Question about Garmin zumo 550 GPS Receiver
Zumo 450 Power Through Cigarette Lighter
I cut the cigarette lighter (male) end off an old cell phone car charger and hooked it up to the two ends of the power wire going to the cradle however when I plugged it into the lighter hole, it doesn't work. I know the cradle and power wire are good as I touched the wire to the battery terminals and it fired up, no problem. Am I not getting the same 12 volts through the cigarette lighter?
  • 89 Answers
You should be, Check to make sure the fuse isnt blown on either the cigarette lighter plug or in the plug that has the wires coming out of it.
Posted on Nov 24, 2008
Buick Lesabre missing cigarette lighter outlet.
cigarette lighter has ONE wire, attached to center contact on the back end, and grounds via the case, or a wire attached to the case and the other end to the support structure of the dashboard.
Jul 04, 2014 | 1990 Buick LeSabre
My accessory plugs don't work but the cigarette lighter does
sounds like the power end of the GPS is faulty.
Oct 10, 2017 | Kia 2008 Sorento LX
Fuse keeps blowing.even after i replaced the cig. Lighter why
Main cause could be something stuck in the lighter socket. Sometimes, the ends of the car charger for a cell phone of GPS will separate, leaving the end in the socket itself. Placing the cigarette lighter back int he socket while there's something already in the socket will cause you to blow a fuse.
Jul 20, 2011 | 1990 Buick Century
2006 Jeep Wrangler cigarette lighter not working
Check for un-isulated connection on the hot wire lead. It might have been after-market but on mine the connection would short out, blowing a fuse. 1 inch of heat shrink tube fixed the problem.
Mar 08, 2010 | 2000 Jeep Wrangler
Is the cigarette lighter also the plug for cell phone charger?
The cigarette lighter plug should also work for the phone charger as long as the phone charger uses the cigarette lighter style plug(long with two metal contacts on the sides and a button contact on the tip). Most standard car chargers will fit both cigarette and auxillary style plugs.
Dec 29, 2009 | 2004 Ford Focus
Nokia 3310 charger.. won't charge help me..
if its the car charger check the cigarette lighter fuse and also the charger fuse
Sep 25, 2009 | Nokia Car Charger: 3310 3360 3390 3395...
Porsche cigarette lighter is bigger than standard cigarette plug
Found a cigarette lighter assembly that is the standard DIN/SAE size that is a direct replacement for the one in my car.
Aug 31, 2009 | Garmin zumo 550 GPS Receiver
Cigarette Lighter Pulled Out
The part that Pulled out Should Screw into the Part that is still in the Car.
Jan 21, 2009 | 1999 Mitsubishi Eclipse
1993 Mercury Tracer cigarette lighter
I assume that you tried the cigarette lighter itself and didnt rely solely that the charger was working properly. When you tightened the ring on caseing did you see that the wire connected on the back of the lighter was properly attatched, sometimes a good connection loosens up especially if caseing was found to be loose.. Well assuming it was properly connected you could test the circuit with either a multimeter or 12 volt test light if power is found at connection then you problem is definetly the cigarette lighter assembly itself.. I hope this was helpful...Let me know I would appreciate it
Dec 27, 2008 | 1993 Mercury Tracer
Battery dead; cannot open hood
If the cigarette lighter is an unswitched power point you could use it as a location to put a very small charge, just enough to get the hood release solenoid to activate. Years ago there was a device that was a male cigarette lighter power point at both ends and enough cable to go from car to car. DO NOT ATTEMPT TO DO ANYTHING ELSE EXCEPT OPEN HOOD, DO NOT TURN KEY TO RUN OR ATTEMPT TO START. ANYTHING COULD RESULT. MINOR OR MAJOR. THERE IS A COMPUTER MEMORY SAVER THAT MATES A 9 VOLT TO A MALE CIGARETTE LIGHTER PLUG THIS MAY NOT BE ENOUGH TO RELEASE HOOD BUT MAYBE WITH A 12 VOLT FLASHLIGHT BATTERY (2 6 VOLT BATTERIES) WOULD WORK TO OPEN THE HOOD. (TURN EVERYTHING OFF EVEN DOME LIGHT.)
Aug 23, 2008 | 1999 Porsche Boxster
Garmin zumo 550 GPS Receiver Logo
193 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
