Question about Cyberhome DVR 1600 DVD Recorder
Wont finalize recorded it full length machine shut itself off because it was full ,clicked ok tried to go to edit to finalize , it would not allow me to go to edit, to finalize , tried to play back said disc un reconizablel
    Problem Solver:
  • 12 Answers
The most likely source is the power board in the unit. If you remove the lid, you will see the power board siting off the side of the DVD tray. Look closely at the board and you will notice 5 cylinder type capacitors that are black with silver tops. If the tops are not exactly flat, but look like they are bulging, then the capacitors need to be changed.
The capacitors are: 10v 2200uf 105-Degree Capacitors.
The symptoms are: the unit will not power up immediatly. If the power is connected and the unit left for a few minutes, it may show the timer after while, and power on, however, it will not work correctly. I have even been able to put in a DVD and it be recognized at first, then fail.
If you need help, email me.
Kahn
Posted on Nov 25, 2008
Why does it freeze when I try to finalize the disk? Nothing works - power - exit- cancel - menu - nothing.
Like a computer then do crash sometimes. It maybe because the disc is quite full, or too full and it can't write the menu to it. It could be just the title menu that's the problem. You can try a few other options, such as changing the title design. Trying a better quality disc for example.
I don't think it's an electronic fault on your machine that is the problem. Unless it won't finalise a single TV show short length on to a disc.
May 09, 2016 | Samsung DVD-VR357 Tunerless DVD Recorder...
Tip
Convert and Merge Panasonic TM700/HS700 MTS to ProRes MOV for FCP 7 on Mac
More Article about ProRes Converter: <br /><a href="http://www.aunsoft.com/mac-avchd-videos-to-prores-422-converter-m2ts-to-prores-422-quicktime/">Convert M2TS to ProRes</a> <br /><a href="http://www.aunsoft.com/transcode_convert_avchd_mts_m2ts_to_fcp_fcp7_apple_prores_422_on_mac/">Convert AVCHD MTS to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_transfer_panasonic_hs60_mts_to_apple_prores_422_mov_for_editing_on_final_cut_pro/">Transcode Panasonic 1080p AVCHD to ProRes</a> <br /><a href="http://www.aunsoft.com/no_loss_of_quality_mts_to_prores_conversion-edit_panasonic_tm900_mts_on_fc_studio/">No Loss of Quality Panasonic MTS to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_nikon_d5100_h264_to_prores_for_editing_on_fcp/">Convert Nikon H.264 MOV to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_canon_eos_t2i_canon_7d_mov_to_prores_mov_for_final_cut_pro_on_mac/">Convert Canon EOS MOV to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_deinterlace_sony_hxr-nx5e_avchd_to_prores_mov_for_fcp_on_mac/">Deinterlace Sony AVCHD MTS to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_bloggie_touch_full_hd_mp4_to_prores_for_final_cut_with_mac_sony_bloggie_touch_converter/">Convert Sony Bloggie Touch Full HD MP4 to ProRes</a> <br /><a href="http://www.aunsoft.com/apple_prores_422_converter_convert_and_playback_apple_prores_codec_movies/">Convert and Playback Apple ProRes Codec Movies</a> <br /><br /><b>Panasonic HDC-TM700</b> is the new model introduced in early 2010 with 32GB built-in Flash Memory. To maximize the beauty of Full-HD 1920 x 1080, 60 progressive recording*, Panasonic worked to develop the ideal camera system. <br /><b>Panasonic HDC-HS700</b>,New 1080/50p recording (Full-HD, 1920 x 1080, 50 progressive recording) conveys about twice the information of 1080i (interlace) recording to produce the ultimate beauty in image quality, exceeding even conventional Full-HD images. It minimizes afterimages and flickering caused by subject motion and renders crisp, detailed images. 