Question about Dell Inspiron 1300 Notebook
Inspiron 1300 will not boot up
When I turn it on it says "Loading PBR for descriptor 2.
Then says a disk read error occurred press ctrl+alt+del to restart.
The disk most likely does not have an OS on it any more.
It was exposed to a very powerful magnetic field.
Is my HD toast, will a new HD solve this problem?
  • 1 more comment
  • tomangley Nov 25, 2008
    Thanks for the ideas. However my XP system is no longer installed there is nothing on the drive. It says loading PBR For Descriptor 2. After that mesage it say to reboot with the 3 finger salute and freezes there and I can not do anything but the salute. I tried f8 and nothing happened. I can't get into bios to change boot sequence it requires a password and I don't have it. I bought it used and was not given it I called DELL and they wouldn't give me a password. If I install a new hard drive will I be able to reinstall XP even though I can't change to boot from cd?
    Ok I have one last question and problem.
    Problem: I can not get past the password from the previous owner or the DELL password. I tried all suggestions in previous input.
    Question: Before I by a new hard drive and install it. Will it boot up at least to some form of DOS so I can run the CD drive? Or will it boot from the CD driva after it attempts to boot from the HDD?
    As I said I could not get past BIOS password and could not change BIOS to boot from CD Drive. The boot order is HSS then CD drive.
    Will it try the HDD first then go to the CD Drive?
    Thanks for helping me with my problems all feedback is appreciated.
  • tomangley Nov 28, 2008
    Thanks for all your help Problem solved.
    Problem Solver:
  • 15 Answers
"Bad PBR" means the partition boot record the MBR is trying to load has an invalid sector signature.
Right before that message, you should see something like "Loading PBR for descriptor 2". That will tell you which PBR the MBR is having a problem with--descriptor '1' is the Dell Utility partition, '2' is the XP partition, and '3' is the Dell Restore partition.
First, make sure that all connections are secure.
If no luck and it uses Windows XP, then press the F8 key during startup, select Safe mode from the menu using the arrow keys, and press Enter.
If it starts in Safe mode, then do a clean boot to find the cause:
http://support.microsoft.com/default...b;en-us;310353
If it does not start in Safe mode, then restart, press the F8 key during startup, and select 'Last Known Good Configuration'.
If still no luck, then press the F2 key during startup to get into Setup(try the Del key if F2 does not work), and make sure the CD drive is configured to boot ahead of the HD.
Then, insert the Windows(or Recovery) CD, restart, and follow the steps shown here to access the Recovery Console, and do a FIXBOOT(writes a new partition table to the HD)-> http://www.webtree.ca/windowsxp/
If that does not fix things, then do a FIXMBR(repairs the HD's Master Boot Record) using the same above procedure for a FIXBOOT, except substitute FIXMBR.
If still no luck, then you may have to do a repair install as described in the above link(Follow the steps for having an OEM version of XP).
If no good, then do a fresh install of XP(You will lose all data, restore points, and updates).
If there are problems doing that, then either the HD or RAM may be bad.
Posted on Nov 24, 2008
  • 53 Answers
Hiiiiiiiiii ther
how r u ???
1st the magnitic field toast ur HDD so new HDD sure will solve the problem
but 1st u must make sure that the HDD is toasted
try to use under DOS HDD editing soft wear {like acronics for ex.} and see if that read the HDD
if not than try to boot from CD and try to make a low leve format
if this didn't work i guess ur HDD is tosted sorry
and about the password to the bios
to rest a bios password ther is some methoed to do so
1 useing something called back door bios password {so u can try those r Award backdoor BIOS password for dell -- dell, eight spaces,01322222, 589589, 589721, 595595, 598598 , ALFAROME, ALLY, ALLy, aLLY, aLLy, aPAf, award, AWARD PW, AWARD SW, AWARD?SW, AWARD_PW, AWARD_SW, AWKWARD, awkward, BIOSTAR, CONCAT, CONDO, Condo, condo, d8on, djonet, HLT, J256, J262, j262, j322, j332, J64, KDD, LKWPETER, Lkwpeter, PINT, pint, SER, SKY_FOX, SYXZ, syxz, TTPTHA, ZAAAADA, ZAAADA, ZBAAACA, and ZJAAADC.} what you see listed may not be the actual backdoor BIOS password, this BIOS password may simply have the same checksum as the real backdoor BIOS password
2 resetting the bios password useing softwear {so u can use this softwear CmosPwd -- http://www.cgsecurity.org/wiki/CmosPwd }
3 resetting the bios password useing hardwear { and that's simply by takeing off the motherbored battery for some time up to 30 mins }
and if u need any further assistance email me
u take care and have fun
salammmmmm {bye in arabic }
p.s rate me thanks
Posted on Nov 25, 2008
  • ayman farag
    ayman farag Nov 26, 2008
    hiii ther
    how r u ??
