Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door won't open
My garage door won’t open – it raises about 4 inches and stops. When I disengage it and try to lift it manually it is very heavy and won’t stay up
If I engage it while it is open (up) the bolt will catch and it will lower but won’t go back up again – only raises 4 inches and stops
Any ideas?
  • 2 more comments
  • mary kay Nap Nov 24, 2008
    i tried that and still nothing - it just stops about 2 - 4 inches up - it doesn;t flash the chain will only go so far and i can't see anything that is stopping it
  • bpierce1011 Jan 15, 2009
    My garage door will remain open as long as I hold the remote or wall mounted door opener button down. As soon as I release the button, the door goes down. When I disengage the door from the chain, the chain can be driven to the open position in increments but when it gets near the top position, the chain reverses and goes to the closed position.
    Any ideas?
  • Anonymous Jan 18, 2009
    Can't open the door more than 4-6". Motor is working but seems to get blocked and goes back down. Manual won't budge it either. Can't see any blockage and chain seems OK.
  • mary kay Nap Feb 26, 2009
    yup that was it
  • 112 Answers
You probably have a broken spring on your door
Posted on Jan 18, 2009
  • 89 Answers
Hmm, Well i had said this earlier, But though i was retarded... lol. It MAY be the Grease lining the track, I didnt think grease could freeze, but im sure anything is possible... If not that then I have no clue, Maybe call the installers and have them come look at it.
Posted on Nov 24, 2008
Cannot open my garage door manually after I disengage it from the garage door opener (chain drive)
They are not light weight but there is no reason if the motor can raise it, then you cannot raise it by hand.
Feb 05, 2016 | liftmaster chamberlain 1/2 hp chain drive...
I have a craftsman 3/4 hp 315 mhz garage door opener model 13953990ds when ativating it to open it only moves 6 to 8" forward and back and stop. i have tried all steps in the manual can get it solved
If you've readjusted the opener, and it still isn't working, you need to have a trained door technician come out and adjust the tension on your springs. To determine this, pull the red release handle to disengage the opener from the door, and try to lift your door by hand. You should be able to move the door easily, and it should stay at the half open point without falling or rising. If the door is hard to move, excessively heavy to lift off the ground, or will not stay open, the door itself is the culprit. If the door is fine, the opener will need to be serviced.
Sep 02, 2013 | Sears Craftsman LiftMaster Chamberlain...
I have a panel lift garage door which is automated. The door will travel about 10% when closing then auto reverse. The panel appears to be binding when I am unable to find out where it is binding.I have...
The door must manually open and close without binding before the Automatic portion will work. The Automated door opener is designed to close or shut off when a bind, or excessive draw on the motor is detected. This prevents the motor from burning itself out when stuck. I would disengage the motor until the door raises and lowers with ease, manually. I also recommend you have a helper when attempting to find this bind, and repairing it.
Apr 10, 2011 | Garden
Our garage door will not open all the way. Up until yesterday it worked fine. Then when I came home from work and pushed the button to open the door, the door raised up about 3 inches and stopped. I pushed...
You have either a broken door spring or the drive gear in the motor unit is bad. The drive gear is a white nylon gear just in front of the motor and it will be obvious if it is bad.
Nov 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 125OLM will not open, even manually. The motor seems to be working. The chain goes around and it seems to engage, but then the door barely goes up (1 inch, maybe) 1/2 to 1 inch off the floor. ...
If you can't move the door manually with the lift disengaged, it is most likely the counterbalance spring has failed or slipped. Other problems would be stiction in the tracks or a stuck lock that should be disabled for a lift.
Jun 12, 2010 | liftmaster Chamberlain Garage Door Opener...
Craftsman 1/2 HP garage opener opens only 6 inches
Remove the cover and check the drive gear. It is white nylon and is just in front of the motor. It may be stripped. Take a close look at those door springs. They can sometime appear to be okay when one is broken.
Oct 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door went up about 6 inches and stopped. Door can be raised and lowered by hand without without disengageing it. Inside garage control only produces a clicking sound in motor area when pressing pad....
Remove the cover and check the drive gear. It is white nylon and is just in front of the motor. Most likely stripped. The part number is 41A2817 and is available at any good door service company. It comes with instructions but you must be a DIY'er.
Oct 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
My 1/2 hp Chamberlain garage door stops while going down even when I am holding the wall unit. If I stop it and restart it goes a little further and then stops. Both sensors have green lights and they are...
On the back of the motor unit you will find the down force control. You may have to remove a light lens depending on your model. Increase this a 1/4 turn and try.
May 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,150 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