64GB SDXC card can record approximately 27 hours 30 minutes of 1920 x 1080i High Definition video in HE mode, and approximately 5 hours 20 minutes of 1920 x 1080p full High Definition video in 1080/50p mode. <br />Final Cut Pro is supposed to support AVCHD Lite import, but it does not work very well.If you encounter any problem using GH2 AVCHD Lite on Mac, or want to edit TM700/HS700 1080p MTS in FCP/FCP 7, it is recommended that you convert TM700 Full HD to common MOV for FCP/FCP 7.So you may face the rendering problem when editing in Final Cut Pro. To avoid waiting for rendering in Final Cut when editing, it is recommended want to <b><a href="http://www.aunsoft.com/video-converter-mac/">Transcode AVCHD to ProRes 422 for Final Cut Pro</a></b> native format. <br /><br />Apple ProRes,Apple ProRes 422,Apple ProRes 4444,introduced in Final Cut Studio, was advertised to one of the codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro. <br /><br />Here is the step-by-step guide for you to <b><a href="http://prores-converter.com/2011/06/convert-and-merge-tm700hs700-mts-to-prores-mov-for-fcp-7-on-mac/">Convert and Merge TM700/HS700 AVCHD MTS to PreRes 422 MOV</a></b> for Editing in FCP/FCP7 without rendering on iMac or MacBook Pro with Mac OS X like Snow Leopard. <br /><br />Step 1. Load Panasonic TM700/HS700 videos to Aunsoft Video Converter for Mac. <br />Run Aunsoft Video Converter for Mac as the best <b>TM700 AVCHD Video to ProRes Converter on Mac</b>, click the "Add" button and you can browse the TM700/HS700 1080p videos for conversion. <br /><br />Step 2. Choose Apple ProRes for Final Cut Pro. <br />Click the "Format" option, and navigate the mouse cursor to <b>Final Cut Pro &gt; Apple ProRes 422 (*.mov)</b> as output format. The video to ProRes 422 converter will transcode Panasonic DMC-GH2 1080 AVCHD Lite to Final Cut Pro native format. <br /><br />Step3. <b>Merge Panasonic 700 1080p AVCHD files. (Optional)</b> <br />Tick the checkbox for "Merge into one file", and the Panasonic TM700/HS700 1920&times;1080 AVCHD converter will join and combine the video clips into a single file as output. <br /><br />Step 4. <b><a href="http://canon-videoconverter.com/2011/06/convert-and-merge-tm700hs700-mts-to-prores-mov-for-fcp-7-on-mac/">Convert Panasonic TM700/HS700 videos to Apple ProRes for FCP</a></b>. <br />Click the convert button under the preview window, the conversion from <b>Panasonic Camcorder AVCHD to FCP Native Format ProRes 422</b> will start immediately. <br /><br />After converting and merging the Panasonic TM700/HS700 AVCHD files, just import the output Apple PreRes 422 .mov files to Final Cut Pro 7 or Final Cut Pro 6 for editing and the video is in HD 1920&times;1080.Optimize your workflow and save time with the Apple ProRes compression for Final Cut Pro. You can also import the output videos to Final Cut Express (FCE) 4 for editing in full HD.
