Question about Dishwashers
Whirlpool DU6000XR Dishwasher. How do you get the bottom panel off to get to the underneath? It seems there are screws on the top of the panel but the door is in the way.
  • Anonymous Mar 19, 2014
    PART OF THE SCREW FIXING IS BROKEN ON THE CONTROL SECTION OF THE WASHER
    Sergeant:
    Champion:
  • 338 Answers
You should be able to still reach it with a screw driver
Posted on Nov 25, 2008
How to Replace a Dryer Door Switch on a whirlpool
First, make sure the peg on the door that pushes the switch is in place and the two snap pegs that hold the door shut are not broken. If any of these are broken, replace them first and see if that solves your problem. If not, here's how to replace the door switch: Unplug the dryer. Pull out lint screen. Remove two screws revealed underneath. Slide a 1" putty knife between the top and cabinet at the top front corners on each side, jamb it in while tugging the top forward to release the clips, one at a time. Lift top and lean against wall. If it's a gas dryer, remove lower front panel and loosen two 5/16" hex head screws for top front panel. If electric, loosen same screws at bottom of front panel. Remove two 5/16" hex head screws holding front panel from inside near top. Carefully tilt front toward you, holding drum in place. Lift front panel slightly to disengage bottom screws and remove. Gently lower drum until it stops. Unplug two (sometimes three) wires to door switch on right side. Now the front panel is completely free. Remove two Phillips head screws holding door switch onto front panel. Reassembly is the reverse of disassembly. Make sure wiring to door switch is secured to cabinet so they don't drag on the drum, and are not pinched. Be careful realigning the drum into the door opening so felt seal is inside the front glide ring on the drum. After the front panel is in place, gently hand turn the drum to make sure it is turning properly and the belt in still hooked to the idler and motor pulleys. If the drum falls off the rear rollers, or the belt comes loose, you will have to correct it before putting the front panel back on, as you cannot reach them otherwise. Taking pictures during disassembly will help get it back together properly. It really is not as hard as it seems, you may even be able to replace the switch without removing the front panel. Also, if you have a three wire switch, write down where they go or snap a picture. If it's a two wire switch, it doesn't matter, it will work the same either way. Good luck.
Feb 18, 2014 | Whirlpool 358409 Washer/Dryer Screw &...
Whirlpool dishwasher door falls open fast when opening. plastic part came off, but don't know where it is from
remove the bottom access covers on the bottom of dishwasher. turn on the dishwasher with water valve in off position so you can here the motor running,while its on, find the breaker and turn off power.you will here motor stop. disconnect power wires from power box on right hand side,then disconnect water line open the dishwasher door and at the top remove screws holding dishwasher in place. pull dishwasher out from bottom.you may have to adjust bottom adjustable screw legs. pull it out and check sides where springs are for the door to open and close. it may have came loose.
Feb 27, 2013 | Whirlpool Gold GU2275XTV Builtin...
My Whirlpool dishwasher ADP7408 is not working and is displaying F4 in the electronic display
Leave it off for a while and try it again, if this does not work you will need:
A person to help tip the machine over
a basin
a pliers
screw drivers
some rags
Empty out as best you can the remaining water from your machine.
Roll over and remove the bottom of the dishwasher, you might need to remoce screws from the back panel too.
Carefully remove the bottom panel, there may be devices attached to it slide your hand in and unclip them, BUT be carefull often the edges of the metal is sharp.
Once the bottom is of grab your pliers and you patience and release the clips on the hoses, blow them all out. The salt store might need to be emptied completly.
Reconnect everything and replace the bottom.
Stand the machine up and refill the salt store with water to the top.
Test the machine, it should now work.
Hope this helped
Oct 03, 2012 | Whirlpool 33 in. ADP6830 Free-Standing...
Like to remove the control panel
    • 1 Turn the breaker switch for the dishwasher to the "off" position at the breaker box before attempting to remove the dishwasher panel.
    • 2 Locate the screws on the lower access panel and unfasten them with a screwdriver, setting the screws out of the way.
    • 3 Detach the control console from the top of the front panel by unfastening the screws underneath the console with a screwdriver and setting the screws aside.
    • 4 Find the screws at the bottom of the front panel and unfasten them with a screwdriver, allowing the panel to slide down. Take the panel off the front of the dishwasher.
Oct 03, 2011 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Remove the door
The outer door panel makes it easier to get to the bottom. Open the door and remove the screws from the inner liner staring from the bottom on each side working your way up. You will stop just short of the top 2. Have a brace under the panel so it does not fall on your foot. Once the screws are out the panel lifts off.
Apr 25, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Water flowing from underneath when in use
  1. open the bottom panel 2-4 screw
  2. take a flashlight and turn the machine on
  3. see where it come from
  4. if you need take the unit out a bit from the counter
  5. check it all around to find the sorce of the leak
  6. good luck its EZ :)
Jul 27, 2009 | Whirlpool 24 in. DU810CWD Built-in...
Whirlpool dishwasher reset code
Yup, found it on another site..I had the same issue today.
Reset code: Push 1. Heat Dry 2. Normal 3. Heat Dry 4. Normal
wait about 2 minutes as the controller resets itself. You should see all the leds flash on and then wash and rinse leds stay on for about 30 seconds. A minute or so later ..presto, my machine worked again.
My machine is not the GU3200XTP, but in the same Whirlpool tall tub series (same manual) so leds may not have the same name.
Mark
Oct 19, 2008 | Whirlpool 24 in. GU3200XTP Built-in...
How do I open the sprary arm
the plastic screw is not holding it down. First disconnect the white tube in the back of the bottom spray arm.Now turn the stub part clockwise. and the spray arm should pop off...
Jul 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool adg 7560
on must hirlpool the top console has control on front upper side,,if so you must remove console and bottom panel,,because your panel will be thicker you must get 1 inch counter screws remove diswasher orginal panel than add you bottom,,,,if it dishwasher that has control bottons on top side of doorplace panel over hold door the remove 4 inner panel screws and replace with 1 and a half in screws ,and mount straight through
Mar 22, 2008 | Whirlpool 24 in. ADG7540 Built-in...
Dishwashers Logo
90 people viewed this question
Top Dishwashers Experts
