Question about JVC AM FM CD DET FACE CAR STEREO
CANT ACCESS CD PLAYER MOTOR ON FACE IS STUCK
WHERE CAN I GET THE UNIT FIXED OR IS THAT POSSIBLE WHAT HAPPENS IS THE FACEPLATE IS MOTORIZED AND SOMEHOW STUCK BUT IF I TRY TO OPEN IT THE "MOTOR" CONTIUES TO RUN THE MODEL IS JVC KD-SH3899 PLEASE HELP
  • 199 Answers
Hi, sounds like a switch had become faulty, you will have to send to a repair agent.
www.blueice-electronics.co.uk
Posted on Nov 25, 2008
Kdc-x969, when the unit is tured on the face does not flip down. most buttons turn the unit off but the face flips down instead of up when it shuts off
It very well could be that the internal motor that moves the faceplate is going out or has already gone out. It sounds to me like that could be the problem.
Apr 12, 2011 | Kenwood eXcelon KDC-X969 CD Player
There is no display on the faceplate. The faceplate is stuck in the CD eject position. If I remove the faceplate the mechanism rotates to the position where the controls would be visible but when I attach...
I would try cleaning the connectors on the face plate with an pencil eraser and on the unit itself with a very fine sand paper. And make sure you get rid of any dust after cleaning before putting the face plate back on.
Please leave me a good feedback.
Thanks
Jan 06, 2011 | Kenwood KDC-8021 CD Player
I start up my panasonic sa-pt660 and it makes a lot of ticking noises and give me a chgr err. I tried restarting it. I also tried switching it to the radio and dvd player from the remote and the console...
OK I fixed it. One of the CD's had gotten stuck between trays in the loader. I pulled out a few CD's by forcing open the trays gently. However even after removing as many cd's as possible one was still stuck. 1. Remove screws holding cover plate on in back and sides. 2. Remove cover. 3. Lift face plate latches and lift over top of unit. Remove serial cables from face plate and place aside. Remove screws from back of CD tray unit and bend back metal tab with flathead screwdriver. Lift CD unit up on one side so you can get your fingers up inside underneath and push stuck cd towards tray openings. You can gently force top few trays out. You may need to shake unit so that stuck cd reaches open end. Pull out CD. 4. Replace faceplate and connect serial cables. Plug in power cord, power on unit and make sure trays will eject normally. 5. Put it all back together!
Oct 29, 2010 | Panasonic SC-PT660 Theater System
Unable to remove faceplate or eject cd on kenwood
remove the to of the unit, then the two in the actual cd player, pull out cd player, there will be two more screws,these hold the faceplate assembly in place, remove them. This will allow you to pull a small plastic hook down to let the face plate slide out. then remove the face plate from it's holder, slide it out. Remove the four screws on the back of the faceplate inside the there is a very small piece of plastic that has a hole at one end and squared at the other. This is the problem causing piece. I suggest super gluing this piece where it attaches to the inside of the faceplate. This should fix the problem.
Jan 17, 2010 | Kenwood KDC-516S CD Player
Display not working
I have the same problem. There's a little ribbon cable behind the contacts for the faceplate. It gets folded as the face plate motors in and out and eventually breaks like mine did. I'm fixing it tonight and then I will disable the motorization. Followed by NEVER BUYING A PIONEER AGAIN. I reccomend you do the same.
Aug 05, 2009 | Pioneer DEH-P780MP CD Player
Face wont open
if you have already tried hitting the reset button you should first remove the faceplate and check the contacts on the main unit and the back of the faceplate. if they are dirty clean them (with power off) with contact cleaner or a small eraser. if your lucky that will fix the problem but most likely you have a bad ribbon cable. this cable attaches the faceplate contacts to the main unit and flexes as the face tilts. after time these cables get small cracks that may not be visible. you can usualy buy the part from a place like pacparts.com and replace it to solve your problem.
Dec 16, 2008 | Kenwood KDC-MP528 CD Player
My Kenwood KDC-7024 has just started playing up - as soon as you turn on the ignition, the face panel comes down, flicks on for all of 2 - 3 seconds and then closes, it then keeps doing this repeatedly...
It's possible the flexible PCB (more of a cable, really) that connects the faceplate to the main unit has cracks in the conductors. This has been an issue with some of the older Kenwood HUs that have the MASK motorized faceplate. The flex-cable gets bent and pinched enough over the years that it eventually cracks the copper.
Mar 07, 2008 | Kenwood KDC-7024 CD Player
Head Unit going goofy
If the unit has a removable face take a pencil eraser and try shining up the little contacts on the back of the face and the radio. See if that cleaning helps.
Jun 18, 2007 | JVC Sirius KD-G700 CD Player
FS-SD5
Its a good possibility that the turntable that the cd sits on is pushed down or up from where its suppose to be as if the laser cant focus on the disc the motor wont spin.There could also be a bad spindle motor as these do go bad or the motor driver ic is defective. see if you can somehow see the lens when the disc is inserted if you can see the lens moving up and down it is one of thoses problems I described are the cause, or worse case is a defective laser Pick-up assy. Good luck. good luck
Apr 15, 2006 | JVC FS-SD5 Shelf System
JVC AM FM CD DET FACE CAR STEREO Logo
66 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