on Jun 16, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
"access denied" in XP
<p>Introduction:<br /> <p>When installing or uninstalling the printer driver, a message may appear stating that <span>access is denied</span>. This may occur in Windows 2000 or XP. It may be necessary to edit the registry of the computer to resolve this issue. <br /> <p>Editing the registry with the instructions in this document may bypass security profiles. Please consult your system administrator.<br /> <p>According the instructions below, first check the service pack on your computer, and if necessary update it. If the issue is not resolved, proceed and edit the registry.<br /> <p>Instructions:<br /> <p><b>Step 1: Check the service pack</b> <br /> <p>The issue may be resolved by updating the service pack, if the most recent service pack is not already installed. To check which service pack is installed on the computer, complete the following steps: <br /> <ul> <li> <p><b>Windows XP:</b> Click Start, right-click My Computer, and then click Properties. Under System:, the service pack is listed. <br /> <li> <p><b>Windows 2000:</b> Right-click My Computer and then click Properties. Under System:, the service pack is listed. <br /></li></ul> <p>Make a note of the service pack information. <br /> <p>On the Microsoft Web site, find the Windows Update information. Check to verify the latest service pack and whether it is installed on your computer. If necessary, follow the instructions provided by Microsoft, or contact Microsoft for help, to install the service pack.<br /> <p>If the error message returns and you are unable to install or uninstall the printer driver, proceed to Step 2.<br /> <p><b>Step 2: Edit the Registry</b> <br /> <p>Window maintains most of the information about your computer and its programs in a file called the registry. It is important to backup the registry before editing it. If mistakes are made when editing the registry, your computer may not function properly. Having a backup copy of a working registry will allow you to restore your computer to a working state if mistakes are made while editing the registry.<br /> <p><b>Backing up the Registry</b> <br /> <p>Complete the steps in this section to backup the Windows registry. <br /> <ol> <li> <p>Click Start and then click Run. <br /> <li> <p>In the Open box, type regedit. Click OK. <br /> <li> <p>In the Registry Editor, select My Computer. <br /> <li> <p>In Windows 2000, click Registry and then Export Registry. <br /> <p>In Windows XP, with My Computer highlighted, click File and then Export. <br /> <li> <p>Browse to a file location that will be easy to remember. <br /> <li> <p>Under Export Range, select All. <br /> <li> <p>Type in a filename. Suggestion: registry_backup with the current date. <br /> <li> <p>Click Save to save the backup copy of the register. <br /></li></ol> <p><b>Editing the Registry in Windows XP</b> <br /> <p>To make the necessary changes to the registry in Windows XP, follow these instructions: <br /> <ol> <li> <p>Click the ( <b>+</b>) next to HKEY LOCAL MACHINE. <br /> <li> <p>Click the ( +) next to SOFTWARE. <br /> <li> <p>Right-click Hewlett-Packard, then click Permissions. Verify that Full Control is checked in the Permissions for Users box below the Group or user names box. Then, click OK. <br /> <li> <p>Click the ( +) next to Hewlett-Packard. <br /> <li> <p>Right-click HPDJ PRINTING SYSTEM CONFIG and then click Permissions. Verify full control is allowed for each user on the list. Then, click OK. <br /> <li> <p>Right-click HPZ and then click Permissions. Verify full control is allowed for each user on the list, then click OK. <br /> <li> <p>Click the X in the upper-right corner of the Registry Editor to close it. <br /> <p>Now, with the registry edited properly, uninstall and reinstall the printer.<br /></li></ol> <p><b>Editing the Registry in Windows 2000</b> <br /> <p>To make the necessary changes to the registry in Windows 2000, follow these instructions: <br /> <ol> <li> <p>From the desktop (with the registry closed), click Start and Run. <br /> <li> <p>In the Open: box, type <span>Regedt32</span> and then click OK. <br /> <li> <p>In the tiled windows, find the one labeled HKEY_LOCAL_MACHINE on local machine and maximize it. <br /> <li> <p>Double-click HKEY LOCAL MACHINE. <br /> <li> <p>Double-click Software. <br /> <li> <p>Click the Hewlett-Packard entry. <br /> <li> <p>Click Security on the menu bar at the top of the window. <br /> <li> <p>Click Permissions. Verify that Full Control is checked in the Permissions box. <br /> <li> <p>Double-click Hewlett Packard. <br /> <li> <p>Click HP DJ PRINITNG SYSTEM CONFIG. <br /> <li> <p>Click Security and then click Permissions. Verify that Full Control is allowed for every user in the list. Click OK. <br /> <li> <p>Click HPZ. <br /> <li> <p>Click Security and then click Permissions. Verify that Full Control is allowed for every user in the list. Click OK. <br /> <li> <p>Close and exit from the registry.<br /> <p>Now, with the registry edited properly, uninstall and reinstall the printer.<br /></li></ol>
on Mar 10, 2011 | Computers & Internet
This morning while trying to copy from vhs to dvd I kept getting an on screen message OTR Pause....record. What is OTR as the tape did not copy this is model DRC832ON
OTR is one-touch recording on most of my VCR/DVD burners where you set the length of time to record from the tv. In my manual it is the Express Record feature. Press the REC button several times to advance the record time by 30 minutes. In your case it might refer to On Timed Record.
