Question about Motorola Talkabout T7450 (22 Channels) 2-Way Radio
Motorola T7450 Charger Light is Out. Not Charging??
Your fix please.
  • Motorola Master
  • 1,654 Answers
In most cases when the charger light will no longer illuminate, the charger is bad. (They are somewhat like a lightbulb. They will burn out over time.) You should be able to find another one online or at your local Motorola dealer for $15 US or less.
Posted on Nov 25, 2008
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
I left my Motorola Razr 3 on charge last night as usual. This am it had switched off & will not switch on again. I have attached it to my computer via USB charger & the green light is showing on the front...
Computer will not charge your phone if the computer is off, may stop charging during standby or sleep mode. If failure to charge over night was on wall charger its a problem with charger/cable. OR your phones battery is junk.
Aug 11, 2013 | Motorola Mobility RAZR V3
MotorOLA XOOM battery won't charge
Keri
Maybe a bad charger.
Mark
Motorola Support
Mar 15, 2012 | Motorola Mobility Xoom
Getting unauthorized charger message when using universal charger for my Motorola Rival A455 phone--how to fix?
I had the same problem with my rival. I used a universal USB charger. It worked fine for a month or so and then stopped charging completely. I went to the Motorola website and downloaded the charging driver. I haven't had a problem since.
Jan 23, 2011 | Motorola Mobility Rival A455 Cell Phone
I have a set of T7450 talkabout One of them when you transmit the other person can hear you but all you get back is a high pitched sound and static. sometimes it will work ok.
Check your batteries. One simple check is to trade the batteries between the units and see if the problem moves to the other radio.
Best regards.
Feb 12, 2010 | Motorola Talkabout T7450 (22 Channels)...
Invalid battery..
There is too much going on here. For starters, you should only be using Motorola accessories IE batteries, chargers, screen protectors. Now that you have done this, you have actually confused the phone, it is a "smart phone" and because of this, it is able to identify the different battery/charger. You have to send this to Motorola of for a quick fix or buy a new phone.
Oct 11, 2009 | Motorola Mobility MOTOROKR E6
Motorola s9 headset not charging
I had the same problem but instead of a red light it would flash green twice and stay off. I could not find the original charger and another plug in charger would not work. I plugged it into my computer with a usb cable and after several seconds it started charging.
Sep 16, 2009 | Motorola Mobility S9 Headphones
Bluetooth doesn't fully charge?
simply check and if possible change the charger.
if the same problem persist try charging with a USB cord(which you have to connect to a PC)
please let me know of the outcome.
Apr 27, 2008 | Motorola Mobility H500 Wireless Headset
Motorola v3i
connect your phone to the system through usb. if it starts charging then its not the problem with the phone or battery. its a problem with the charger. now also if it does not charde, then it must be a problem with the phone. take it to the nearest motorolla service centre and fix it.
Apr 22, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Talkabout T7450 (22 Channels) 2-Way Radio Logo
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
