Question about Philips 55PP9352 55" Projection Television
TV will not turn on. It makes a nonstop clicking noise.
The clicking noise is nonstop in perfect sequence. It sounds like the TV is turning on and then off immediately. No picture comes up on the screen.
  • the_derr1 Nov 25, 2008
    cumminsisbe
    If I replace the power supply, will this fix the problem?
    cumminsisbe
    Or should I replace the halide lamp. Or maybe replace both. What do you think?
Sounds to me like the high voltage power supply is attempting to fire off the metal halide lamp without success.
Posted on Nov 24, 2008
  • Matt Nov 25, 2008
    I'd try a new lamp first...the power supply is probably a lot more expensive to replace. Lamps go out far more often than the power supplies and have a service life of only 3000hrs (+/-).
  • Matt Nov 25, 2008
    Lamps aren't cheap...you're looking at spending at least $300. There are lots of folks that have managed to take 'generic' metal halide lamps and fit them inside whichever base/socket your particular lamp needs to fit into the specific recepticle in the TV.
When i turn the key there is a nonstop clicking.The car sounds like it wants to start but doesn't
Make sure battery is fully charged. Check all battery cable connections. Make sure they are tight and free of corrosion.
Mar 20, 2013 | 1994 Toyota Camry
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
No Power up. Has 3 relay clicks when you plug it in. No LEDs light up and no flashing code from the stand-by LED. Have service manual. Where do I start?
hello the best thing to do is turn the power off take the back cover off and visual inspect the boards in side get a good torch and check for any bulging capacitors burnt resistors if everythink looks ok then you will have to check underneath the boards for any try joints i hope this helps
regards
shaun
Feb 23, 2010 | Sony KP-53HS30 53" Rear Projection...
I was watching tv and out of nowhere the tv turned off and now will not turn back on for more than a couple seconds. When it does turn on it makes a click noise then turns off, with no sound or picture.
Dec 14, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Annoying noise
If this is a projection tv, the sound you are hearing is the color wheel spinning.
Sep 28, 2009 | Televison & Video
Does the Samsung PN58B650 need a minute to warm up the first time you turn it on every day? When I turn on the TV for the first time every day, the picture is there but the colors on the screen are pink...
I swapped out the HDMI cable with standard component cables. The picture and sound is perfect. Later I will swap again with a different HDMI cable to confirm if the problem is a bad cable or if the TV has a problem with HDMI.
Sep 22, 2009 | Samsung PN58B650 TV
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
May 21, 2009 | Televison & Video
Jumping Screen
I've had a couple of these. The panel control board is going bad, but there may be a way to make it last a bit longer. If you go into the MENU of the TV, and turn off all the color correction, all the whistles and bells that come inside the tv to "make the picture better," it usually helps. Any kind of motion correction, or any kind of noise reduction (picture noise reduction) should be turned off. If the picture has a cloud of green pixels that seems to pepper the screen, then after you turn off all the stuff in the menu, unplug the TV for 5 minutes, and then plug back in. It should help the picture some.
Hope this helps...
Jan 05, 2009 | Insignia IS-LCDTV32 32 in. Television
Philips 55PP9352 55" Projection Television Logo
402 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
