Question about Mitsubishi VS-5043 50" Rear Projection Television
Possible Convergence Hi, my 1997 VS-5043 will not stay locked in when doing advanced or 1st time setup convergence. The blue and the red both drift and the picture has a slight bow or curve. I have both the front and rear off the set and have lightly tapped around with a small wooden stick. I notice the 3 IC's to the right of the convergence module secured to a heatsink,and have read that these go bad. If they are defective which ones should I change and If not that then I would love any suggestions. Thanks for the help
  • 1 more comment
  • Chris Prosek Jan 04, 2007
    Would like to clarify that the picture, even after it warms up, never gets better. Attached is an example for your analysis. I just want to double check before I pull the circuit board out. Thanks.
  • Chris Prosek Jan 15, 2007
    I also had another problem with not having any filament voltage that never got resolved,but thats ok I am happy with any help. Thanks again
  • Chris Prosek Jan 19, 2007
    I replaced the 3 STK packs and my picture is outstanding..Thanks
    President:
  • 3,130 Answers
If this problem happened all at once, replace the Convergence IC's as you still may have capacitors going bad in this set of this age, but these IC's are for sure bad from the picture you posted.
Posted on Jan 04, 2007
    Sergeant:
  • 308 Answers
I would suspect you have several capacitors drifting out of tolerance as they warm up. When checking for these, also make sure to change The value Of C813 (33uf 16v) To (10uf 50v) if it hasn't been done already. You'll need a technican with a capacitor meter and ESR tester to find the marginal capacitors. I doubt that any of your STK packs (IC's) on your convergence module are defective. I'm also assuming that the tapping with the wooden stick didn't change anything, otherwise a bad solder connection could be the culprit.
Posted on Jan 03, 2007
Mitsubushi VS-5043 Rear Projection,,, Replaced 3 Converrence IC's. Recovered green color. Red color is bowed. Cannot move red crosshais in convergence set up. Is their a way to reset? Could something else...
There are a few low value 1-watt flameproof resistors in the convergence yoke circuits. They typically range from 1 to 3 ohms. An open resistor will cause the respective color to be non-responsive. Also chack that you have the convergence yokes re-connected to the correct connectors on the board.
Nov 10, 2009 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS50805 Serial # 102718 No red in picture
Replace the convergence ICs your model uses two STK392-040 Convergence ICs. You can get replacements at the following link with instructions.
http://servicemanuals.vstore.ca/
Dec 28, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Color convergence
The convergence IC's will need to be replaced along with possible resistors and/or fuses.
Dec 17, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Convergence
Good Day, Hazardsneon;
No, one portion of an IC could fail, but don't replace the one that failed, replace both. Good Luck, big IRISH.
Sep 07, 2008 | Mitsubishi VS-45603 45" Rear Projection...
Mitsubishi VS-50705 50 in apparent convergence problem.
First thing a tech would do is solder around Convergence amps then check to see if you can align by menu then if can not. Change amps and maybe resistors.
May 19, 2008 | Mitsubishi VS-50705 50" Rear Projection...
MITSUBISHI MODEL NO. VS-5043 BOWED AT TOP AND BOTTOM.
This is a convergence problem. The output ic needs to be replaced.
Apr 01, 2008 | RCA HD52W59 HDTV Projection Television
Mitsubishi 50 in vs-5043
Needs convergence circuit O/h==replace convergence IC's & any damaged/over-heated resistors.re-align as needed.
Oct 01, 2007 | Mitsubishi VS-50502 50" Rear Projection...
Mitsubishi VS-60705
1. THE CONVERGENCE CAN BE RESET BY PRESSING "MENU 12596" TO ENTER THE CONV MISC. MENU THEN "8970" TO RESET.
Aug 21, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Convergence IC
The convergence IC's are black in color with white lettering on them and will start with STK. These IC's will be standing up and be about 2" X3" in diameter. These IC's will also be mounted up against a large metal device called a heat sink. good Luck
Apr 08, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
49 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
