2 inches of transluscent white lines appear at top of TV screen.
The TV is just 2 years old. Several transluscent white lines are appearing at top of TV screen. I can compress the screen to 4.3 and they go away. But not all channels look good compressed. What is causing this? Thank you for your help.
  • ck_sparks Nov 26, 2008
    I omitted the brand of TV which is Magnavox 27MT60050
    Genius:
  • 1,550 Answers
Your TV has lost adjustment .
Most likely the controls are inside the TV and that a trained person needs to do the adjustment.
If your model is very old .
Then there will be an adjustment screw for controlling on the back of tv .
It would let you correct this problem with just a screw driver .
Thanks for using Fixya .
SAM ANDERSON
Posted on Nov 25, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, would suspect vertical capacitor. The lives would be slight slanted with the left slightly higher than the right and the right fading a bit. Should this be the case, then as earlier proposed, capacitor.
Might you pls post back the brand and model.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 26, 2008
    For some reason, your posted brand/model "Magnavox 27MT60050" does not show in the database. In any case a probable comparable model, the capacitor is a 100 uF/ 35V or in some others a little lower values. Cost estimate is less than a dollar for the parts and should be readily available from most electronics parts stores. Repair should be less than 30 minutes barring any unforeseen faults. Service fee would depend on the going rate in your area.
    Cheers.
White line across screen
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sony 46 KDL46EX523 LCD TV
Lines down screen
We have a Samsung LE32A457, whilst we were watching T.V tonight the top halve of the screen suddenly appeared with green lines halfway down the screen and that half of the picture was unwatchable, T.V is 2 years old. We have removed all scart leads but this did not help and the problem still exists, when shutting down a white horizontal line across the centre of the screen appears from this line upwards the picture is faulty. Any help or advice would be grateful.
Jul 08, 2010 | Samsung LE32A457 32 in. LCD TV
Horizontal white lines 27A43.
You have some bad capacitors. They are located very near and next to your vertical IC. I would guess you would have to replace maybe four of these! Thanks for asking!
Jun 12, 2010 | Toshiba 27A43 27" TV
Toshiba 27WL46 27 in.LCD- Lines top of screen getting worse.
If they are vertical lines, then the LCD panel is going bad, it will get worst with more lines appear as time goes on.
Jan 07, 2010 | Toshiba 27WL46 27 in. LCD Television
Orange 2 inch line appeared on left side of screen ,then no pictu
it could be jusr a bad connection on th LVDS cable or your panel has died
have a tech check it out or send it to Tops Electronics in Haverhill ma
Nov 18, 2009 | Vizio P42HD Television
Visual transparent lines at top of picture
You have a vertical output circuit problem. This was common for Philips' sets. Have a repair shop check it out. Should not be too expensive to repair.
Oct 15, 2009 | Philips 27PT6441 27" TV
Same white lines on top of screen
you still go the warrenty on it
Jun 04, 2009 | Toshiba 32D46 32" TV
White horizontal dashed lines appear and at top of tv screen
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Mar 13, 2017 | Apex Digital GB43HD09 43" Rear Projection...
Horizontal lines across the top 3 inches of picture
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
Nov 28, 2008 | Philips 32PT6441/37 32" TV
Televison & Video Logo
Top Televison & Video Experts
