Question about Refrigerators
Door handle loose on 10656542400 kenmore
The door handle is seperating from the door and is loose. How can I correct this?
I too can see the clips and screws, but I can't seem to get to them. I don't see the caps, but maybe I don't understand the location as someone described earlier.
The solution on the Kenmore 56822 turned out to be very simple:
With the door closed, pull up on the door handle (requires some force). The door handle will slide up, and once it is up, it can be removed by carefully pulling it off of the door. Then the screws holding the mounting lug can be tightened. Place the handle back on the door, and slide it down, and voila, no more loose handle. I am going to put some LockTite on the screw on mine to ensure that it stays tight.
Posted on Dec 26, 2008
  • srschmal Dec 26, 2008
    You will need a Torx Driver (size T-20) to tighten the screw.
Toyota Tazz window winder
Toyota Tazz driver side window refused to wind properly. Problem was that winder mechanism and window separated - old glue. Found some input from Ben on this forum. Some pointers after doing the job today.
Step 1 - remove the arm rest - two screws
Step 2 - remove the screw holding the door opener handle.
Step 3 - remove the C-clip holding the winder handle. The clip is round but the ends are slightly bent outward - to fit back easily. Use a large screwdriver to force a small opening (thus moving the panel slightly inward). I took a piece of thin solid wire and bent it into a loop. This looped wire I hooked around the one end of the clip and pulled in the opposite direction towards the inside of the car. The open end is towards the part of the handle you wind. Make sure the top of the handle faces towards the interior of the car (door is open wide). The clip shot off (as Ben warned) but landed in the car.
Step 4 - the door handle (square) must be slid forward and outward towards you. Will now be loose but is held by the rod going to the lock.
Step 5 - loosen all clips carefully by pulling the panel forward - large screwdriver works.
Step 6 - lift up the panel - and push the door handle holder through the hole in the panel. The panel will now be free.
Step 7 - the window can be removed in this case where window and mechanism seperated by simply pulling the window upwards and outwards.
Step 8 - I used a small grinder and removed most of the glue - but not all.
Step 9 - put the window back into the door making sure it is correctly aligned in the side-sliders.
Step 10 - I used an epoxy 2-part glue (Pratley) and placed some glue in the holders. Position the window and mechanism correctly (using glue I left as marker). Note that only 2 holes in door panel can be used to see or fit glue.
Step 11 - Mix more glue and apply front and back. Now place some grease in the mechanism rail (horizontal) and wind window to the top. Leave to dry.
Step 12 - replace all in reverse. Clip pushes on easily - I used a small long-nose pliers.
Cheers,
Chris Snyman
Nov 20, 2012 | Cars & Trucks
The drivers door will not open from the inside. The inside door handle will not engage the latch. I can open the door from the outside.
Linkage has become detached. You'll have to pull the door panel. There are steel rods (linkage) that are held in place by a PLASTIC CLIPs (GM's better idea)... The clips break or come loose. Replacements are available at GM dealership but you'll need to figure out which one is bad. Take the old piece (or pieces) along with you so you can make sure you are getting the right ones. The interior handle and the exterior handle are on two seperate mechanisms which is why the inside doesn;t work yet the outside does. Hope this helps. Good Luck. If you need help figuring out How-To remove the door panle, a trip to your local public library in the Automotive books section should help and show you how the panel pulls off. A panel removal tool is a big help and is available at most Auto Stores. You make end up breaking someof the plastic clips that hold the panel in place but they are available at an Auto Store also.
Dec 16, 2010 | 1997 GMC Sierra
Sears trio elite ...french doors with bottom freezer...right side loose on freezer door handle...thanks
I have the same refrig. After taking the freezer basket hinges off, thinking I had to take the whole door a part to access the screws for the handle...my husband figured that the handle probably slides off...and yes that is just what it does!
Push the handle in a bit and then slide to the right. It takes a little bit of effort but that handle will come right off. Then you can tighten the screw that holds the clip in place. Then you line the handle back up to the clips, and slide to the left. Good Luck!
Apr 08, 2009 | Kenmore Refrigerators
Amana AFI2538AEW bottom freezer door handle is loose?
My dad's freezer handle is loose, model ABB2224DEW. Went to partselect.com and located drawing of freezer door parts. Found a link to a "do-it-yourselfer" that describes removal and replacement of the handle. Hopefully this helps.
