JUST NEED TO KNOW HOW TIGHT TO TORQUE THE SPIN BEARING NUT ON THE OUTER HUB ON MY MACHINE I SEE THERE IS LOCK TITE BUT I CANT FIND A TORQUE AND I KNOW FROM BEING A AUTO MECHANIC BEARING TORQUE IS IMPORTANT!
I assume the bearing is connected to a belt drive. if so its more important to get the tension on the belt first , to prevent unesssecary wear on bearings,and i believe it would be the same tension that you would have on the alternator belt of a car.
SOURCE: whirlpool duet washer sport ht - error codes
FYI: The pump cleanout is located on the front of the machine, bottom right corner. There are only three screws holding the bottom cover on. It is easy to get to if you prop it up a few inches off the ground. Just thought this would be helpful as I just did this as of 5 min ago. Should take 10 min. or less.
SOURCE: Whirlpool Duet Sport HT front load washer keeps having F21 Error
remove the lower access panel (3 screws along the bottom of unit) behind htere you will see the pump and an access to clean the pump filter, probably filled with assorted debris. be aware when you unscrew there will be water behind it,
SOURCE: Code F1 @ Whirlpool Duet Sport Washer
An F1 is almost always a defective main control board. Could try unplugging the unit for a few minutes and see if it will reset. The part # for the board is W10110072. Sears sells it for $119.46 http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WFW8300SW01&productCategoryId=0153200&brandId=1198&modelName=RESIDENTIAL-WASHER&diagramPageId=00003&componentDescription=CONTROL%20PANEL%20PARTS&documentId=W0607261&backToLink=Return%20to%20Sub%20Components%20list.
SOURCE: Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
SOURCE: Very Loud and Active Whirlpool Duet Sport Washer
It looks like the transit bolts are still in there at the back and if you take them out it should be more quiet.
Rear hub and bearing
Click to Enlarge
To install:
Click to Enlarge
Rear hub removal
Inner wheel bearing removal-rear hub/bearing
Rear wheel bearing removal-2wd
Rear wheel bearing removal-4wd
To install:
Install or connect the following:
Rear wheel bearing installation
hope this helps if so send testimonial comment or even any other questions you have