Use the COPY button on the front of the unit when the tape you want to record is in the VCR and a blank DVD is in the DVD tray. If you have the A/B Edits set, only the A/B editted sections will copy. (Copy protected tapes and DVDs can't be copied.) (Or the timed transfer described below)
Copying DVDs to VCR tapes can be done in a timed record mode. You can either use Menu > Disc > Copy Disc then press OK or Menu > Timers > Set Transfer and press OK. Then press Info to name the timed event followed by Done and OK, if desired. Press OK to highlight Copy From/To and make sure to select the correct source and destination and press OK. Next set the day and time that you want the transfer to take place (a couple of steps, press OK between them and when done). Then adjust the quality if needed and press OK. Finally highlight Keep Timer and press OK again. Make sure the correct tape and DVD are in place for the timed event.
Depending on what you set the unit for, I'd look for signs of power failures (which mess up most timed record functions). Then I'd double-check the time you set it to transfer and the A/B edits function. (A/B edits lets you grab small clips from an Indexed tape. Either index the tape by playing it and pressing the Insert A/B edit button (on the VCR/DVD, possibly on the remote) or delete A/B edits.)
I hope this helps.
Jul 23, 2010 | RCA DRC8300N DVD Recorder/VCR
I burn dvd -r and dvd+r and it will not play on it
It is possible that the disks are not finalized. You may need to configure it to auto finalize, which is off by default. It would be impossible to have more than one title on a disk if you always auto finalized. Check your manual, and finalize your disks. Many times marginal disks will play OK in the unit they were recorded on, but not so well in other players. The media (disks) could be the problem as well. On a side note, the DR410 will NOT burn DL (dual layer) disks. I hope this helps and good luck.
Oct 28, 2009 | Toshiba DR410 DVD Recorder
Recorded dvd
You are probably having an issue with the discs rather then what you are trying to play them on.
The discs need to be finalized before they can be used on another player.
  1. Put the disc in the drive (the ones you have already recorded)
  2. Press SETUP on the remote
  3. Select - Disc Edit Press OK
  4. Select - Finalize Press OK
Wait until it is finished then try to play them on another player.
Apr 04, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Won't record DVD+R
I have been working throug a stack of 25 Windata, the cheap ones. DVD +R/ They have been working 100%, every time. The only problem I have is when I leave machine to shut itself down because I am not there to stop it at end of movie.. The disk becomes so full that I cannot get to disk to finalize and it will never play on another machine. When I hit the Disk Edit on such an overcrammed disk, the drop down menu with Finalize at bottom does not come up Only the hand with the red crossout sign over it comes up..
Nov 29, 2007 | Protron PD-DVR100 DVD Recorder
Wont play full length
The Ilo can only play 30 seconds of video per clip. I'm afraid the only real workaround is to trim the video down to 30 second segments and number them in sequence so that the videos play relatively seamlessly. Thankfully, Ilo had the foresight to include a CD-rom with video editing software on it to allow you to do this, but any video editing program that can manage AVI formats will work.
Dec 27, 2006 | iLO XM-MP3-CD Car Stereo
Problems finalizing discs
Check to see if you are using 16x media.  If you are you need to get a firmware upgrade from Toshiba.  Contact their support number listed inside of the manual.  They will ship you a dvd to insert into the unit.
Nov 02, 2006 | Toshiba DR4 DVD Recorder
Disk Error when Finalizing DVD
you just need to replace optical pick up of the set. It must be costing abt rs 6500/-
Aug 24, 2006 | Panasonic Palmcorder VDR-M30 DVD Camcorder
Cyberhome DVR 1600 DVD Recorder Logo
60 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
