Washing Machines Logo
Anonymous Posted on Jul 24, 2017
Bosch WFK 2401 Full of Cold Water!
We have an 8-year old Bosch WFK 2401 washer that has worked flawlessly.
We did laundry thsi past Sunday and all was well. Today, Friday, we went to do a load and when we opened the washer door, water started gushing out. The washer was probably half full of water.
We don't have any error messages.
Any ideas any one?
paul
Level 3:
  • Master 825 Answers
  • Posted on Jul 24, 2017
paul
Master
Level 3:
Answers
825
Questions
0
Helped
174149
Points
2202
Put machine near an outside door let the empty hose lie outside that will drain the water out........then check the pump for a blockage ........
cheers
5 Related Answers
douglas smith
  • 1462 Answers
  • Posted on Jun 14, 2007
SOURCE: Bosch Washer WFK 2401
leaks could be from anywhere. remove the top and back cover, put on a cycle and try to trace where leak is. sorry if this is not very helpful. water in filter should not smell. this may be due to using liquid detergent which causes a smell like drains if used over a period. put on a boil wash and revert to using powder
Anonymous
  • 66 Answers
  • Posted on Jun 22, 2008
SOURCE: Bosch WFK 2401 problem, please help
this could be a block in the pump or motor brushes would go for the pump
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Jan 03, 2009
SOURCE: Bosch WFK 2401 Washing Machine On/Off Switch Replacement
TRy www.espares.co.uk/bosch
or www.bosch-spareparts.co.uk
If it runs o/k with the switch held in .\then all youneed is a new switch.
Plz rate my advice.
Thanks.
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Jan 15, 2009
SOURCE: installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
michael_t919
  • 88 Answers
  • Posted on Apr 20, 2010
SOURCE: Bosch WFK 2401 - Washer fails to spin.
Check the carbon brushes on the motor.
I have a Bosch washer model WFK 2401 and I need a new pressure switch. The repair company I'm dealing with says that they can't get the part from Bosch any longer. Do you have any suggestions for...
We own a Bosch- probably nearly 20 years old. I manged to get the parts I needed- but we live in France and I buy on-line from the UK!
I would go onto the Bosch site. You will probably find spares suppliers from which to inquire. Also I'm sure you could query the Bosch site directly.
I'm not criticizing your repair company but I will be very surprised if the part was not available from somewhere.
Good luck,
John C
Our 9 year old WFK 2401 needs >$900 repair (drum bearing bad=needs both inner and outer drum; pump motor squeals.) But dealer says we must replace BOTH washer and WTA 3500 drier (which if fine) because...
yes he is right!!! ask yourself this,,,,after 9 years have you had your money worth out the dryer yet? and the washer???
go on treet yourself,,,buy a new lot,,,you know you wont to?
and what a slap in the face for all your friends,,,"look what i got!"
rasssssp!
1helpful
Our Bosch WFK 2401 keeps filling with hot water - even when a cold cycle is selected.
The problem is the water inlet valve has failed. Although it is only the cold water the whole valve needs to be replaced. There are 2 solenoids on the valve 1 for cold 1 for hot the cold water solenoid has failed. The reason it works in the softner is it uses a separate solenoid to let water in there.
Check the below link , it might be useful;
http://appliancehelponline.com/washerwaterinlet.html
3helpful
2helpful
We have a Bosch WFK 2401 that is approximately 8 years old. I am not sure what cycle it was on when all of a sudden a loud noise started coming from the washer. Sounded like a gear stripping. A loud...
Check to see if inner drum is loose indicating bearing problem..Also check two springs on top of tub evident with lid off they can snap/ good luck
9helpful
Installing carbon brushes on Bosch WFK 2401
Remove drive belt.
Remove motor plug
Thanks.
Bosch WFK 2401 hot water wont shut off even if you turn power off
I can help , If the unit is leeting water in with the power off the only thing it can be is the water inlet valve , it is the componet you connect your water line to under the unit behind the front lower panel. Tell me if you have any other questions and let me know how this works out.
Phil
WFK 2401
Replace hot water valve.
2answers
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
