Question about Garden
Chain saw starts then dies shortly after
Poulan chain saw
  • geterdn Nov 26, 2008
    I had the same problem. I cleaned the carburetor and air filter but still had an issue.i found a broken fuel line from tank to carburetor.replaced it it started and ran but the higher the rpm`s it acted like it was starving for fuel.Further inspection showed i had scored the cylinder walls.I hope i have helped you,Your saw may not have the same problem but these are a few area`s to check.If you haven`t already.I had to purchase a new saw it was cheaper.
  • 211 Answers
Hi
I think you have a carburation problem.Carefully disassembly the carb and clean it.Check the fuel line and filter,the ventil of the gas tank.
regards savumihai71
Posted on Dec 02, 2008
  • sxgtutorials
    sxgtutorials May 28, 2013
    Hi, is it complicated to open carb, because I am not mehanich, sorry for my broken english, I am original from Croatia, but I belive I understand well english..
Chainsaw runs then dies
Carburetor needs to be overhauled and replace all fuel lines and fuel filter.
May 06, 2014 | Poulan Pro Chain Saw. 18 in. 42 cc Gas...
Poulan 2150 chain saw starts after priming and dies after a few seconds
Take the exhaust off so you can see the side of the piston, if it is scored or damaged it means it has probably been run without oil added to the petrol.
That can cause the problems you are having, if it is throw it away, its not worth repairing
Dec 14, 2012 | Poulan 2050 2055 2975 2150 2155 2175 Air...
My Poulan Pro 295 chain saw starts fine, runs for a few minutes, then stops and will not start until completely cool. What could be my problem?
It sounds very much loke the ignition is playing up when hot, just as a little test when it starts to die slacken off the fuel filler cap does it pick up/re start? if yes it is a fuel tank breather issue, replace the breather.
Apr 25, 2011 | Poulan Pro Chain Saw 46cc 20"
The saw starts and runs on fast idle but dies when you use the throttle? it,s a troybilt 18in saw
It sounds like it is flooding when you use the throttle, both are connected. Turn the idle back all the way until it dies, then try turning it a 1/4 turn the other direction.
Feb 19, 2010 | Poulan Pro Chain Saw 46cc 20"
Hi...I have a Poulan chain saw 2000. I can not
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/1b4ef1f00fa5e65888256bfa0019583f?OpenDocument
Did you replace the hoses? It only needs a pin hole. This is older than dirt! I can say that, I have a XXV. There should be an impulse line from the crankcase to the carb somewhere, it may be bad. Crank seals may be leaking. Maybe time to spring for a pressure diagnostic by your friendly local Stihl shop. HTH
Lou
Feb 05, 2010 | Poulan Pro Chain Saw 46cc 20"
Poulan Wild Thing starts great but as soon as I try to cut it die
The carb low idle needs to be adjusted this is fairly common among the Poulan chain saws. Once you adjust the low idle from factory setting it will work
Feb 16, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan chain saw won't stay running
Carburator needs to be removed and cleaned.
Feb 15, 2009 | Poulan Garden
Poulan chain saw after carb rebuild.
Is thereadjustment somewhere on the saw
I think there is 2 .
Feb 03, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
918 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
