Question about True T-49 Side by Side Refrigerator Commercial
T49 True Refrigerator turns off by itself, breaker not triggered
When I flip the breaker off and on it goes back on even though it does not show signs of breaking. Could it be a thermostat causing it to shut down?
Made sure the compressor was vacuumed out and clean.
  • 51 Answers
There are several things that could shut off your unit. If you are shutting the breaker off for longer than a few minutes, the compressor might be cooling off during that time, thus allowing it to turn back on. It also might be shutting off because of the pressure switches located on the refrigerant lines. Please let me know if you need anymore information.
Posted on Feb 20, 2009
Why do I have very large temp variations in my Truet49Comertial refrigerator. and is the fans suppose to run continousley.
the fan only turns off when it goes into defrost cycle. the temp variation can be due to the settings of the cold control and the air flow knobs they should never both be set to high but best to keep them at medium setting
Mar 09, 2015 | True T49 Commercial Refrigerator
What is the part number for timmer control of the T49 two door freeze
is it a Refr. or a Freezer for mthe freezer you can use a paragon model 8141-00-oem D-frost-o-matic timer control................good luck
Jun 15, 2011 | True T-49 Side by Side Refrigerator...
My dry quite working after my was work in electric box he was flipping power on and off
Your dryer is a 220 appliance and should be on a circuit all by itself. Are the items in your circuit box labeled (Lights? kitchen, etc.) One should be labeled "dryer". If you cannot locate one that is labeled for your dryer, Check out the position of the circuit breakers. If the dryer breaker is turned off it will be in the oppoite postion of the others.Caution: DO NOT do what he did and begin flipping breakers! If your dryer breaker is in the off position,is you should be able to flip it back on. Before you do this, have the dryer turned off.
If this does not work, unplug your dryer and leave it unplugged for 5 minutes or so, so that the dryers' operating system can reset itself. Then try turning it back on.
Dec 16, 2010 | Maytag Dryers
Compressor runs for few sec. fans inside dont turn on at all
hi there, circulation of air inside the refrigerator run complete the cycle of refrigeration.if no fan your compressor motor trip off.there are fuse that hold the line connected to fans this was located at the backside of refrigerator,have check on this. replace the fuse.fix my rate have a nice day.
May 14, 2010 | True Food VWR Storage Refrigerators with...
My thermostat went bad on my T49 and was
you might have a leak going on clean the coils and check the fan.
Dec 01, 2009 | True T-49 Side by Side Refrigerator...
My samsung refrigerator model RB1855SL is experiencing a temperature sensor issue. The freezer target temp is set to zero degrees and the refrigerator to 38. The unit cools itself down to the target...
We've had tonza problems with ours too, kept building up frost, temperature sensor acted up as well. Piece of trash if you ask me. Never fixed it (did not want to throw money at it). Amazingly we just got a new one... another Samsung.... (with 4 yr extended warranty though this time!)
Oct 13, 2009 | Samsung Refrigerators
Refrigerator not cooling properly.
upper part feeses and bottom not verry cold at all
Aug 16, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
The outside unit won't shut off, even when the blower is not going. I flipped off the breaker and cleaned the coils. When I turned the breaker back on, the unit came on, even though I turned off the...
Your contactor points could be welded together and not releasing. Turn off breaker again and open the electrical cover to condenser and inspect the contactor. Look for blacken or fuzed points. If they are then get a new contactor let me know if you need any help and will get back to you. ken
Jun 06, 2009 | Heating & Cooling
True T-49 Side by Side Refrigerator Commercial Logo
185 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
