Question about Sony NW-A1000 MP3 Player
SOund Interferance My 6gb version of the NWA 1000 is really crackly sounding through the headphones, and extra inteferance occurs if you change the volume or press the hold button? I have tried other headphones so it is not them. Could it be the connection where the headphone jack goes? or more likely something more terminal? Could the files just be poor quality etc? i transferred them via the enclosed copy of Connect. CHeers James
Mines done that as well. Sony want to charge me £70 to fix it.
Posted on Apr 10, 2007
I have a similar problem. If you put a bit of pressure on the top right corner of the mp3 player (i.e.: clamp it between a couple of your fingers) the sound becomes fine again. However, in my case, the problem eventually became worse, up to the point where I couldn't hear anything at all. I think you'll need to get it serviced to fix the problem. I'm sorry I can't help more than this. Adam
Posted on Mar 19, 2007
SOURCE:
What are the best studio monitor headphones?
It depends on whether you need a closed back or an open back headphone. I think the best sounding studio monitor is the new Sennheiser HD800S. It is an improved version of the venerable HD800. It is very accurate and detailed for monitoring and at the same time very enjoyable for music due to its musicality, depth of imaging, and expansive sound stage.
Visit this site for more instruction
http://www.musicskanner.com/best-studio-monitors-1000-dollars
Oct 20, 2016 | Audio Players & Recorders
No sound even with headphones
I would suspect that a lateral force has been applied to the headphone jack of your tablet. This occurs when you accidentally pull the headphone plug out at an angle instead of straight in line with the jack.
You might be able to find a repair shop to fix this. It might cost as much as the tablet. If under warranty you could try to get it replaced but Fujitsu is terrible in this department.
It is ALWAYS wise to get an extended warranty for consumer electronics. People tend to not do thi9s because they shop primarily by price and the extra warranty drives the cost up to high at the time of purchase. Then comes this kind of problem and you wonder why you didn't spend the extra 20 bucks.
Mar 01, 2015 | Fujitsu STYLISTIC M532 Tablet
Shows that speakers are not plugged in and there is no sound. What is the problem?
You may be able to access the ability to change audio settings through the control panel. There are choices that allow for choosing externally attached speakers. If the system does not know to send the audio signals to those speakers, then no sound will come out.
Feb 18, 2014 | Gateway DX4860-UR14P Desktop Computer;...
No sound coming from headphones using my dj mixer. however through speakers sounds fine. Im using 2 pioneer cdj 1000 mk3 and a djm 800. The sound works perfectly through speakers. how ever nothing through...
hii there, pls try to use another headphone on your mixer, if you get the same problem. It means your headphone have no problem. Problem is with the the jack of your mixture. Open your mixture and check the jack properly attached internal.
Dj Ajay
djajay@inbox.com
Nov 15, 2009 | Pioneer DJm600 DJ Mixer W/Sampler Black...
When I listening by headphone..the sound is bad..how to repair it
maybe its the headphones?
I had the same trouble, it went all crackly. I just got some new really cheap headphones, and it worked better.
Hope this helped.
x
Aug 11, 2009 | Toshiba gigabeat MES60VK Digital Media...
Speakers sound as if have background interferance
Hi Naomi. I am not sure of your model, but you probably have a build in mic. If so, open your sound properties from your task bar, Click on File - Advanced Properties. You should now see a "Mic" volume control. Mute this control and see if this stops the sound.
If this does not work, locate the manufacturer of your sound card and visit their website to download newer drivers, if available. If this also does not work, you will need to return the product to the retailer to reinstall a clean version of windows. Many times files become easily corrupt in the installation of audio codecs, drivers, etc. Hope this helps.
Apr 27, 2009 | Acer Aspire 5920-6335 Laptop
After using the headphone jack on the side of the TV, I've removed my headphones and there is no sound. When I connect the headphones there IS sound coming from the headphones, but when there is no...
try changing the sound output sometimes the tv will change to headphones only so you have so change it back to the tv speakers your owners manual should tell you how to do this
Apr 15, 2009 | RCA L26HD31 26 in. LCD HDTV
The Box Super - Sound interferance( Ireland )
you need to put the cable in the cable input connection . not the TVin as this does not need to be connected to the tv if you have a scart lead going from your box to the tv .
Dec 16, 2008 | StarTech.com StarView SV211K 2-port KVM...
I have it twice and the sound starts sounding bad...(Base)
might be your music EQ. can make your music sound really weird.
Feb 25, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sony NW-A1000 MP3 Player Logo
32 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
