Question about Kenmore Elite 45986 Front Load Washer
Plastic in drum
I have a kenmore elite model 110.2408 with Calypso wash motion, after washing a load I noticed plastic in the wash tub and am hearing a kind of whining noise not very loud and also twice now the timer has gone from 4 minutes left then jumped back to 6 minutes left
  • 116 Answers
REMEMBER IN 4- 6 -8 MINUTES IS YOUR DRAIN AND SPIN CYCLE, PLZ INSPECT PUMP,,, AND SUMP THAT WILL RESOLVE YOUR PROBLEM
Posted on Nov 30, 2008
Cant get my washer back together.
Make sure the rear seal has not turned in and become curled into the path of the rear ring on the drum.
Oct 04, 2009 | Kenmore Elite 45986 Front Load Washer
Where is the reset switch located on the Calypso
There is no reset.
Simply unplug for 40 minutes to reset the ECU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 19, 2009 | Kenmore Elite 45986 Front Load Washer
Water drains during spin cycle, but tub does not spin and appears to have dropped down. Machine does aggitate.
If you can move the tub by hand laterally - the rear main bearing has likely failed - or the drum rollers are worn.
May 30, 2009 | Kenmore Elite 45986 Front Load Washer
Smelly wash tub, in washer.
Model nums are fine in the store, if it is an oasis or calypso make sure drain hose is not in drain more than 5 inches. If not your pump might be going out or is clogged. A great cleaner developed is called washer magic and it will help the smell with some elbow grease. If not and is a traditional top load check motor and gearcase or even the timer for wear in a old machine.
Aug 23, 2008 | Kenmore 22422 Top Load Washer
Kenmore elite calipso was motion
calyso is a low water use machine similar to front loads only enough water enters machine to get clothes soaking wet water is recirculated through tube on back right corner of tub to insure clothes are soaked if pressure switch determines minum water level not reached it will add more
Apr 26, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore elite calipso wash motion
your inlet filter is most likely plugged.
take of your hoses from the machine and clear the filters in the machine inlet ports.
If this does not help your inlet valves are broken.
But most likely the filters is the good bet
Washing machine leaks
I'll guess the plastic sleeve needs to be connected to something nearby..
Sep 24, 2007 | Kenmore Elite 21082
Kenmore Elite 45986 Front Load Washer Logo
193 people viewed this question
Sal De
fordexpert
Robert Rankin
