Question about JVC AV-32320 32" TV
My JVC AV 32320 will turn on, but w/o picture or menu functions
The TV will turn on, but there is no control via the panel on the TV or the remote. The picture begins black, goes to blue and then the TV shuts off. While on, the "on timer" button is illuminated. I believe the TV still works as last time it turned on properly, it did.
  • 2 more comments
  • toddmhart1 Nov 24, 2008
    I have tried the unplugging method way in advance of coming on this site. Additionally, the "On Timer" button is not blinking showing it would need service as indicated in the manual-page 40, I believe
    this TV isn't hooked up to a DVD player. The only connected unit is a DirecTV TIVO unit.
    unfortunately, I also tried the disconnect everything method, too, without positive results. I should mention the TV powers up the moment the main power cord is connected to power supply without the use of a "power button" on the set or remote.
    Sergeant:
  • 276 Answers
The control switch problem that is making this happen.the control switch is faulty.it is just tripped inwards and needs proper reallignment and readjustment.just needs a technician at your place to readjust the control switch on the frontpannel located on the main board.
Posted on Nov 25, 2008
  • 4,234 Answers
This problem can be caused by a leaky diode internally. I have seen this in a number of sets and found that a diode and other related components become defective. There are a few circuits that can cause this. WIthout seeing the set and taking some measurements, I can not tell what circuit is the problem. Unfortunately, I am not a JVC service center, so I don't have the service manuals in hand and this is not the easiest to track down (especially remotely). These sets are good ones and would be worth the service cost for repair. Normally this problem would require parts in the $25 range. Add in the local labor rate for the total repair cost.
Keep us posted.
Dan
  • 849 Answers
It seem there is power supply problem, consult with qualified technician for assistance.
  • 905 Answers
If you can open up the tv , then disconnect the control board from the main board and also disconnect it from the tv ( screws) then clean the plastic buttons and inspect them for pushing on the contact buttons , then plug the control board back in and see if it stays on , before you screw the control board back into the front of the tv , does that do it?
electech
Posted on Nov 24, 2008
    Genius:
  • 1,913 Answers
I think your tv need services technician bcuse it must be hardware related isue.
it is beter give u advice than say sorry.
    Genius:
  • 1,847 Answers
Does this happens when you are playing the DVD too?
  • 57 Answers
Try resetting the TV by unplugging the cord, then plugging the cord back in, this might clear up any issues with the control malfunctioning.
According to the instructions for your set (http://resources.jvc.com/Resources/00/00/97/LCT1135-001B-A.pdf) if the "on-timer" display is blinking, the system needs work, and will need to be returned.
  • AJ Walker
    AJ Walker Nov 24, 2008
    Try disconecting EVERYTHING from the set, except for the power supply :)
Tv has gone black and white
Look to see if same issue when a DVD etc is connected via the audio/video jacks this set should have.
If no color there it is a fairly expensive repair--likely the chroma/video chip which for this model may not be available any longer.
Jun 10, 2012 | JVC AV-32320 32" TV
We just got the JVC 32320 from a friend to use in our kids playroom. However, when we plug it in, it is just a loud fuzzy noise. The buttons do not work and there is no remote. We were going to try to...
The code will depend on the make & model of the remote that you purchase. The instructions that come with it will crossmatch to your TV brand and model.
Feb 09, 2018 | JVC AV-32320 32" TV
On/off timer on a 2002 JVC AV-32320 is blinking. Could this be a fuse? most likely something is broken and needs replacement inside. What are the most likely items to be fixes? It also makes a steady...
Hi, my name is John. Welcome to FixYa. Its not a fuse. It has went into stand-by mode, how many times does it blink? Thanks for choosing FixYa...John
Nov 24, 2010 | JVC AV-32320 32" TV
The picture is to big for the screen it doesnt
Get into setup for zoom function. Or, like my remote, the zoom fuction is right at the bottom with no menu to go to.
Jan 05, 2010 | JVC AV-32F475 32" TV
A black rectangle is displayed on the screen
the black rectangle appears as soon as the channel indicator goes off. someone has turned on the closed captioning in the menu of the set. it is in the "text" mode. go into the menu and turn off the closed caption feature.
Mar 20, 2009 | JVC AV-32320 32" TV
JVC TV with time displayed and will not turn off.
use your front control button to try to enter yoyr menu settings and if possible turn off display function.
Oct 22, 2008 | JVC AV-27D302 27" TV
No sound on JVC AV-48P575 48 inch rear projection TV
Try going into the menu and find something called, "center channel input." If it is on, the sound will not work. Turn it off, and the sound should be restored.
Mar 23, 2008 | JVC AV-48P575 48" Rear Projection...
Unlock JVC tv model number AV-32320
What do you mean by locked out? If you are talking about not being able to turn on the power without the remote hold down the power button on the tv itself for 5 seconds to turn it on. other than that you probably should get a universal remote.
Mar 07, 2008 | JVC AV-32020 32" TV
JVC AV-27D500 27" TV
The closed caption or PIP functions in mostly all sets are only acessable trhough the menu.. You need the original remote to do this. If you dont have one go to http://www.remotes.com or call 1-800-remotes for inexpensive exact replacement remote controls. If you do have the original remote and can acesess the menu but the features are not there then theres a problem with the sets built in firmware and the only way to fix this would be to replace the sets microprocessor IC. Good Luck
May 21, 2006 | JVC AV-27D500 27" TV
JVC AV-32320 32" TV Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
