard drive and it works perfectly. I installed one in my compaq presario v2403nr.
May 20, 2010 | HP Compaq Presario V2000 Notebook
Compaq presario v2000 freezing after start up. making it impossible to navigate pages to solve
click on start and then click on run.
type in MS config and then click ok.
uncheck the option which says load startup items.
Click on ok to restart the computer.
This should stop the computer from freezing once it turns on.
Apr 16, 2010 | HP Compaq Presario V2000 Notebook
Compaq V2000 "Press <F1> to resume, <F10> to Setup
re install the operating system.insert the recovery disk and follow the instructions.
Feb 20, 2010 | HP Compaq Presario V2000 Notebook
My Compaq V2000 beeps twice & freezes
It sounds like the RAM is either not compatable or is bad. Put the old RAM back in and try again. Also the V2000 and HP DV2000 is in recall for mother board problems.
Nov 12, 2009 | HP Compaq Presario V2000 Notebook
Help me please>>>My Notebook Compaq Presario v2000 haven't sound.
To install device you need to install device driver within cd support included of the pack, or goto www.hp.com then click the support for download driver for your device.
hope this help..
Nov 07, 2008 | HP Compaq Presario V2000 Notebook
Blank screen
Hi
Its inverter or mother board problem power which passes to backlight is cutting off because of over heart (over heart of some IC).
Thanks
Sep 16, 2008 | HP Compaq Presario V2000 Notebook
Presario V2000 - Does not turn on..
Hi
Have you tested your Power Adopter, it is working if yes check the battery, This may be the problem
Boopathy
Aug 10, 2008 | HP Compaq Presario V2000 Notebook
Compaq v2000
http://altex.com/indexflash.php
Comp U.S.A.
Circuit City
http://www.frys.com
these are pretty good dealers, and the price is usually between 15-30 dollars
Jan 09, 2008 | HP Compaq Presario V2000 Notebook
White screen
Use an external monitor all should be ok the LCD screen is faulty you can enquire about it here:
http://lcdrepair.net
Oct 17, 2007 | HP Compaq Presario V2000 Notebook
Black Screening
It could be under warranty have the motherboard checked and or the processor. Something is wrong it shouldnt freeze up like that.
Sep 29, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
294 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
