Question about Acer AM5641-B5560A Desktop PC & Monitor BUNDLE
Acer AM5641 Desk-top PC
I have a problem with my Acer AM5641 desktop PC (obviously). The PC is pluged-in and the CPU can be heard processing, but nothing is is responding i.e the monitor nor mouse is responding to being pluged into the CPU the lights for each is not coming on. If the PC is booting up, I can not be sure as the monitor is none responsive. The components, that is the mouse and monitor works fine when attached to a differnt processer.
  • Loteck May 11, 2010
    Is your monitor good?
    Genius:
  • 1,913 Answers
When u power up the computer u heared any beep check then num lock if u abkle to num lock on and off your cpu is ok.then tv to cpu connection we have to check.
also press F8 key when u power the cpu then go to enable vga mode.
then change resolution to 800*600 or 1024 *768
Posted on Nov 24, 2008
Why my cpu fan stays on all the time
CPU fan is on all the time in computers.
Apr 20, 2015 | Acer Computers & Internet
Network interface card
Most any standard PCI NIC will work for you, as long as you have an available port on your PC. Here is one from newegg.com at a great price. It's a Rosewill and I've bought that brand often.
Rosewill RC 404 Ethernet Card 10 100 1000Mbps PCI 1 RJ45
Jan 28, 2014 | Acer Aspire AM5641-U5520A PC Desktop
How I can get recovery my acer am5641-b5560a?
Recover to original state using Acer eRecovery Managemet tool.
press alt+F10 during boot-up process.
This opens eReovery main page.
unless you have changed it, the password is six zeros (0s).
Click recovery actions.
Select RESTORE FACTORY DEFAULT IMAGE.
Once you've confirmed that you wish to proceed the computer will reboot and start to restore the system from the image contained in the HIDDEN PARTITION on the hard drive.
Oct 19, 2010 | Acer AM5641-B5560A Desktop PC & Monitor...
Acer AM5641-U5520A will not
If you removed the memory modules and there is no change then I would start disconnecting one device at a time to see if that is causing the problem. Start by disconnecting the cd/dvd rom and then try booting the computer. Then try disconnecting any floppy drives or pci cards(except for video card). If it has a pci/agp video card then you will need to remove it and test it in another computer or test a working one in the problem computer. If it has built-in video then you will need to test a working video card in the problem computer. It could also be an issue with the power supply so remove it and test it in another computer or swap it out with a known working power supply. Also check the mother board screws that hold the board to the chassi are tight(the board uses them as a ground). Blow any dust out of the case and verify that there are no loose connectors. Also verify that the monitor is not the problem by testing it with another computer. Usually when a CPU is defective the computer will not respond to anything and will act "dead" so it does not sound like the CPU. If everything else checks out then it could be a bad motherboard.
Dec 28, 2009 | Acer AM5641-B5560A Desktop PC & Monitor...
Acer AM5641 sound has stopped working
Yes definitely. Install any good sound card into a PCI slot. If you have WinXP Pro. as OS then it will automatically pick up the driver. If you are using Vista then buy a Vista compatible sound card.....sodeep
Mar 19, 2009 | Acer AM5641-B5660A Desktop PC & Monitor...
Intalling dvd drive on aver am5641
there are two different kind of connectors for drive compoonents such as dvd drives: ide and sata. most computers have both nowadays, though.
Jan 22, 2009 | Acer AM5641-B5660A Desktop PC & Monitor...
Acer AM5641-B5560A Desktop PC & Monitor BUNDLE Logo
316 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
