Question about Relisys TL 766 Monitor
JM777 no receiving signal from CPU
Given Relisys JM777 working fine on another CPU. Plugged everything in all seemed ok. Turned CPU and monitor on, initially got "No Signal" message up, that disappeared and nothing else came up on screen - what did I do wrong? Screen looked as though it was turned off yet power light was on.
    Genius:
  • 1,913 Answers
When u power up the computer press F* key then go to enable vga mode then set disaply resolutin incotrol panel to 800*600 or 1024 *768
Posted on Nov 25, 2008
  • kishor khatri
    kishor khatri Nov 25, 2008
    press F8 key not f*
No input signal on monitor-not connected to tv-computer works fine except for the no input signal
no input or signal means that the monitor is not receiving any signal from the CPU and if the power light is amber then and the cpu works fine then there could be a problem with the cable connecting the CPU and the monitor ...check the cable.
Mar 03, 2014 | Dell Computers & Internet
My relisys monitor wont come on. it was working perfectly yesterday and now wont work at all. the screen is just black and no lights are coming on. everything is plugged in and switched on.
You might have a break in the cable or a loose plug, try wiggling some of the wires around and check to make sure that all the plugs are in as far as they can go.
Sep 20, 2012 | Relisys Computers & Internet
No signal to monitor
Check all conections between the tower and the screen, make sure all are secure, if no joy, unplug the tower and remove the side panel to see if the graphics card is in securely, maybe take the graphics card out and put it back in again to be sure. If you have another monitor or monitor cable try replacing to see if the situation improves.
May 05, 2011 | Acer Aspire M1641-U1521A PC Desktop
Check signal cable
There is no problem. The monitor is telling you that it's not receiving a signal. The reason there is no signal is because your computer is turned off, so it's telling the truth. :D
The monitor should go into idle mode on its own, so you won't see that message for very long. It's annoying, but doesn't cause any real problems. You can save even more energy by shutting off your monitor entirely after you shut down your computer. This will make the message go away and also save money on your electricity bill!
Apr 23, 2010 | Samsung SyncMaster 913N 19" LCD Monitor
I require monjitor drivers for a second hand
This MIGHT work:
http://www.nodevice.com/driver/company/Relisys.html
Just be careful.lol And you can find these sites by just typing it in in google.
Sep 22, 2009 | Computers & Internet
Relisys projector will not show presentation from laptop
the signal resolution may not match on the projector.
Jan 14, 2009 | Relisys RHTP200 DLP Projector
ProView monitor CY-465 Model 468
Jomilshe,
Your monitor not detecting your PC. Check your cable for any damaged pins or changed another cable. Still the same problems...Used another monitor on the same PC. If it OK! Then the other monitor AD board need to be replaced. What's AD board? It's a piece of component that you plugged your VGA or DVI cables to the monitor. Have a nice weekend!
Oct 04, 2008 | Relisys RLT1720 17" LCD Monitor
Relisys Sound
CJ,
1. Check make sure the audio cable are plugged in from the monitor to the PC output audio jack (light green).
2. Open your on screen display and go to Volume settings. See if it set on mute or set to 0.
3. Turn of your monitor & PC and unplugged all the cables from your monitor and PC wait for 10 seconds and then replugged it all the cables and audio cable back. Then turned on you PC...
4. If it still doesn't work.. open the back cover see if the speaker cable are plugged in.
5. If that doesn't work...then your monitor AD board built-in speakers are defective.
6. Why not just used a external speakers, it give better sound quality.
Aug 17, 2008 | Relisys RLT1720 17" LCD Monitor
Relisys 17in tft monitor
hi everyone,
i have a relisys monitor and had this exact same problem where the menu screen comes on and then cycles through the various options until it gets stuck in a loop within the colours settings.
- the solution i found is to open the monitor itself. (make sure power supply is disconnected)
- opening the monitor should be fairly easy - i have 4 screws located at each corner of the monitor.
- i have 6 screws which locate and secure the stand.
- once the screws are removed you can prise open the monitor.
- to make this easier start where the monitor comes apart
the easiest and the use your fingers to slowly prise the
rest of the casing apart.
- now examine the circuit board which you will spot quickly as it is the only circuit board visible. The rest is hidden by a steel guard.
- the circuit board is secured with three screws before
removing them make sure your body is free of static
by touching something which is metal and grounded.
- once you have removed the board locate the white connecters which are inserted in to the board.
- the one i disconnected was the one which is concerned with the menu system, which is the small connecter.
- refit circuit board
- refit casing
- refit stand
and there you have it your monitor should now work but with no menu facility, however the monitor will still have the ability to auto reset the screen should it be misaligned.
notes
this is not a complete fix, even though it worked for me it may not work for you, however you could try removing other connections and reseating them. more connections are locating underneath the steel guard inside the monitor.
Mr Jag Singh
Nov 25, 2007 | Relisys TL 766 Monitor
Relisys TL 766 Monitor Logo
406 people viewed this question
Top Relisys Computers & Internet Experts
Samuel Konger
Samuel Konger
Marcin
Are you a Relisys Computer and Internet Expert? Answer questions, earn points and help others
