Question about Memorex MT1134 13" TV
TV ON SCREEN DISPLAYS (A/V) ONLY
13'' SPHERE MEMOREX WHEN TV IS PLUGGED IN PICTURE COMES ON IT ONLY DISPLAYS A/V. VOLUME NUMBERS 01234 will display channel numbers will not. is there any way to get into TV MENUE SET UP BY THE BUTTONS ON FRONT OF TV. LOST THE REMOTE BOUGHT 2 NEW PHILLIPS NEITHER WILL TURN TV ON OR OFF. (2002 MSP TV 1300) MAROON. THANKS FOR ANY HELP AND HAPPY NEW YEAR..
  • Anonymous Mar 10, 2009
    i have the same problem.
SOURCE: memorex tv programming
I am trying to start remote ucr3110B00 on memorex MT 1120A please help me.
Posted on Dec 30, 2007
SOURCE: Memorex M2024 20" color tv
set to cable mode
Posted on Jan 12, 2008
johnychel
  • 796 Answers
SOURCE: memorex mt2024 "A"
try here
Posted on Feb 10, 2008
SOURCE: Memorex mt2024 TV turns on for 5 secs
What's probably happened is that we have all suffered a static discharge that has probably erased some programming. All it took for me was a dusting of the front screen and, zap, a spark flew into the power button. I will not rule out some electronics has been destroyed, but erasing flash is, I think, a more likely scenario. If so, given the right equipment, this would be easy to fix. However, it is more than likely this procedure is out of the question for any repair shop. For starter, where are they going to find the necessary images to flash the TV (given what I said above is actually what happened). It is likely the only place this can be done is where they manufactured the TV. Add to that, if they have stop production of this particular model, even "your buddy on the factory floor" would probably be hard pressed to find the correct files / images. Assuming all above is true, which is getting harder (even for me) the more I type, the only reasonable solution would be to obtain a working TV and copying the image. But even that may be difficult as many contemporary processors have ways to thwart reading their contents.
Let's see, $90 TV + $5 recycle fee / year... not really that good... probably will not buy a Memorex again...
Posted on Apr 08, 2008
  • 71 Answers
SOURCE: Memorex television is not working with my new Phillips DVD/VCR combo
depending on how you hooked it up; if thru coax cable the you have to use channel 3 or 4 on the tv to use Philips. If you are connecting with video and audio cables then you have to select a/v input on tv to use.
Posted on May 08, 2008
How many 1 inch balls will a 10 inch sphere hold?
volume of 10" sphere is 1000 ties that of a 1" sphere (volume scales as the cube of linear dimension). The close packed fill-factor for spheres is 0.74 (see eg http://en.wikipedia.org/wiki/Close-packing_of_spheres). Thus you will get LESS THAN 740 1" spheres into a 10" sphere (quick calculation neglecting edge effects, which is why 740 is only a bound, not the actual number)
5.August.2014
Aug 05, 2014 | Cars & Trucks
How do I determine the open space in a 12" cube
Determine the volume of the cube
Which is calculated by:
length x width x depth
then subtract the volume of the sphere's
Number of spheres multiplied by (4/3) * pi * radius3
To figure out how many sphere's you can fit in the cube
Divide the width of the cube by the diameter of the sphere then cube that number
(try it with a larger diameter sphere for example 6" sphere and sketch it out, you will see why)
0.01" Sphere-Total Volume
12"/0.01"=1200
1200^3 = 1.728 E 9 = Number of sphere's in the cube
1.728 E 9 x (4/3) * pi * 0.0053=904.32 cubic inches
Volume of Cube = 1728
Remaining Volume = 1728-904.32 = 823.68
You should be able to figure out how to do the other one.
Jun 18, 2011 | Sharp Office Equipment & Supplies
My TV seem to be on wide screen and it shows half the picture, how do I set it up on full screen? No other material is connected to the TV
Hello
If your TV displays a black box type shade on the screen means that your TV may be set to "Text" mode. To clear the screen, select "Caption Off mode".
To do this, press "MENU" button to display menu functions on the screen. Press "channel up or channel down" button to select the function "CAPTION". Press "Volume Up or Volume Down " button to select the mode you wish. There are five modes that you can select; Caption-Off; Caption-C1; Caption-C2; Caption-T1 and Caption-T2. As no other matereial is connected to your TV, you just select "CAPTION-OFF". When done press the Menu button again to exit menu display. Ok.
Oct 22, 2010 | Durabrand DWT1304 13" TV
How to remove the menu display off the screen memorex tv
you can use your remote control to remove the menu display,there is a button there,labeled OSD or DISPLAY just press the button to remove the display..
tnx please vote for my help..
Jun 04, 2010 | Memorex MT1134 13" TV
My tv starts up normal displays a picture for about 3 seconds and goes black with only sound coming from it
back lights are going out if you get in the right light and look verry closely at screen you will see picture . if you do the backlights are going out probly the inverter boards
Feb 03, 2010 | Memorex MLT1921 19 in. LCD TV
The memorex brand icon comes on briefly when i turn on the set
Try the link.It may help.
http://www.devicemanuals.com/guide/Television/Memorex/Memorex-MT1134-13-Color-TV-with-front-A-V-jacks-T1RJMU5UTT.html
Jun 01, 2009 | Memorex Televison & Video
Can't get time and day display off screen
With the MT1192 Memorex set, it's the RECALL button on the remote that toggles it on and off the screen.
Nov 11, 2008 | Memorex MVT2135 13 in. TV/VCR Combo
Clock display
Try pressing the "recall" button on the remote; not intuitive, but worked for me.
Nov 08, 2008 | Memorex MT1131 13" TV
No picture and signal on tv
I have satelite on my tv and everthing is connected but the tv have a no signal across the screen. What do I do?
Sep 10, 2007 | Memorex MVD2113 13 in. TV/DVD Combo
Memorex MT1134 13" TV Logo
114 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Steve Allison
Steve Allison
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
