Code F34-1 means for a Konica 7065
I have a Konica 7065 that when its turned on it says to call technican and report code F34-1.
  • 145 Answers
To reset a fuser abnormality code, perform the following:
1. Power the copier OFF.
2. Access the 25 mode (power the copier ON, while holding down on the 2 and 5 keys).
3. Touch [1: Software SW setting] on the touchscreen.
4. Touch the left up-arrow, which is displayed on the touchscreen, 2 times. The number displayed above the up-arrow will change to 03.
5. Select the bit number of the switch 1, using the right up-arrow.
6. Touch the [OFF (0)] key, which is displayed on the touchscreen.
7. Power the machine OFF/ON to exit the 25 mode.
good luck
Posted on Nov 29, 2008
F52-1 error code on konica 7055
Check all fans, and filters might need a good cleaning around them.
May 27, 2014 | Konica Minolta Copier Toner 7055/7065...
Error code E-22-1
Please the copier model.In Dialta model the code refere to main body main motor malfunction.
Feb 12, 2013 | Konica Minolta Copier Toner 7055/7065...
I have a Konica 7065 I need to replace the developer in it and then I will need to reset the counter
to reset counter turn off main switch hold down 2and 5 turn on release 2 and 5 a different screen will show select 3 PM count/ cycle, set off and is done
Jun 16, 2010 | Konica Minolta Office Equipment & Supplies
Konica 7065 with an error message of F341 problem
hi code 34-1 is fuser temp fault to reset turn off machine hold down buttons 2and 5 and turn on release 2 and 5 a menu screen will show select 1 software switch settings you need to switch no3-1 3-2 3-3 3-4 to off then try if still fails there is a good chance a heater has blown in the exit fusing unit or its temp sensor is faulty definately a technician required hope this helps:)
May 31, 2010 | Konica Minolta Office Equipment & Supplies
Konica 7065 with error code F36- 1
Sir,
Fuser Code (Hot Unit has over heated) To reset you will need to go to 25 Mode to enter his mode you must turn off the machine then holding down the 2 and 5 button turn on the machine, hold them 25 down for at least 30 second once in 25 mode select SW (soft Switch) select "3" then "3" it should be a "1" change to a "0" then exit and turn off the machine and turn "ON".
Feb 25, 2010 | Office Equipment & Supplies
After changing developer on konica 7065 what is the st up procudre ?
You must perform ATDC sensor gain procedureF8 and AIDC sensor F5 perform.
Dec 28, 2009 | Konica Minolta Office Equipment & Supplies
Konica 5370 copier has error report code 58-08 in the display
that code means there is a poor connection between the drum carriage and the main body insure that the drum carriage is inserted fully
Oct 10, 2009 | Konica Minolta Office Equipment & Supplies
Konica 7022 (code F-26-1) Pls call service 0870-2425050)
i have a konica 7022 it say call service code F-35-3, what's wrong with it, help me.
Mar 21, 2009 | Toshiba 2060 Copier
Error code
Problem: The Digital Panel is Reporting Code 34-1, 34-2, 35-1, 35-2 or 36-2 Cause: The copier is having a problem with the fusing unit.
Solution:
  1. This is occasionally a false alarm. Try turning the copier off for about 10 seconds and turning it back on. If the code doesn’t clear, please call 1-800-877-2679 for service.
Sep 02, 2008 | Office Equipment & Supplies
255 people viewed this question
k24674
jasbo
jasbo
