Question about Panasonic CT-36HL43 36" TV
Panasonic HDTV /no power
Tv is pluggede into live outlet. remote turned it off, but now it will not turn on either power button or remote. have unplugged to see if it will reset
nothing!
  • dtendulkar Jan 13, 2009
    I replaced the fuse but after a few days it was blown. I replaced it again and it also was blown after a month. Any thoughts on what may be causing the fuse to blow?
  • Anonymous Jan 18, 2009
    do slammed in room, -tv stopped, now no power to TV. was working perfectly before. Tried pplugging , unplugging etc.
The loss of power was do to a blown fuse. could not access it through the small opening near where the power cord went in at the back of set.. carefully took the back of just far enough to access the fuse and replaced it. Working fine.
Posted on Nov 25, 2008
How do I fix the problem with my TV? Details are below.
Normally on the Panasonic tv this will call for a service call. The key to getting it repaired correctly is to check for a certified Samsung repair shop because most of the parts come from Samsung. Now if you want to do your own research call to 800 number for Panasonic Tv see if there are any problems with that model that the manufacturer has extended but does not post. I had one repaired that the red light on also so I understand and it went out approximately 4 3/4 years. If your in the Atlanta area use Norman electronics they have repaired hundreds on tvs for me due to my work.
Mar 05, 2016 | Panasonic VIERA TC-P55ST30 55-Inch 1080p...
My Sharp tv remote will not turn on / off tv. It will turn on by the main power switch on tv but not by remote.
From page 8 of the manual:
The POWER indicator on the AQUOS television should light GREEN indicating you have power to the AQUOS television.
If the POWER indicator on the AQUOS television still does not light up, press TV POWER on the remote control to turn the power on.
IMPORTANT:
IF THE UNIT DOES NOT POWER ON - UNPLUG THE AQUOS TELEVISION FROM THE OUTLET AND REPEAT THE INSTALLATION STEPS.
IF YOU STILL ENCOUNTER NO POWER, PLEASE CONTACT US AT 1-800-BE-SHARP
http://www.nemsworld.com/theater/LC46_52D62U_Manual.pdf
Dec 04, 2015 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Tv will not power up
Press the TV button or ON/OFF button while remote is in TV mode and there's a source of power to the outlet or outlet strip.
Make sure the TV is plugged in.
You might have tried to turn on the TV during the lamp cool-down. Wait a few moments and the picture will appear.
Has the power light on the front of the TV been blinking for one minute? If so, the lamp may be dead. Refer to the Power indicator
is blinking or flashing section below for more information.
When you first plug your TV into an outlet, the Power indicator on the front panel will light and blink for approximately 30 seconds
and then go off during the initialization of the TV. This happens only when the TV is unplugged and plugged back in. The TV can
only be turned on after the Power indicator goes off.
Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else, such as a lamp.
Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the
remote control solutions on page 53.
Multiple TV Setup might be set to the wrong option. Press MENU/OK on the front panel. Select Setup Options, then Advanced
Options, then Multiple TV Setup. Choose TV (default).
Sep 26, 2013 | RCA Scenium M50WH187 50" HDTV
Having problem with my Panasonic TV.
hello Plug the power cord back into a properly grounded wall outlet. Then press the POWER button on the projection display or the
While pressing the VOL- button on the projection display,
hold down the PIP or SPLIT button on the remote control
simultaneously for more than 5 seconds
When the lamp time reset procedure is complete, the
above screen will appear. (This screen may be different from
the actual screen
Note:
When the lamp time reset is complete, the LAMP
indicator goes out.
regards
shaun
Jan 18, 2010 | Panasonic PT-50LC13 50" Rear Projection...
My Panasonic HDTV will not turn on
Mine did the same thing. Did you find out what to do?
Oct 11, 2009 | Panasonic CT-26WX15 26" TV
Philips Projection tv will not turn on
Not trying to offend you here at all, but ....
1. Plug something else into the same outlet and verify that the outlet works.
2. Look at the power cord for any damage like wear and tear near either end of the cord.
3. Once its plugged in see if you can turn it on using the power button on the front panel (not the remote)
4. If it came on using the power button then there is not a problem with the TV.
5. If it did not come on then Sorry I can't help.
6. If it did come on then make sure the "tv" button near the top of the remote (assuming its the original remote) was pressed before pressing the power button on the remote.
Jun 01, 2009 | Philips 55PW9363 55" Rear Projection...
I was wondering if you could tell me how to reset the timer after I have installed a new lamp. Can you help me? tv is a panasonic pt-56dlx25 Thanks, dave
Plug the power cord back into the properly grounded wall outlet. Then press the POWER button on the projection display or the remote control to turn the power on.
2. While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control simultaneosly for more than 5 seconds.
3. Whe the lamp time reset procedure is complete, the screen will display "LAMP TIME WAS RESET TO 0." When the lamp time is reset, the LAMP indicator will go out
Dec 30, 2008 | Panasonic PT-56DLX25 56" HDTV
Green and purple ghosts
Try to reset first if nothing happens we proceed another solution;
Resetting the TV
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can saved time.
1. Unplug the TV power cord from the power outlet for 3 - 4 hours.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Oct 09, 2008 | Panasonic PT-47X54 47" Rear Projection...
Panasonic CT-36HL43 36" TV Logo
200 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
