Question about Philips 9P5534C 55" Rear Projection Television
Need to replace tv lamp for phillips projector model 55PL9224/37
I need a diagram of the replacement of the lamp
2 Suggested Answers
  • 11 Answers
SOURCE: dull picture after even after i replaced the lamp
Sorry to say it but your so called Technicians don't seem to have a clue.
One person talks about adjusting the convergence which you can't on this set, besides the TV shutting off on its own have NOTHING to do with convergence.
All the answers given are the same...replace the lamp, replacing a good lamp will NOT fix the problem with this TV. I have the same set and it has the same issue.
None of your "Technicians" seem to know, they just pretend or come up with standard answers.
Posted on Mar 25, 2011
How do I change my projector lamp?
Instructions
  1. Front Projector
    • 1 Disconnect the power cable from your projector. Allow it to cool for 30 to 60 minutes. Lay the projector upside down on a table.
    • 2 Remove the lamp cover, typically located on one of the rear corners of the projector's underside. Depending on your projector, you will either have to loosen a few Phillips screws or press on one or two plastic release tabs to remove the lamp cover.
    • 3 Loosen the screws holding the lamp assembly in place. Grab the assembly by the handle and slide it out of the projector.
    • 4 Slide a new lamp assembly into the projector. Don't touch the glass on the bulb because it will damage the bulb. Tighten the retaining screws on the lamp assembly and replace the lamp cover.
    • 5 Turn the projector right side up and reconnect the power cable. Power on your projector.
    Rear Projector
    • 6 Unplug the TV from the outlet. Let it cool for 30 to 60 minutes.
    • 7 Remove the lamp cover. On most rear projection TVs, the lamp cover is located on the right or left side of the TV's rear panel. Remove the cover by loosening the screws and pulling the cover away from the TV. Certain manufacturers, like Mitsubishi, have the lamp cover in the front of the TV, near the left speaker. To get to the cover, you must first use your fingers to pry off the front panel below the screen, revealing the speakers and lamp cover. Loosen the screws on the cover and pull it away from the TV.
    • 8 Remove the lamp assembly. Loosen its screws, grab the handle and slide it out of the TV. If you have a newer Sony model, there are no screws. Instead, press the release tab to unlock the lamp assembly and slide it out of the TV.
    • 9 Slide a new lamp assembly into the TV. Don't touch the glass on the assembly, as the oils in your fingers will damage the bulb. Tighten the screws or pop the retaining tab into place.
    • 10
      Replace the lamp cover and front panel, if necessary. Plug your TV back into the electrical outlet and power it on.
Tips & Warnings
  • Touching the lamp assembly before it has cooled can cause a nasty burn.
Read more: How to Change a Projector Lamp ' eHow.com http://www.ehow.com/how_7307928_change-projector-lamp.html#ixzz1rpURlpva
Apr 11, 2012 | Office Equipment & Supplies
Need to remove bad lamp from the HC100 projector
1. Reverse the projector gently.
2. Loosen the screw (a) using a Phillips screwdriver (+), and remove the lamp cover (b).
3. Loosen the screws (c) using a Phillips screwdriver (+).
4. Pull up the handle.
5. Pull out the lamp box by the handle while holding the projector.
Pull the lamp box out of the projector slowly. If it is pulled out quickly, the lamp may break scattering
glass fragments.
Do not spill liquid on the removed lamp box or do not place it near any flammable object or where children
can reach to prevent injury or fire.
6. Load a new lamp box securely into the projector in the right orientation.
7. Put the handle back to the original position.
Make sure that the handle is locked.
8. Tighten up the screws (c) using a Phillips screwdriver (+).
9. Tighten up the screw (a) using a Phillips screwdriver (+) to secure the lamp cover.
Jul 20, 2011 | Mitsubishi HC100 DLP Projector
Have a 50 inch samsung projection tv model hlt5075sx/xaa lamp code bp9601653ap132w turn tv on lamp stays on for approx 20 seconds then 3 blinking lights on right bottom side start blinking if it is the...
The blinking lights will be flashing a code.....
Can you please indicate the sequence of the flashing lights, as this will determine what needs to be done to fix your fault.
Cheers,
Jun 16, 2011 | Samsung - Projection TV replacement lamp...
Projection lamp expired. how much is it to replace it?
you need the projector model number to find the proper projector lamp as not all projector lamps are made equal.
here are some sites you can find more information. just search based on your projector model.
http://www.projectorcentral.com/Sony-lamp-suppliers.htm
http://www.myprojectorlamps.com/
Projector lamps range from price. Low $100s to $300s based on the projector brand and model you have.
Mar 06, 2011 | Sony Televison & Video
Looking for replacement lamp for Sanyo PLV-WHD1 TV Lamp type # POA-LMP96 service parts # 6103227382. Need some help finding one that is compatible for reasonable price.
You can get replacment lamps for this TV from www.TvRepairKits.com
Models Supported = PLV-55WHD1, PLV-65WHD1, PLV55WHD1, PLV65WHD1 ,PLV-55WR2C, PLV-55WR2CH POALMP96 , POA-LMP96 , 6103227382. and more.
Feb 03, 2011 | Sanyo Genuine Original 6103227382 ...
We have a hitachi cpx260 projector. both the power light and the lamp light is red.
This usually means you need to replace the lamp.
1) To do this, power off the machine and disconnect the power cable.
2) Open the lamp compartment, and remove the lamp. You'll need a screwdriver for this. I recommend having both a flat-head and phillips-head as the screw on the compartment door and the screw holding the lamp in are not always the same type.
3) Replace with new lamp and fasten with screw.
4) Reattach lamp compartment door and fasten with screw.
5) Power on your projector and go into your menu.
6) Find the lamp timer setting and reset the timer to zero.
Oct 18, 2010 | Hitachi CP-X260 LCD Projector
Hitachi replacement bul
Let me know exact model of your Hitachi TV to check bulb availability in parts stores.
Bulb replacement is easy process and mostly it is written on owner's manual of TV.
Please use "add a comment" button to intimate model number of TV.
Thank you.
Apr 06, 2009 | Hitachi REPLACEMENT LAMP, Projector Lamp...
Projector
Check that you replaced the lamp in the right way, and also that the unit is well reassembled, you may also need to reset lamp counter from menu on some model.
Mar 07, 2009 | Dell 2300MP Multimedia Projector
Colour misalignment and focus
If you feel dull image and any yellow color problem you can change the lamp other wise no need to change the lamp.
There will be patten settings are there. so please inform service center service engineer will do this job.
Regards,
Prakasam
Feb 17, 2008 | Office Equipment & Supplies
Philips 9P5534C 55" Rear Projection Television Logo
190 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
