Question about GPS
I have a nuvi 650, made a mistake and erased the maps. tech support sent me a copy now what folder in the garmin folder do I install them too? Thank you
  • jen932 Nov 25, 2008
    PERFECT! Thank you.
  • Anonymous Apr 07, 2009
    erased the maps on 650
  • GPS Master
  • 2,130 Answers
You put it in the folder marked "Garmin".
- Jim
Posted on Nov 25, 2008
    SHARCNET-USA Nov 25, 2008
    No subdirectory... just the folder marked "Garmin".
I want to delete maps from my Garmin Nuvi 1450 LMT to make room for different country maps. How would I do this? I have been looking for answers online and in manual for hours now with no luck. Please...
    • 1 Remove the SD card from the Garmin GPS.
    • 2 Insert SD card into your computer's card reader.
    • 3 Open the "My Computer" in either the desktop or the start button.
    • 4 Double click the SD card folder to open it.
    • 5 Hold "Ctrl" on your keyboard and left click on all the map files in the folder. Once they are all highlighted, right click and select "Copy."
    • 6 Go to your desktop, right click and select "Paste." You have created backup copies of the maps in your Garmin GPS. Return to the SD card folder via "My Computer."
    • 7 Select the map file you wish to delete, left click it once and press both "Shift" and "Delete" on your keyboard.
    • 8 Return the SD card into Garmin GPS. Turn it on. Check the screen to see if the right map has been deleted. If any mistakes are made, simply start over from step 1. Replace any map that has been accidentally deleted.
    • OR Insert one end of the USB cable into the USB port on the Garmin. Insert the other end of the cable into the USB port on the computer.
    • 2 Click on the desktop "Start" menu, and chose the "Computer" folder.
  1. 3 Right-click on the Garmin drive folder, and select "Open." Some Garmin GPS devices (e.g., Nuvi 200 through 800 series devices) will have the map files stored here. Browse this folder for maps you want to remove, right-click on the file and select "Delete." If no map files are available, go to step 4.
  • 4 Double-click to open the "Map" folder.
  • 5 Right-click on any map file that you want to remove, and select "Delete."
  • Sep 18, 2011 | Garmin Nuvi 1450LMT
    I bouth in the end 2008 Garmin Nuvi 760 with usa maps. I live in Argentina and travel frecuently to ST = CT. For mistake erase the usa maps and in few day i ll travelingo to U.S. There are same webside...
    The garmin maps are copy protected and are registered to your device.
    You may be able to pick one on a memory card off ebay cheaply especially if you do not want the very latest version.
    Please dont forget to vote this answer was helpful
    Many thanks
    Feb 15, 2011 | Garmin Nuvi 760 Car GPS Receiver
    Garmin Nuvi 205 can't unlock maps
    First, check to make sure the map file is there. The file name is gmapprom.img. It's located in the Garmin directory. It should be 1GB in size. To do this you need to connect the Nuvi to a PC with a USB cable.
    Next, please tell me what year of map you have on your unit, 2009, 2010, etc.
    Them, email me your units internal serial number. Its a 10 digit number (not the number on the outside). The number starts with a "3" and can be found by pressing the tools button, then system and then "about".
    Please email me at sharcnet-usa AT sharc DOT NET
    - Jim
    Mar 25, 2010 | Garmin nuvi 205W GPS Receiver
    Garmin Nuvi will not load maps - why
    Try the Hard Reset procedure outlined in this tip.
    Does your Garmin Nuvi 205 or 205W Freeze at Loading Maps?
    Does it lock up or stop working?
    This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them.
    A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior after firmware updates. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit. It's also one of the first things that Garmin will have you do when contact tech support regarding quirky unit behavior.
    Backup and Restoration Procedure for Favorites:
    The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
    1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
    2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
    3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
    Perform the Hard Reset:
    *Note that this will clear all user selected settings on the unit
    1. Power the unit off.
    2. Remove the battery and wait several minutes.
    3. Install the battery.
    4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
    5. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
    6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
    If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
    You have now performed a hard reset of your Garmin Nuvi 205 and 205W.
    I hope that helps.
    Jan 07, 2010 | Garmin nuvi 205W GPS Receiver
    Lost my map in my garmin nuvi 350 how can i get it back
    Form Message You need to have Garmin Tech support send you this attachment; "gmapprom.unl" Then follow the instructions below.
