Question about MSI MS-6734-10 (-6734-010) Motherboard
Upgraded computer and won't come on, no bios.
Put MSI ms-6734, amd xp2100+, 2 gig (2 sticks of 1gig) PC2100 DDR in computer and now it won't bring up the bios or boot up. It comes on, runs the fans. Mobo was taken out of a working PC 2 weeks ago by myself, as was processor, got ram today. HDD light stays on, solid. Switched JBAT1 jumper to reset CMOS then switched back and didn't change anything.
    Genius:
  • 1,913 Answers
Disconnect all and reconnct it.something jammed .may be *********** bord circuit is ground.
disconnect hdd ram then try.
to reattch one by one.
try with only smps ,mother bord and ram.
also check processor sitted correctly.
Posted on Nov 24, 2008
Install DDR-DIMM PC3200 to MS-6367 MSI
That motherboard was made for PC2100 DDR266. A PC3200 DIMM *SHOULD* be backward compatible. Depending on the density of the PC3200 memory you might have problems. If you have not bought the memory yet I would go with the PC2100 for sure since the PC3200 will give you no speed gains at all and will be running at PC2100 speeds anyway.
If you already have the PC3200 memory then I would say just give it a shot. The worse case scenario is your machine will not boot up with the higher speed ram installed. Assuming you take all the normal hardware upgrade care and do not physically break anything you can test this memory with no harm to your motherboard.
Aug 12, 2009 | MSI MS-6367 Motherboard
Replacing existing DDR RAM
Well this that you can use PC3200 DDR 1GB then those you mentioned above ... and let me tell you there is only bus speed difference between ..
Jun 23, 2009 | MSI 865P Neo (MS-6742-020) Motherboard
Recognition of 3gb memory
Are you installing the correct memory type? I have the same motherboard, make sure you are using PC2100 DDR memory. I assume you are using 3 1 gig sticks of mem is this correct?
Nov 11, 2008 | MSI KT3 Ultra Motherboard
MSI motherboard model 6734 AGP interface
Looks like your motherboard is a MSI KM4AM-L detailed here:
http://www.msicomputer.co.uk/index.php?func=proddesc&prod_no=572&maincat_no=1
If so, then it has an AGP slot which will run at 4x and 8x.
Remember to check the BIOS settings after you install it to make sure it is set to 8x, if that is what your card will take.
Sep 22, 2008 | MSI KM4M-L Motherboard
Whether supports DDR?
Hi valentin122, you're board does not support PC2700 memory.
The link below will take you to you're board,
MSI 845 UltraC (MS 6566). Suggest you add to you're favorites.
http://www.msicomputer.com/product/p_spec.asp?model=845_Ultra-C
There is not a bios upgrade to support PC2700 memory.
Bios link.
http://global.msi.com.tw/index.php?func=downloaddetail&type=bios&maincat_no=1&prod_no=295
You're manual is here.
http://global.msi.com.tw/index.php?func=downloadfile&dno=3466&type=manual
See page 2-5 in you're manual.
The mainboard provides 2 slots for 184-pin, 2.5V unbuffered DDR DIMM with 4 memory banks. You can install PC1600/PC2100 DDR SDRAM modules on the DDR DIMM slots (DDR 1~2).
To operate properly, at least one DIMM must be installed.
Here is a link for you're memory. To reach you max GB, you would need 2 DIMMS.
http://www.computermemoryoutlet.com/Standard_DIMMs-PC2100_(266MHz)_DDR-184^pin_NON_ECC_(Usually_for_desktops)-memory.htm
Have more questions, feel free to ask.
Good Luck!
Mike
How to vote you're expert.
Enter FixYa.com site.
Sign in to your FixYa account.
Locate My Profile on our FixYa's homepage.
Under My Problem locate your problem and click on it.
Under the solution given by the expert, choose.
Apr 12, 2008 | Computers & Internet
MSI MS-6734-10 (-6734-010) Motherboard Logo
223 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
