Question about Compaq Computers & Internet
Laptop won't stay on
My compaq computer is a kind of old. We have been having problems with the battery staying on while plugged into the wall outlet, but we managed to put pressure on the wire in the back and it would stay on. Now it turns on,starts the screen for the windows xp program and after a while shows a blue screen for a very short time, to fast to read what it says, then shuts down, then restarts itself again and the whole process repeats. Help!
  • 1 more comment
  • wproverbs31 Nov 25, 2008
    I tried but when I click safe mode it goes to this crazy list
    the list says
    multi(0)disk(0)rdisk(0)partition(1)\WINDOWS\system32\drivers
    and then after each line there is something differerent typed then it shuts off and won't let me do anything else, reboots itself and starts over again
    yes we have the disk now what
    we have family photos and things we really don't want to lose on there is there anything we can do to keep them and fix the problem still?
    Genius:
  • 1,913 Answers
Ok put cd in rom then power up the computer thenpress del or F2 for enter in bios.then set first boot device as your rom.
then go to recoverty console pls wait for 5 minutes .
Posted on Nov 26, 2008
  • Compaq Master
  • 4,806 Answers
The blue screen you are seeing is called "the blue screen of death" this could be software, hardware or a bad driver, boot into safe mode, right click on "my computer" select "manage" and then "event viewer" and lastly "system" there it will give you an error code about the blue screen, write this eroor code down and get back to us
regards
Posted on Nov 25, 2008
  • 1 more comment
  • Lee Hodgson
    Lee Hodgson Nov 25, 2008
    the system 32 folder in the windows directory is corrupt and you need to recover the system, did you get a recovery disk with the machine?
  • Lee Hodgson
    ok you have to go into the bios F2 on boot and change the boot order to the DVD/CD drive and save the settings by pressing F10 click Yes and reboot, make sure the disk in the drive first, if you get a prompt to press any key to boot from cd, do it and you will be able to recover the system.
    i must warn you that all of your data will be wiped
    regards
  • Lee Hodgson
    take the hard drive out of the machine and plug it to another computer as a "slave" device then you have to look through the documents and settings folders and retrieve all your fhoto's, doc's, movies and music.
    Once you have recovered your data put the drive back into the machine and proceed with the system recovery
    regards
    Genius:
  • 1,913 Answers
Your hard disk has bed sectors or your rma has problem
press F8 key when u power up.then go to safe mode then type in run in start menu "chkdsk /r"
then press "y"
then restart the computer.
then it recoves then auto resrt .
then check best of luck.
HP Compaq NC8430: Laptop does not want to charge battery
Take the battery out, plug in the charger and see if the laptop works. If it works, the battery may be the problem. Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop. Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity. If that light isn't on, try a different outlet. Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it. If it still does not light up, your adapter could need replacing. Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery. Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection. Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
Jan 30, 2013 | HP Compaq nc8430 Notebook
My laptop wont run when plugged into outlet
Replace the motherboard. I have seen them online for sale at $30 to $40 bucks.
http://www.getpartsonline.com/462439-001.html
[FIND the part number on the old motherboard. Make SURE you get the correct part number ]
Here's the link to a free Service Manual from HP,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=3540082&
Scroll down, click on -
HP G7000 Notebook PC and Compaq Presario C700 Notebook PC -
Maintenance and Service Guide
It's a PDF file. May take up to 30 seconds before the first page comes up.
Need guidance? Post back in a Comment.
Regards,
joecoolvette
Jul 20, 2012 | Compaq Presario C700 Series Laptop...
It keeps turning off, I have tried my friends power cord incase that was the problem but even with her cord it turns off, and just before that says that I need to plug the charger in even though it is...
ok sounds like your battery has gone bad.
try this test: remove battery plug computer into the wall.
boot computer if it boots up and stays on you will need a new battery.
Nov 13, 2009 | Compaq Presario R3000 Notebook
When the lap top logs off front light stays on
Do you still have the power cord plugged in? There are indicator light s for Battery operation, power on, hard drive activity. If you just logged off but the laptop is stillpowered on, then there will be a light indicating that. If you powered off the laptop but left it plugged into a wall outlet, then there is a chrging indicator that will stay lit.
Sep 11, 2009 | Dell Inspiron 6000 Notebook
Want stay charged
Sounds like a bad battery cause its not keeping a charge. Try a new or known good battery and see if it will charge and then unplug the ac adaptor to see if the laptop stays on.
If the laptop stays on with a different battery charged then your old battery is bad. If your laptop doesn't stay on with a known good or new charged battery without the ac adaptor hooked up then its a bad motherboard.
Feb 14, 2009 | Toshiba Satellite A100-S8111TD Notebook
Computer shut down
The sparking has probably caused your circuit protection inside the AC adapter to turn off the current.
Also, when you are plugging an adapter in,,do not have it plugged into the wall power outlet when plugging into the laptop,,,plug into the laptop first and then plug into the wall.
Jan 29, 2009 | Compaq Presario Notebook
My compaq presario R4000 just stopped working and shut down - no warning - nothing!
bad battery. best way to kill a battery is to always have it charging and never using it or discharging it.
take the battery out and use it just with power cord, see if it shuts down again. or try to use it with JUST the battery if battery is bad the PC will not turn on or stay on
Jan 04, 2008 | HP Compaq Presario R4000 Notebook
Wont stay on
I suggest removing the battery when plugging it to the wall outlet or are you trying to charge it? I think the one that is spinning is the hard drive reseat it then lets see what happens try to purchase a new hard drive if problem persists. please indicate also the status of the lights on your laptop ill reply with more steps when you've indicated everything
Mar 22, 2007 | Dell Inspiron 1100 Notebook
Computers & Internet Logo
134 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
