Question about JVC HR-S7500 S-VHS VCR
Stuck VCR (JVC HR-S7500EK)
The cassette stopped playing and the video machine turned itself off. When it was turned back on, the eject tape symbol flashes and the machine turned itself off again. On opening the video machine, I removed the plate and took out the cassette and reassembled the plate - and now, on turning the video machine on it acts as if a cassette is still in there and seems to be either playing for a short while and then turning itself off. It won't eject, stop or do anything...
Please help! : )
  • bannism4 Dec 21, 2008
    exactly the same
  • boxite Feb 12, 2009
    My tape would not eject so I opened the recorder and found the tape loose but not broken. I then took the bar off and removed the tape put the bar back and tried to put a new tape back in but the machine will not accept it.
ice man
  • 68 Answers
SOURCE: jvc HR-S9700 -TAPE JAMS, THEN SWITCHES OFF,CASSETE DOOR REMAINS OPEN,DOES NOT ACCEPT OR PLAY
the switch is on the electronic board under the tape compartment. you have to unscrew the screws and unplug all the wires to take it out. be careful though, you have to put it back the way it was otherwise you will mess up the machanisim on that machine. good luck
Posted on Apr 06, 2007
Benimur
  • 6966 Answers
SOURCE: Too fast playback of video cassette
Initially, I am inclined to think that nothing is wrong. It is just most likely that that particular tape was recorded in a different speed other than what your VCR is capable of playing. This is a form of compression wherein a longer recording/playing time is squeezed into the same type/kind of tape. The various settings are SP, LP, EP or even an XP. Pls click here to give you an idea of the recording time/speed at different settings.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 09, 2008
MNfisherman
  • 11896 Answers
SOURCE: Will not release the cassette when ejected and breaks the tape.
there is a spring attached to the tape release gear that will eventuall wear out through time, also, sometimes the rubber belts wear out and throws the timing off.
That would be the first two things to check. Make sure spring is not stretched. Try testing with cover off and watch to see if the part holding the back of the tape releases.
Posted on Mar 11, 2009
SOURCE: problem ejecting tapes getting stuck
The take up is not rewinding the tape all the way back into the shell. Check the idler, it's either worn or if it's plastic it is warped from the heat.
Posted on Apr 30, 2009
  • 16 Answers
SOURCE: JVC HR-S9500 S-VHS VCR. all functions work except
the eject button is a plastic piece that turns and pushes down on the board and is more then likely broken open the vcr take off the front face plate and check the button, it will propaply fall out. you can use super glue and glue the button back in place
Posted on Jan 05, 2010
Hi, I have a JVC HR-J658 VCR that doesn't eject tapes.
You mean a tape is stuck inside? Disconnect power and open up the cover. If the tape is stuck around the posts, free it and by manually turning the loading motor you can slowly get the mechanism to eject the tape.
Nov 05, 2013 | JVC HR-670 VHS VCR
JVC HR-S9500 S-VHS VCR. all functions work except the eject on the vcr. there is no eject on the remote.it plays, ff, rew, stops etc. I can't get the tape out.
Jan 05, 2010 | JVC HR-S9500 S-VHS VCR
Tape would not come out.
Not sure on the removal, but if you replace the mode switch the machine might come back to life.
Jul 31, 2009 | Panasonic PV-7400 VHS VCR
I have a HR-J625EA JVC VCR & video cannot be ejected.
this sounds like a sensor problem the vcr thinks the tape has been ejected and then turns off! this will cost more to fix then a new VCR!
Dec 08, 2008 | JVC HR-S9800 S-VHS VCR
JVC HR -J655EK Video Stuck
Hi hannah. The simplest way to remove stuck tapes is to remove the top cover. Usually just a couple of screws. Then remove the stuck tape and put the cover back into place. You can also look for emergency eject hole and insert a snall pin into the hole and attempt to eject the disc while repeatedly twisting the pin inside the hole.
May 16, 2008 | JVC HR-J461MS VHS VCR
JVC HR A62U VCR
I was wondering if you tryed unplugging vcr for an hour then
plugging it back up. sometimes this resits it and it will work fine.
the tape might eject itself out or eject button might work.
Nov 10, 2007 | JVC HR-A32 VHS VCR
Tape stuck in vcr
Hello tcsabug,
First locate the load and unload motor, it is the one with the rubber drive band. release the drive band and rotate the gear to raise and pull the carriage back into position.
This should remove your cassette, and put the carriage back into position.
I hope this helps,
Thank You,
Shuttle83
Oct 16, 2007 | JVC HR-J633M VCR
Jvc HR-S9700 -TAPE JAMS, THEN SWITCHES OFF,CASSETE DOOR REMAINS OPEN,DOES NOT ACCEPT OR PLAY
Aug 18, 2006 | JVC HR-S9500 S-VHS VCR
JVC HR-S9700 TAPE STUCKS, HAVE TO BE PULLED OUT, CASSETTE DOOR REMAIND OPEN,VCR SWITCHES OFF-CAN NOT BE PLAYED AGAIN
Check out the drive that works the unloading and loading operation of your machine. Also check the switch that is activated by the presence of your cassette. If something is wrong with the latter, the tape will not load and unload properly. And under those circumstances your machine will not work.
Try Google search for your questions. You may get lucky and get the answers right there!
Mar 13, 2017 | JVC HR-S9600 S-VHS VCR
JVC HR-S7500 S-VHS VCR Logo
77 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
