Question about Sony Handycam DCR-HC32 Mini DV Digital Camcorder
Battry Mode not working
My Sony Handycam DCR-HC32 is not working in the battery mode but working in the direct supply mode. I tried replacing the old battery with a new one but couldnt solve the problem. I cant neither see the battery info nor charge the battery. When put to charge the light to indicate the cam is on charge too is not glowing.
    Sergeant:
  • 211 Answers
Replace the power supply/charger and that should solve your problem.
Posted on Dec 03, 2017
  • Ron Reynolds Dec 03, 2017
    Sounds like the power supply/charger is the problem. Check on ebay for a replacement.
    Sergeant:
    Habit-Forming:
  • 152 Answers
If where you put the batteries in are corroded you can use a small file or sand paper to clean them up so you can get better connections hope this helps Merry Christmas
  • 473 Answers
SOURCE: Camcorder to Mac Sony dcr-hc32
Maybe this FAQ will help ya? Problem: Camcorder will not connect to iMovie - No camera attached Possible Solutions: * Are you using a 4 to 6 pin firewire cable? That is the ONLY thing you can use. No USB cables or anything else * Are you using a compatible camera? Still cameras that take movies are NOT a DV camera * How new is the cable? If it is pretty old or you have kinked, it you may need another one * Is the camera in DV mode? It should be. (Usually in the menu options somewhere) * Have read ALL of Apples help topics on this If your good with all the above: 1. Close iMovie 2. Delete all iMovie plist files for iMovie located in Home/Library/Preferences 3. Plug the camera in to the wall (electricity) 4. Make sure you have a good firewire cable and plug it in to the Mac from the camera 5. Turn off your camera 6. Reset your pram 7. When the Mac is booting, power on the camera 8. Start iMovie Sony camcorder special fixs: 1. Turn your camcorder to Play mode. 2. Press menu button (or relevant touch-screen button) 3. Click the 'ETC' item and then to CONTROL. 4. Select i-link (and not IR). or 1. Turn your camcorder to Play mode. 2. Press the Menu button (or relevant touch-screen button) 3. Scroll down the Menu to the 'ETC' option, if there is one 4. Click the 'ETC' item and choose 'VIDEO EDIT' if it's there 5. Click 'VIDEO EDIT' and 'MARK 1 IN' may appear 6. Click on 'MARK 1 IN' and then exit from the Menu options, by pressing the Menu button again Your Sony cam should now work OK with iMovie. * Reason? The camera and Mac can't decide which device is giving the FireWire instructions, and which is supposed to be receiving and acting on them. Using this sequence (above) lets the camera receive instructions from iMovie.
Posted on Sep 14, 2005
Arpi
  • 326 Answers
SOURCE: sony handycam DCR-HC20 Screen blank on camera mode
Hello, please visit this link: http://www.imaging-resource.com/badccds.html contact Sony Service and claim for free repair. Best regards, Arpi
Posted on Aug 10, 2007
  • 169 Answers
the ccd image sensor of your camera is defective that why is no image you see..better go to sony service center for replacement of the sensor...
Posted on Aug 11, 2007
  • 73 Answers
SOURCE: drivers!
I THINK SONY WILL LET YOU DOWNLOAD DRIVER FOR FREE AT www.sony.com
Posted on Feb 23, 2008
SOURCE: Camera
I am assuming you meant your video (not just pictures) - you need a firewire cable - I have same camera - I use a firewire cable (4pins on each end) and connect to my IBM Laptop with Vista - vista does everything else to capture.
If you need to transfer photographs from the flash memory card -- I suggest the best way is to remove the flash memory card and use a USB flash card reader that you can hook up to your computer.
You may be able to do these otherways by installing the Sony software that comes with this camera - or can be downloaded from Sony website.
Posted on Jul 19, 2008
My Handycam shows a bluish screen(DCR-HC32E)
did you happen to drop the cam? there could be a technical error with the LCD screen. take it to the nearest Sony service center and have them take a look at it. you can try resetting the cam and see if it changes anything.
Jun 11, 2010 | Sony Handycam DCR-HC32 Mini DV Digital...
Sony Handycam DCR-HC32NTSC Play Back
Normally the touch screen should be activated, try removing battery to reset settings, if touch screen still does not work, then it is faulty.
Jul 28, 2008 | Sony Handycam CCD-TRV37 Camcorder
The buttons on my lcd screen does not work anymore. I tried calibrating it, but it just stays in calibrating mode as if it is not calibrating. this is for the DcR hc21
hi, if your lcd's touchscreen is not working only,then not to worry about just replace the lcd flap and its done,its very easyly avilable and easy to replace
Aug 25, 2009 | Sony Handycam DCR-HC32 Mini DV Digital...
I have a sony dcr-hc32 that when i turn it on i can see throuth the view finder but when i flip open the viewing screen there is no picture and the view finder goe's away. thanks
There is connecting ribbon wire between LCD board and Camera main board and this ribbon wire is cracked and needs to be replaced.
Let me know if you want to replace it at own to provide you part number.
Dec 11, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
Sony Handycam DCR-HC32 Not Working, Not Ejecting Tape, LCD Flicker
DCR-HC32 need new tape mechanism as shown in below exploded view.
Its part number is as follows..
A-1082-424-A MD (Z210) SUB ASSY
Nov 06, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
Connecting Lyd Model#203 mini-cam to Sony DCR-HC28 Handycam
The HC28 has a/v out only - whereas the HC32 has a/v in/out capability of which only certain models of camcorders have.
Oct 06, 2008 | Sony Handycam DCR-HC28 Mini DV Digital...
Dcr-hc19e & picture package menu & macromedia flash player
Here's were you need to go and updated the picture package version that you have.
http://www.ppackage.com/e/index.html
Apr 05, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
Sony handycam DCR-HC-32E records only in blue and red
the ccd image sensor is the problem of your camera....it have to be replace with the new sensor....i do not know if it is still free for replacing the sensor but the model of your camera is one of sony the recall product....because the ccd image sensor have a factory error..
Aug 01, 2007 | Sony Handycam DCR-HC32 Mini DV Digital...
Sony Handycam DCR-HC32 Mini DV Digital Camcorder Logo
59 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
