Onkyo AV Receiver TX-SR 805 no display on the receiver
Somehow the receiver is working but it does not display anything on the display pannel.
  • 6 more comments
  • Anonymous Dec 07, 2008
    no display on the front panel of the receiver
  • Anonymous Jan 06, 2009
    Onkyo 805 - front display doesn't work
  • Anonymous Jan 11, 2009
    no display
  • jgolbois Jan 19, 2009
    The receiver seems to working fine, the display just doesn't work. Anybody have a solution other than contact Onkyo?? Other than this, I love the receiver.
  • markdesilets Feb 19, 2009
    no display on reciever but works otherwise
  • Anonymous Feb 24, 2009
    same problem started tday!
  • kerby2000 Feb 28, 2009
    It seems that many people have the same problem.
    For me this started today.
    Please let us know if you have a solution.
  • Anonymous Mar 08, 2009
    Had a power blackout and same thing happened when the power returned. :((
Finally one of us found the solution - thanks to cambrian
Please follow the link
http://www.avsforum.com/avs-vb/showthread.php?t=857502&page=579
BTW: My knowledge of electronics is very limited, but nevertheless I could fix the problem. I hope you can do it too.
Posted on Mar 12, 2009
  • Rick Avra Oct 26, 2015
    Thanks for the pointer - it worked for me too.
    Cambrian: thanks!
Thanks to Cambrian and you who gave direction to the thread which contains his recommended solution, I have also quickly repaired my 805 with the replacement of just two 10 Ohm resistors. Many thanks!
Posted on Oct 24, 2011
I followed the link above and it worked perfectly. Actually, you should use the page before which is this page http://www.avsforum.com/avs-vb/showthread.php?t=857502&page=578. Scroll all the way down almost to the end to see the "805 display tutorial". I went through my stock of resistors and found 2 10-ohn 1/2 W so I used them instead of the 1W that author recommended and they worked fine. This gentleman Cambrian is more than a genius, he's a Godsend ;)
Posted on Sep 06, 2009
Onkyo TX-SR 805 flashes message "Test - < - 42" when switched on at power button.
Hello, you seem to be in technician test mode. Unplug the receiver for an hour, turn on and perform a reset by holding vcr/dvr and then on/standby. This should resolve your issue. Thank you, Onkyo USA
Mar 01, 2017 | Onkyo Televison & Video
How to fix Onkyo TX SR 303 when it says phones engaged but no phones are not plugged in
Hello, I suggest a reset of the receiver. Please see the procedure below. Thank you, Onkyo USA.
To reset the AV receiver to its factory defaults, turn it on and, while holding down the [VIDEO 1/VCR] button, press the [STANDBY/ON] button. "Clear" will appear on the display and the AV receiver will enter Standby mode.
Feb 28, 2017 | Onkyo Audio Players & Recorders
How do I hook up my iphone 5s to my Onkyo TX-8511
You can use a DS-A5 iPod docking station or a RCA Y-adaptor found at retailers such as APPLE, BEST BUY, RADIO SHACK, AMAZON, etc.: http://www.amazon.com/APPLE-COMPOSITE-AV-cable-ZML/dp/B004EWEX9Y/ref=sr_1_1?ie=UTF8&qid=1331155139&sr=8-1You can use a DS-A5 iPod docking station or a RCA Y-adaptor found at retailers such as APPLE, BEST BUY, RADIO SHACK, AMAZON, etc.: http://www.amazon.com/APPLE-COMPOSITE-AV-cable-ZML/dp/B004EWEX9Y/ref=sr_1_1?ie=UTF8&qid=1331155139&sr=8-1 . Connect from the headphone port of the iPhone and use the red & white RCA audio cables to connect into the RCA audio input terminals of your TX-8511.
Jan 02, 2015 | Onkyo TX-8511 Receiver
Bose 901 hookup with Onkyo SR 805 and Onkyo M282 amp and 901 EQ/
The good news. I have a setup similar to what I think you're trying to do and it works great!
The Onkyo M-282 stereo amp for the 901's is the perfect solution. Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
**Onkyo SR805 Pre-Out Front >>> Bose EQ Amplifer IN
Bose EQ Amplier OUT >>> Onkyo M-282 IN
Set the Input Level on the back of the Onkyo to MAX. The receiver controls everything just fine after you run through your level setup routine again.
I was looking a the 12v triggers on both units and it looks like you only have a Zone 2 trigger so that wouldn't work for turning on your M-282. I guess you're going to have to turn it on and off the old fashioned way, like I do mine.
Mar 15, 2009 | Onkyo TX-SR705 Receiver
Hi I have an Onkyo TX-SR875. The AV receiver display panel has gone, so I reset it to factory defaults to see if it would bring it back - it didn't. Worse can't now see the on-screen setup menu to setup...
This is a common problem on onkyo receivers like the 805, 875 etc. The front panel display board has 2 faulty resistors(marked 9304 & 9310) which can blow out easily. Replacing them with some very basic soldering, resolved the issue for me.
View this link on the AVS forum for detailed instructions .
Look for the post titled "805 Display fix"
Dec 06, 2008 | Onkyo TX-SR875 Receiver
Onkyo TX-SR805 - surround sound problem
The speaker impedance is not the problem.
Apr 09, 2017 | Onkyo TX-SR803 Receiver
No video through HDMI section of Onkyo TX SR-805 receiver
My has problems with losing video on HDMI, component, or svideo, this is a piece of you know what!
Jul 03, 2008 | Televison & Video
Onkyo TX SR 702 AV Receiver
don't run you video from the projector to the reciever. just run it to the dvd and run the sound from the dvd through the reciever
Jun 01, 2008 | Onkyo TX-SR702 Receiver
Subtitle Problem: Onkyo TX-sr605
The only remote that will definitely turn the sat subtitles on/off is the sat remote. The other subtitle buttons on the other remotes refer to the DVD subtitles and the subtitles generated by the tuner in the tv. The subtitle option is greyed out on the tv because you are not on the tv tuner.
Sep 03, 2007 | Onkyo TX-SR604 Receiver
3,868 people viewed this question
 Grubhead
Grubhead
