Hitachi 50UX58B 50 in. Rear Projection Television
Problem for Hitachi 50UX58B 50 in. Rear Projection Television
Hitachi 50ux58b
By chicken hawk on Jan 02, 2007
Red light on front power panel comes on when tv is plugged in for a few seconds then shuts off .I unplugged TV took the TV apart plugged TV in and looked at circuit boards three green led iights come on followed by a red light that has d912 protected led written by it then shuts off
Same Problem
Feb 17, 2009
-   i have the same problem red light comes on for a second then goes off that is it I can't get it to do anything else.-   kevoski99
Jan 03, 2009
-   leds come on for a few seconds then nothing-   joepeak1
Best Solution
posted on Jan 03, 2007
Very Helpful)
henlopen
Rank: Wiz
Rating: 84%, 649 votes
It's possible that the Convergence IC's are causing a shutdown of the power supply. Also on this model, there have been problems with:
C707 - 1000pf @ 2kv Cermaic Disc Cap (normally a small blue one) Hitachi Part # 0244211.
I901 - A STRM6811a Reg Ic and
E994 - 2.0 Amp Circuit Protector (Pico Fuse) having a high failure rate. If the 2 amp pico fuse was good, and the capacitor looked OK, then I would check the convergence circuit board. There are many other parts that can also cause shutdown problems, however.
Was this helpful?
Yes
No
Solution #2
posted on Nov 07, 2008
Very Helpful)
Ecollier2012
Rank: Guru  Hitachi Expert
Rating: 93%, 560 votes
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Hitachi 50UX58B 50 in. Rear
Questions and Unsolved Problems for Hitachi 50UX58B 50 in. Rear
Do you recommend Hitachi 50UX58B 50 in. Rear Projection Television?
Answer
Answer
wwood51375 yes those components can also affect the color. I tried answering your question but they... (More)
Answer
screen has a double image. looks like the green gun is bowed at the top and bottem of the screen.... (More)
Answer
50ux58b had lost poewr, red light went out never came back on
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