    1.) Save the attachment from our message to the desktop
    2.) Right-click the file gmapprom.unl, and click copy
    3.) Click on My computer
    4.) Click on the Garmin Nuvi drive
    5.) Click on the Garmin Folder
    6.) Rightclick a blank white space in this Garmin folder
    7.) Click Paste, and note gmapprom.unl file is listed, please also delete gmapsupp.img if present
    8.) Unplug the device, and allow to start up
    Jun 04, 2009 | Garmin nuvi 350 GPS Receiver
    Garmin Nuvi 200 Maps Disappeared
    Hope this helps!
    I wanted to add maps to my 250W. I found the maps I wanted on a Torrent. However, many searches around various forums never revealed how to install these. Found the following through reading and experimentation.
    1. Downoaded map image file GMAPSUPP.IMG. Download also gave me "Use code XXX when generating unlock code for maps"
    2. Downloaded Garmin Unlock Generator 1.3 by JetMouse
    3. Looked on my GPS to find the UnitID
    4. Entered the UnitID into Garmin Unlock Generator. Ignore the GM XT device unlock code and the top Generate button.
    5. Selected Map Product as Custom and entered the code given for the downloaded image file.
    6. Hit the bottom create button to generate a 25 digit code.
    7. Download Img2Gps and run
    8. Click Load Folder to load the image file. Select the tick next to it.
    9. Check the Use Unlock Key option and paste the 25 digit code in.
    10. Load a blank SD card into your Garmin
    11. Connect the Garmin to your PC using a USB cable. You should see two dirves in windows: one is the Garmin and the other is the "Removable Disk" SD card.
    12. Create a folder called "Garmin" on the SD card
    13. Select Folder/Card in Img2GPS
    14. Click "Copy Maps". Select the folder /Garmin on the SD card. You may need to click copy again.
    15. Upload will take a while.
    16. You should now see a file GMAPSUPP.IMG on the SD card in the /Garmin directory.
    17. Create a new text file called GMAPSUPP.UNL in the same directory (make sure it does not have a hidden .txt extension).
    18 copy the 25 digit unlock key into this file.
    19. Close the file.
    20. Disconnect the Garmin.
    21. On Startup it should load your original maps and the new ones.
    May 28, 2009 | Garmin nuvi 200W GPS Receiver
    NUVI 310
    you will need to erase a file from the units memory. Connect your GPS system to your computer; go to start then ‘My Computer’, and double click on your device file (mass storage system), there you will see a folder named ‘Garmin’. In this folder are several different files, look for file named gmapsupp.img. Right hand click on this file and delete as this file is causing the maps to lock.
    Dec 09, 2008 | Garmin nuvi 350 GPS Receiver
    2009 map update not loading
    Fixed. Called Garmin. It seems that version 4.90 FW on the Nuvi 350 (which came shipped on my 350) has a bug where it cannot communicate with the Garmin software either to update maps or update FW. Tech from Garmin e-mailed me a patch that I copied into the Garmin folder on the Nuvi itself, via USB and Windows Explorer. I then rebooted it; the patch installed itself which then allowed the unit to communicate with the map upgrade software and all is well. 2009 map update is now installed and the Nuvi is working fine again. Haven't tried upgrading to newer FW yet; will probably leave well enough alone.
    Jul 01, 2008 | Garmin Nuvi 660 GPS Receiver
    Product key for free download
    i don,t have product key for nuvi 650 he say the key is in disc i don,t know thank
    May 27, 2008 | Garmin nuvi 200W GPS Receiver
    From the Garmin web site:
    Question: What should I do if my Garmin nuvi / zumo displays the message “No Detailed Maps That Support Autorouting.”?
    Answer: Please follow these steps to troubleshoot the error message:
    Checking the unit:
    1. Hold your finger down on the screen until the message “No Detailed Maps That Support Autorouting” disappears.
    2. If you get a locked maps message following this error please remove any SD cards in the device and skip down to the instructions for “Getting your unlock codes”.If you did not get a locked maps message then please select tools>settings>map>mapinfo button.
    3. Check the box next to the mapping product City Navigator and you should no longer get the “No Detailed Maps That Support Autorouting” message.
    Feb 05, 2008 | Garmin Nuvi 360 Bilingual GPS Navigator...
    GPS Logo
    57 people viewed this question
    Top GPS Experts
    Will Halftowaite
    Are you a GPS Expert? Answer questions, earn points and help others
