Question about Panasonic SC-HT650 System
Unit will not turn on.
Unit worked earlier in the day, went to take a DVD out and hit the power button only to hear a click followed by another click. No display came on at all, the red AC led is on indicating it's getting line in. I pulled the cover off and tried powering it up, clicking sound is coming from a relay on the board by the AC plug. What is most likely the problem, the relay or the power supply?
  • loar61 Nov 25, 2007
    I took the DVD out of the unit. The next time I tried to use the unit, F61 appeared on the unit. It would not stay on and the DVD player would not open.
  • defiled33 Dec 26, 2007
    I too am getting the error F-61 on my Panasonic SA-HT67.
    While watching a DVD it gave out a pop sound and shut down. From then on when ever I try to turn it on, it gives me the F-61 and shuts down again. It even does this with nothing plugged into it.
    defiled33@hotmail.com
Take the cover off and check both fan connections. I did this and it turned out to be a loose connection causing the F61 error. Also, check to see if the fans move even just a bit when you turn the unit on. If only one moves then you may have a burnt fan, if neither move you have a major problem. If they both move continue checking connections, loose solders etc. If all else fails, but a new one.
Posted on Sep 05, 2007
I think we have the same problem only mine is flashes an F61 on the display then shuts itself off.
Posted on Jan 22, 2007
Okay basically, i turn on the ps3 , it looks perfectly fine but on the menu , it just shows the backround and there are no options. what happened to it? it was working fine earlier
How to Access Playstation Recovery Menu
1. Turn off Playstation®3.
2. Hold The power button down; The system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be promted to plug in your controller via usb and then hit the PS button
6. The Recovery menu will pop up.
try to recover your unit from here you will lose data depending on options you try son start with rebuilding your file system and try from there good luck ok
Nov 25, 2010 | Sony Playstation 3 (PS3) Console
I tried turning on my tv and i hear the click like it is turning on...but the scrteen reamins blank. i hit the button again...and nothing...i hit it again...and i hear the ckick again but it doesnt turn on
This TV will need to be repaired, What you hearing is a relay in the power supply unit not able to send power to make a circuit, okay this could be due to a bad powersupply,or bad flyback.
I would suggest bringing it into the shop $95 bucks to fix it for good. You be glad you did.
Thanks and please do leave postive feedback for your free answer today!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Nov 10, 2009 | Apex Digital AT2014DV 20 in. TV/DVD Combo
We have a Honeywell A/C (we believe it's a focus pro 6000) that is not working properly. The A/C unit itself is running but the vents inside the house are not cooling. We think it's a problem with the...
the honeywell is just a thermostat.my guess is the capacitor went out in the condenser when you lost power.turn the temp down on the thermostat and hit the hold button.....if it does not cool,call a service tech.good luck!
Sep 24, 2008 | Honeywell Heating & Cooling
DVD Stuck in Player
While the above problem is not in the manual, I would try pushing and holding down the Open/Close buttton for an extended period to see if the unit will 'unlock' itself.
Mar 16, 2008 | Sanyo DWM-390 DVD Player
Truck dvd player concept/pronto
Does it possibly have a reset button you could press with a paperclip? If not, try disconnecting the constant power wire for ....let's say an hour, and hooking it back up.
Nov 28, 2007 | Concept Slot Load Half-Din DVD Player Car...
HCT DVD recorder: HDVR-960s
I purchased this same unit yesterday from the PX Power Zone. I hooked up the unit and even managed to record a few minutes of a show. I then went into setup and made a few changes. Now, I have no display at all from the unit. Does anyone know how to reset the unit back to factory settings? Please email me at bjessip1@hotmail.com. Many thanks!
Bill
Nov 04, 2007 | Samsung DVD-R155
Sudden failure to power up
I've had this happen a number of times with my receiver. This trick from the Troubleshooting guide in the owner's manual usually does the trick: To reset If an unusual condition in the display window or malfunction occurs, reset the unit as follows. 1 Press the POWER button to turn off the power. 2 Press the POWER button while pressing the ENTER button. Everything stored in memory after purchase is canceled. If the power cannot be turned off in step 1 because of a malfunction, reset by disconnecting the AC cord and carry out step 2.
Aug 01, 2006 | Aiwa AV-D77 Receiver
Panasonic SC-HT650 System Logo
269 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
