My braun multimix hand held mixer used to have several speeds and now only has one which is the forward hold all the time position. I opened it up and made sure the ball bearings were in place but no change it what happens.... any ideas
    Problem Solver:
  • 5 Answers
I just fixed mine. My daughter dropped it (again) and speeds 2 and 3 failed to work so I disassembled it and found a broken center terminal on the power transistor. I saw a fine crack so I soldered it. I also added much needed strain relief to the heat sink. It works fine now. This is a poor design. The power device has a heat sink attached and there is no strain relief so the transistor can move back and forth at least 3/8". For a tool that sees a lot of vibration and shock, this heat sink should be tie strapped or have hot melt glue to prevent movement. Gary
Posted on Dec 31, 2008
Braun 4642 Mixers user guide
http://www.user-manual-pdf.com/appliance/handmixer/braun/instruction/braun-multimix-4642-handmixer.html
Nov 12, 2012 | Braun M880 MultiMix Hand Mixer
I can attach the immersion blender attachment but it does not turn on. The machine works fine with the mini-chopper attachment or the beaters. How can I fix this?
Hi
Make sure you use the pulse function of the power switch. Only this position (forward, away from you) will activate the immersion blender, and then at full speed only.
Feb 09, 2011 | Braun M880 MultiMix Hand Mixer
Once the blender is attached, how do you start the mixer?
You start it by pushing the switch lever forward, and you need to hold it there for as long as you want it to run. This is a momentary mode and is the only way to run the immersion blender.
Jan 18, 2011 | Braun M880 MultiMix Hand Mixer
Braun multimix won't run on 1st and 2nd speeds--only 3rd speed.
Hi.
This problem has been covered already on this link. Please leave a comment if further assistance is required and I will do my best.
Dec 10, 2010 | Braun M880 MultiMix Hand Mixer
Braun multimixer m880 the motor has finally died,
See
http://www.smallappliance.com/product.asp?pid=5623&cur=USD&sid=18956&mid=5&gid=18978&prdCls=P&PartsPaNu=1&shopBy=Brand
(2 pages)
And you will find spare parts online for your braun which i believe is model nr 4642 (se baseplate).
You may also use braun's own spare parts finder at:
http://www.service.braun.com/product/product.asp?rg=NA&c=US&l=GB&typ=pf&frmTyp=s&grp=0&s=4642&subgrp=&des=&sgrp=s&sString=4642'HH'HH06'H'MultiMix&seite=2
But you will have to contact one of the authorised service partners to buy.
Oct 14, 2010 | Braun M880 MultiMix Hand Mixer
How does one open the case of a braun multimix 220w - i removed the screw in the front, but something else is holding it together
You need to remove the base plate by carefully prying it open at the opposite end of where the electric cord is fitted. Then release the two halves working along the edges with a thin blunt object. Also carefully remove the sliding cover for the center power mixer outlet before separating the halves.
Jan 01, 2010 | Braun M880 MultiMix Hand Mixer
Bottom Slide Cover (Part 2a in the manual)
See the description for the speed problem and repositioning of the slidere at this link. The slider should snap back in place easily if everything is ok. The slider also operates a switch inside the mixer. This switch is intended to only allow you to run on full power when using the hand blender. You may need to open up the mixer to check this switch is not stuck in the activated position permanently. Otherwise consider the description of the speed problem in the link.
Jun 17, 2007 | Braun M880 MultiMix Hand Mixer
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
