Grundig Elegance 82 MW 82-2101 Minutes after startup the picture disappears and standby light returns. 30 minutes of pressing remote finally the picture stabilizes and is perfect.
Does not work
Posted on Apr 13, 2011
TV powers off after an hour aprox.
Hi the auto standby function MIGHT have been activated to disable PRESS MENU BUTTON ON REMOTE SCROLL DOWN TO SETUP & PRESS OK. SCROLL DOWN TO OTHER SETTINGS & PRESS OK ....SCROLL down to AUTO STANDBY AND PRESS THE LEFT & RIGHT ARROWS To SET THE OPTION TO OFF ....GOOD LUCK
Jul 02, 2016 | Panasonic Televison & Video
Sky box green light on permanent
Sounds as if the software is corrupt. Try a forced software update...
1) Switch the digibox off at the mains power, so no lights are displayed on the unit
2) Press and hold the BACK UP button on the digibox (not the remote control)
3) Whilst holding, switch the digibox back on at the mains power so the red standby light is displayed
4) Wait approximate. 10-20 seconds for the remaining 3 lights to display, at which point you can release the BACK UP button
5) Allow the digibox to download the latest software, which can take 10 minutes before returning to standby
6) Leave 60 seconds then power up as usual
A software update/refresh will leave your recordings intact. You won't lose anything.
If this doesn't solve your problem, then the next step is more drastic. It's a Full System Reset and Planner Rebuild. Be advised though: Your recordings are at risk!
1) Switch your digibox on
2) In sequence, press on your remote 'SERVICES > 4 > 0 > 1 > SELECT' (this will access the hidden menu)
3) Select the relevant option (usually the bottom two) and follow the on-screen prompts (note that it's likely your digibox will reboot between processes)
Applies to Sky+HD Digiboxes only, running latest EPG
1) Press Services on your remote control. 'Options' in the Top Menu will be highlighted in orange.
2) Press the Right arrow once to highlight 'Settings' in the Top Menu.
3) Now press the Down arrow once to highlight the 'settings' tab in the Middle Menu.
4) Press 0, 0,1, Select on your remote in quick succession. The 'Setup' tab will then be highlighted within a hidden menu.
5) Select the relevant option and follow the on-screen prompts (note that its likely your digibox will reboot between processes)
Sky Digibox Planner Rebuild / Full System Reset (if stuck in standby)
Applies to Sky+ and Sky+HD Digiboxes only
Same as above, but applies if your digibox is stuck in standby and you cannot get to the hidden menu:
2) Press and hold the 'right and left arrow' buttons on the digibox (not the remote control)
4) Wait approximate. 30 seconds for the blue Sky+ ring of lights to display, at which point you can release the 'right and left arrow' buttons
5) Press 'SELECT' on the digibox (not the remote control)
6) Now the system will format the hard drive, the blue Sky+ ring of lights should spin backwards
7) Allow the system to format, which can take 10 minutes before returning to standby
8) Try to power up!
Sep 02, 2014 | Televison & Video
Have grundig elegance tv and when switched on this morning stuck on standby tried switching off at mains etc no difference
sounds like one of the caps on the circuit board has popped. this needs to be returned to the store.
Nov 28, 2010 | Televison & Video
Lcd problem
Unplugging the television for about fifteen minutes or so, then plugging it in again.
Dec 26, 2009 | Grundig GU19WDT 19 in. LCD TV
What does it mean when that blinking green light turns to orange one in lp 350?
Hi
This would be "Standby"
When you press standby, the display and audio turn off and a blank screen is displayed for 15 minutes.
You can change the amount of time the projector stays in standby mode; see “Standby Time” on page 27 for details.
The LED lights orange while the projector is in standby.
• If you press standby again within 15 minutes, the projector returns to normal operations immediately. The LED changes from orange to green.
• If you press standby again after 15 minutes, there is about a 60 second delay before the lamp turns back on. The LED flashes green while the lamp is re-lighting.
• If you don’t press standby again, the lamp turns off after 15 minutes. The LED lights orange while the projector is in standby.
The full manual can be found here:
Infocus customer support
Infocus LP350 Manual
I hope these help
Mike
Sep 18, 2009 | InFocus LP350 Multimedia Projector
Picture disappears after a while
panel is bad not econimical to repair.
May 31, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
Grundig arganto 82
You have a problem in the secondary of the power supply,no amount of switching on or off will solve this,it will have to go to service,
May 17, 2007 | Grundig GF70-600 TV
Televison & Video Logo
252 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