Replacement of freezer door handle.
1. Removed freezer door handle. First I read the freezer door handle removal instructions in the Amana refrigerator user guide. Removing the handle requires inserting a plastic card at least 1.5 inches under the left end of the right side of the handle so it releases the butterfly clip latch on the freezer door. Next I pulled the right side of the handle to lift it away from the freezer door. Then still holding the handle away from the door, at the spot that is 1.5 inches from the inside of the right side of the handle, I held the plastic card vertically and slid one corner of it between the handle and the freezer door and worked the card down until it released the butterfly clip latch. Keeping the card at the same space under the handle so the latch was released, I then turned the card to the left until it was horizontal and was lifting the left end of the right door handle away from the freezer door. I then slid the handle across the card to the left until it cleared both door butterfly clip latches and it lifted off the door.
2. Installed freezer door handle. First I read the freezer door handle installation instructions in the Amana refrigerator user guide. The handle is curved on one edge and must be installed the curved side down. Correctly installed, the outside ends of the handle curve upward and the handle curve is down so it looks like a frowning mouth. Next holding the handle curved edge down, I turned it up so I could see the brackets and held it against the door. I lined up the handle brackets slightly to the left of the butterfly clips on the freezer door. Next I turned the handle with the brackets against the freezer door and slid it slightly to the right until the left side of the handle held onto the door butterfly clip by itself but was not latched. Then I lined up the right handle bracket with the right freezer door butterfly clip and carefully slid the whole handle to the right until I heard the left butterfly clip latch click. Next I slid the handle back slightly left once more and then slid it back to the right until I heard the right butterfly clip latch click.
Parts Used: HANDLE, DOOR (WHT) Level of difficulty: Difficult Time to do repair: 30 - 60 mins
Apr 02, 2009 | Amana AFI2538A Bottom Freezer French Door...
Neff Oven handle loose
The door can be seperated by screw on the side of the door, Put lock washers to insure futer tightness.
Mar 12, 2009 | Ovens
Door handle is loose
If my memory serves me correctly, you should see two posts attached to the refrigerator door right now. The handle slips over these posts and if you look closely there is a little hole in the handle where you would insert a allen key wrench to tighten the little screw against the post protruding from the door itself. With the door handle in your hand, properly match up the correct allen wrench to fit the allen screw very snug. Realign the door handle on the protrucing posts and tighten. Once finished, you should have a tight fitting door handle again. Let us know if we can help further.....Eric
Feb 13, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Replace passenger side electric mirror
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls. Then you can access the bolts that secure the mirror onto the door
Oct 30, 2008 | 1998 Buick Century
I got it!!! Okay, the most common problem is the fridge handle at the top is coming loose from the mere fact that the fridge gets opened more than the freezer and people grasp the handle higher than lower. Okay, open the door until you can look at the handle sideways where it attaches to the door. What is happening is the screw that slides into the bracket is simply backing out. Try lifting the handle straight up, only about an inch plus. The bracket is the same on the bottom of the handle as the top. If you cannot get the handle to lift, get a very slim standard screwdriver and push the retaining clip down (away from the handle) so the screw head can get passed it. You may have to push the retaining clip pretty good to get it down. When you have it pushed away from the screw head, lift the handle and it should pop up. Take the handle away from the door and tighten the screw. The screw head takes a torques screw head (star shaped, like a philips but different) Tighten it until it stops the just realign the TWO screw heads into the upper and lower bracket and slide the handle down gently. No problem! You can do it!
Sep 19, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
LOOSE DOOR HANDLE whirlpool frige GC5SHEXNQ00
Pulled the handle up to release it from the clips on the door. The screw in the plastic door handle that attaches the handle to the door clip was striped. I used a small amount of J B Weld epoxy to repair and reattach the screw. Realign the handle with the clips and push handle down to reinstall.
Jul 29, 2008 | Refrigerators
Bottom Freezer door handle
I had the same problem. It took me an hour to figure out that the bottom freezer handles clips onto the door using butterfly clips. To tighten the clips you have to remove the handle by sliding it to the right (or left??) It snaps right out with a quick **** exposing the clips underneath. A quick tightening of the clips and the handle snaps back in.
Nov 07, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
359 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
