Question about Nikon Cameras
NikonD70s, Flash pops up but will not fire. - Nikon Cameras
  • 13,433 Answers
You may have a faulty lens, try another set of battery, change flash settings, reset the nikon to default settings.
if noting help, hows your nikon warranty? if its out you can get a free repair estimate from  www.advancecamera.com/repair
Posted on Nov 25, 2008
    Genius:
  • 1,847 Answers
Did you try with a new battery.
  • Legin Varghese
    Legin Varghese Nov 25, 2008
    If the battery is not powerful enough the flash won't fire.
    the first step will be to take the battery off and put it back and power back on.
    Next will be to do a reset by going into the menu.
    Hope this will help...Kevin.
Flash pops but doesnt fire
Still this is strange. Most of the time when I use the auto setting, I turn the main dial not on the green camera, but on the one between SCENE and the green logo. That prevent the flash to pop up. But still if you want to use the flash it should be possible.
Be aware that some settings the flash can't be used, f.i. when the shutter speed is to high. I would suggest to put al user settings back to standard and try to use the flash again. If it stalls again, try to read the display, if it gives anything of a warning or message.
Jan 18, 2014 | Nikon D5100 Digital Camera with 1855mm...
My nikon D60 and the pop up flash dosent work
the flash pivot on the release side of the flash has a small cylinder that operates the flash up switch. If that cylinder is broken off or the pivot is pushed in so the switch doesn't close, then what you describe happens
pop up the flash and remove the two screws underneath, and you can pry off the cover - gently - to check the switch
Mar 16, 2013 | Nikon D60 Digital Camera
Auto flash wont work
did it pop up automatically or did you pop it manually? if it popped up by itself then the flash unfortunately is probably dead, since on automatic, it won't pop unless it's going to fire. If you popped it manually then - the camera doesn't think that the flash is necessary for the conditions that you're shooting in.
Oct 21, 2009 | Nikon Cameras
D70 internal flash not firing
Check if something is preventing the flash to pop up 'fully'. Check for some dust or other particles trapped between the flash and the body. Does the screen say 'Subject is too dark'? If so, the flash has not popped up fully.
Nov 10, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
The flash on my d40x will no longer fire. the flash pops but nothing else happens! i have tried resetting but to no avail. i first noticed the problem while i was travelling so i couldn't send it off to be...
I do not want to speak down to you. If you pop up the flash and it does not fire it may be the mode. If the camera is in an auto mode and it feels there is NOT enough light to take the photo it will automatically pop up the flash and take the photo using flash. If it is in auto and it pops up the flash and it does not use it you may have a problem.
In most cases the best mode to use is P. In P mode (Programmed Auto) the flash NEVER automatically pops up (I find that very annoying). It will ONLY fire after you pop it up and take a photo. So with the camera in P. Take some photos with the flash down. Then try to take some photos with the flash up. It may also help to have fully charged batteries. Flash circuit uses lots of power for a short time to charge a capacitor. If the battery is too weak to charge the capacitor it will NOT fire the flash. It may have a RED LED or an INDICATOR in the View Finder that tells you the FLASH is READY.
Dec 01, 2017 | Nikon Cameras
Nikon d40 flash won't fire
If lightning bolt icon is blinking in viewfinder, flash is not ready. Either flash isnt popped up all the way or flash strobe tube is bad.
May 02, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon d 80 flash will not pop up while in auto mode
Put it in Auto (Green) mode then try, if flash pops up, it is the case of settings otherwise mechanical problem.
Mar 23, 2008 | Nikon D70s Digital Camera
Pop-up flash
make sure after popping up the flash, you didn't change the mode into "no flash" mode....an easy way to check is put the flash back down, then proceed to take another photo. If the flash pops up again but did not flash, you have a faulty camera (assuming battery level is at least until the 1/3 mark).
Dec 26, 2007 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon coolpix 5700
The red dot beside SB means that the flash is not ready. If the flash does not pop-up, I would say something is jamming it -- and not allowing the flash to pop-up. If the flash does pop-up, but the red dot stays on, there is a problem with the flash. The simplest might be a battery that is almost dead. The flash has to "charge" before it will fire. I have to admit, you would notice this rather quickly as the camera would power down within a few shots -- even if the flash didn't fire.
Check the pop-up flash position and get back to me. I hope this helps! Please post rating, if it does.
Regards,
Char1ieJ
Sep 16, 2007 | Nikon Coolpix 5700 Digital Camera
Canon 580ex "pops" in a baad way
Buy the flash tube and the cap., if they are bad.
It is not that hard, I can help.
Alexander
atdlee@netzero.com
Sep 04, 2007 | Canon SPEEDLITE 580EX TTL Flash
Cameras Logo
14 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
