Question about Brother HL4040CN Laser Printer
Brother HL4040CN Error Msg E1 ''Print Unable Turn off and on''
Turning off and on results in the same error message. The LCD display is red.
1) Is this something I can fix myself?
2) How do I fix it?
2) Can it be fixed?
3) Worth taking to brother to have it fixed (just past warranty period)?
The brother web site says to:
Power off the printer.
2. Wait 5 seconds.
3. Power on the printer.
If the error continues, the printer would need service.
  • dnaath Feb 17, 2009
    I have a BROTHER HL-4070CDW and I've got the exact same problem when trying to get into the LAN setting. The display turns RED and says UNABLE PRINT E1.  The printer is brand new less than 2 days old. Cannot get ANY help.
  • dorothydumpl Mar 04, 2009
    Just started happening. Have turned it off and on three times. Any luck?
SOURCE: Error message ''Unable to Print 4F''
How to repair error "print unable 4F" in the Brother dcp-135c .
thank alot.
Posted on Jan 14, 2009
komguy
  • 2306 Answers
SOURCE: I get error message Print Unable E1 for my brother
E1 is called a program error, asking the printer to do something it thinks it can't. Could just be a print that uses a lot of memory, if you don't have the extra memory installed. The manual just says to power off and on again, but I would also look at what you are trying to print and try another job.
Posted on Aug 28, 2009
  • 31 Answers
SOURCE: Brother MFC-665 CW with "unable to print 4F" error
My MFC 665CW popped this same "Unable To Print 4F" error recently making the machine fully useless. Just an annoying triple beep and repeat error message to screen when trying to do anything at all with it. I wrote Brother about it. They said to check all through the machine (with a light) for any paper torn off inside, or unwanted foreign objects. This is a good step to do anyway to help maintain the printer. If that is not it, they said it would be a mechanical malfunction. I tried "resetting" by unplugging it for a while as they suggested to no avail. Also while I did find a bit of paper torn off down in my MFC 665 removing it had no effect.
Posted on Oct 22, 2009
cene765
  • 787 Answers
SOURCE: error message one brother mfc-5440cn
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number
is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the
annoying cannot clean message.
Posted on Oct 28, 2009
pineworks
  • 4041 Answers
SOURCE: brother mfc5860cn has error message print unable - 4F
Hi there
Please try this.
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
HL-L8350CDW series Unable to print 0A. How do I fix this?
"Print Unable 0A" indicates that a hardware malfunction has occurred.
- If the error message is "Print Unable ZC", refer to: "Print Unable ZC"
1. Power the machine off by holding down the power button. Wait a few seconds and then power the machine back on.
-If no error message appears on your machine's display, go to Step 2.
- If the error changed to "Self-Diagnostic" on your machine's display, contact brother for warranty service.
-If "Print Unable 0A" returns, contact brother for warranty service.
2. Leave the machine with power ON for 15 minutes.
- If "Self-Diagnostic" or "Print Unable 0A" returns, contact brother for warranty service..
WARRANTY AND SERVICE OPTIONS.
Brother Authorized Service Center locator
Jan 12, 2018 | Office Equipment & Supplies
I have a brother's MCF-255MC printer and i keep getting the message unable to clean 50 I followed the steps in the manual and it still didnt work could you please help me?
How do I clear the message "Unable to..." or "... Unable" ? ' Brother
support.brother.com/g/b/faqend.aspx?c=gb&lang=en&prod...eu_as...
Aug 18, 2014 - Unable to Clean (Clean Unable); Unable to Init. ... If the encoder gets markings or debris on its surface, it may cause other problems.
Brother Unable to Clean 50 Error - YouTube
? 0:51
https://www.youtube.com/watch?v=8THfCUgYCMU Jun 9, 2015 - Uploaded by Aceh Com
Printer Brother Unable to Clean 50 Error Cara mengindentifikasi Printer Brother Unable to Clean 50 ...
Clear the "Unable to Clean" Message ' Brother MFCJ4510DW ...
? 1:49
https://www.youtube.com/watch?v=EH3CEA3WbEY
Aug 2, 2013 - Uploaded by Brother Office
Yeah, keep it ... Clear the "Unable to Clean" Message ' Brother MFCJ4510DW, ... assistance, please ...
Printer is displaying unable to print/init/clean 50. Have referred
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting Get a Professional Answer ... Have referred to brother manual and there is nothing jammed in the machine. ... To attempt to resolve it, do the following steps created by Brother in this step by step guide to try resolving the error message: ... Unable to init, unable to print, unable to clean, unable 36, error 46, 50 and error 32 are ...
I am getting error:unable to clean 50, was unable to print - JustAnswer
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting I am getting error:unable to clean 50, was unable to print - Answered by a ... What is the exact model of your Brother printer? ... For example, MFC-615 ... it is not allowing me to press any thing, I keep getting a beeping noise when I press .... How do I remove error messages, epson wf-2750, PC MS10, I 8/12/2017 8/12/2017.
brother MCF 255MC printer message unable to clean 50 Google Search
Aug 14, 2017 | The Office Equipment & Supplies
Cords got ripped out of system then i plugged it in and its blinking then flashing yellow and turning off
Welcome to Fixya
YLOD or yellow light of death (indicated by the flashing yellow light). When you are Experiencing Problems with the PS3 like this you mainly have 2 options to take.
Option 1
Send The PS3 to Sony
Almost all problems with the PS3 Sony can fix easily if not they will send you a refurbished model.
Price:
If your in warranty they will not charge you for this repair/replace.
If your out of warranty the Charge will be $150
Waiting Time:
4-6 weeks
Sony Contacts right here
Option 2
The PS3 Repair guide
When your suffering problems with the PS3 its often easy enough to fix it at home with a good ps3 repair guide. There famous for fixing major problems like:
The YLOD - Yellow light of death/ Red light error
The Disk Read error
The Hard disk Corruption error
The Red Screen of death - Serious error
PS3 Freeze up Error
PS3 No Signal Error - no display
FIX All error messages
But not everyone knows they can fix simple settings problems like all error messages and the no display error, av and hdmi screen problems and more.
Price: averages between $40 - $60
Wait time: instant download and repair within 2 hours
I really hope I provided you information to fix your problems with the PS3 and get back to gaming soon as possible.
Thanks!
Mar 07, 2011 | Sony Playstation 3 (PS3) Console
Hello my problem is in xbox 360 elite e 73 one light red
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 28, 2011 | Microsoft Xbox 360 Console
I have an xbox360 I had almost a year I went to switch it onan a red light apear and tells me to go to xbox custemer care E37
Jan 21, 2011 | Microsoft Xbox Console
Xbox-360 elite lower right hand red flashing led light code error E73
Jan 17, 2011 | Microsoft Xbox 360 Console
Someone plugged there xbox 360 HDMI cable into the USB port in a laptop. Now they get a E74 and 1 red light lower right side . What can they do now.
Jan 14, 2011 | Microsoft Xbox 360 Console
I am having a problem with my xbox360. a single red light problem and also in game,picture gets blurred and pixels gets stretched....help
Jan 08, 2011 | Microsoft Xbox 360 Console
Print unable 32 error message
The message "Print Unable 32" or "Machine Error 32" will appear on the LCD display if paper or labels are stuck inside the printer or drum unit.
Follow the below link to fix Print unable 32 error message on Brother MFC-9840CDW Laser Printer
http://tinyurl.com/print32
All the Best...
Dec 09, 2010 | Brother MFC-9840CDW Laser Printer
Brother HL4040CN Laser Printer Logo
3,455 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