    1st ur problem
    u say u did all the 3 method i told u and nothing solved :D
    i guess u jst tryed the back door password
    but the hardwear fix must solve it :D
    2nd ur Q
    and yes it will boot up 1st from the HDD but cos it's empty than it will go to the 2nd boot on the list in bios
    and i guess is it the defult it will be the CD
    so don't worry
    p.s rate me thanks
"A disk read error occurred Press Ctrl+Alt+Del to
Most likely the hard drive is failing, run diagnostics on the hard drive if you have a resource CD. Or you can download them from support.dell.com
Jul 21, 2011 | Dell Latitude C810 Notebook
Screen says" Loading PBR for descriptor
And again and again and drives you up the wall.OK-boot sector is corrupted, or hard drive is going south.What you can try is system restore.On boot see which button is designated for that-usually f10 or f12.Start tapping that button and follow instructions. If that failed, the only option is to reinstall OS.If you have a lot of stuff that you want to save, install Windows in different folder, say WindowsA.All your stuff will be saved on the Hard drive-My Documents.Good luck and keep us posted.
Jun 14, 2011 | Computers & Internet
I have a inspiron i1011-26600bk and its telling me a message that says Loading PBR for descriptor 2...done. What should I do?
"Loading PBR for descriptor 2 ... failed" would be the exact error message if the MBR is unable to load the partition boot record for the second partition. There may be more, but here are three possible causes:
1) the partition table is corrupted so that the descriptor points to the wrong place (i.e., says the partition is one place when it's really somewhere else);
2) the partition table descriptor points to the right place, but the boot record there is corrupted or has been erased;
3) The hard disk is failing and having trouble reading the sector with the boot record.
To check (1), visit www.goodells.net/dellrestore/fixes.htm and download the dsrfix utility. In short, if dsrfix reports a clean bill of health, then (1) isn't the problem.
To check (3), run hard disk diagnostic tests. Press F12 when the machine is starting and see if the bios boot menu offers you a hard disk diagnostic test that you can run. Or even better, if you know the brand of the hard disk, most manufacturers should have a free diagnostic utility you can download to test the hard disk.
If it's not (1) or (3), then use Ctrl+F11 to run the Dell restore utility to recreate the Windows partition.
Mar 12, 2011 | Computers & Internet
I have a dell inspiron 1300 and I accidently shoot down the PC during the runing program when I restarted again what I get just a black screen and a message Loading for PBR for descriptor 2 ...done. I...
Start the PC and run diagnostics (Fn + Power) then run the hard drive diagnostics. If this fails then chances are the Hard Drive has errors which probably means you would be lucky to get your file back Im afraid.
Sep 08, 2010 | Dell Inspiron 1300 Notebook
A disk read error occurred press ctl+alt+delete to restart
May I know whether the Hard Drive is listed in the BIOS? Try reinstalling the Windows using the Windows OS disc.
Jul 04, 2010 | Dell Inspiron B130 Notebook
Loading PBR for descriptor 2... MODEL DELL DV051
That is the boot loader message to boot to the NTFS Primary boot partition (Primary Boot Record for Descriptor 1 is the Utility partition)
Normally, this message flashes and the system boots, since it is not there is a failure in the boot process.
#1 run diags on the Hard Drive (CTRL+ALT+D at boot) and see if it passes
If it does
#2 Boot to you XP CD, press R for recovery console, and run the COMMAND CHKDSK /R see if the system will boot
If no go, go back to recovery console, try the command BOOTCFG /Rebuild then see if the system will boot
If That fails, try reinstalling Windows
If Diags Fail or all the above fail, replace the hard drive
Jun 24, 2010 | Dell Computers & Internet
First freeze, then boot slow, then boot "PBR 2 ...done, then disk read error Ctrl Alt Del to contine..., now no screen at boot up....fried???
The problem is with the corrupted boot files .In my opinion you have one solution
Steps for solution
1. Download an operating system called ' Linux mint ' which can be installed in the pen drive having minimum 4 gb capacity . Using this operating system you can access the computer .
2. Copy the file and folders to an external storage device (external hard disk, pen drive etc..)
3. Reinstall the operating system ( XP,Vista ,Window 7,Ubuntu etc )
Hope you be successful
Mar 11, 2010 | Dell Inspiron 6000 Notebook
Computer will not re-boot
your hard drive has been corrupted due to improper shutdown
Oct 07, 2009 | Dell Dimension 3100 PC Desktop
Boot to the Diagnistics FN+POWER at boot, run hard drive diagnostics. The PBR Descriptor 2 message is part of the normal boot process (directing the boot loader to Primary Boot Recond 2, the C: Drive) but usually flashes on an off so fast most people never notice it. Since the boot process is not going past the re-direct it is indicative of a bad hdd (Since the re-image process crashed)
Most likely you are looking at a hard drive replacement.
Regardless you are going to need an XP CD (you'll have to reinstall windows or run recovery console at a minimum)
Apr 01, 2009 | Dell Inspiron 6400 Notebook
Not going in window xp
You will have to try and boot from the Operating System CD and Run a Check Disk
from the repair utility chkdsk /r/f/p or try a factory restore on boot Press and hold: Control key + F11
Nov 17, 2008 | Dell Computers & Internet
Dell Inspiron 1300 Notebook Logo
999 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
