Question about EliteGroup RS482-M754 Motherboard
Cpu freq lost
About once a week while booting I get the message that it is going to boot into safe mode. I can either boot in safe mode or go into bios and set the cpu freq. I reset the bios to the safe defaults and everything seems to be ok for about another week.
  • bbranan Dec 02, 2008
    If it were the battery the problem would only occur after unpluging the computer and also the time and date would be lost.
  • 781 Answers
Try changing Motherboard BIOS battery
This is a small shiny button type object about 15 to 19 mm across you need to get the correct number battery
Posted on Nov 25, 2008
My comp says i need to turn off safe mode its preventing certain things from loading
Hi, open your computer in safe mode and uninstall some newly install software. Otherwise--
  • Turn on CPU.
  • CPU will be start booting. Red/yellow light will be blinking. If yes then check your monitor light will be fixing and Show *********** Board.
  • If shows and your OS will be Booting and fail to start.
  • If yes you can repair it.
  • Insert OS disk into the DVD driver.
  • Turn off PC.
  • Turn on
  • "Press any key........" when comes this message you press any key.
  • After that you can see two option
?? Fresh copy Installation OR
?? Repair Option
  • For Repair Press "R"
  • It will be start repairing
Thanks.
May 17, 2011 | Computers & Internet
I set the normal mode to safe mode,but i dont know how to change back now
This happens when set you PC on Safeboot Option.
Follow the steps mentioned below to boot in normal mode.
1: Once you are in the Safe Mode, Click on Start and then Click on Run.
2: Type msconfig (you will see system configuration utility).
3: Click on Boot.ini tab and check for the Boot Options.
4: You will see Safe boot options check.
5: Uncheck it then click on apply and then then ok.
6: Now your computer will boot in Normal mode.
Once you reach the desktop you will again see the system configuration utility screen. Just check the option don't show this message again. You are all set.
Dec 15, 2010 | Computers & Internet
Hi, Everytime I turn on my DELL Dimension 5150 I am faced with the following message: A problem has been detected and windows has been shut down to prevent damage to your computer. UNMOUNTABLE...
This sounds like it can not mount your boot file from hard drive which needs to load windows. Sometimes this will happen if you leave a floppy, cd or some kinda usb flash drive in computer when rebooting and it does not happen always. I would try to boot in to safe mode as message is saying. To boot in to safe mode modet computers use F8 key. Turn off your pc and then as soon as you push power button start tapping key F8 located on top of keyboard. You can stop once you get screen that says Advanced startup menu. Choose option Safe mode and press enter. You will need to use arrows to make selection. Once you choose safe mode wait for the loading to be done and then choose ether your windows name or Administrator. Once in safe mode you will get error message just ignore it and press yes. When windwos comes up try to do a restore to previous date. Go to start-programs-accessories-system tools-system restore.in system restore choose restore to earlier time and on the calendar choose date that your computer was working fine. I usually go even week prior to when computer stopped working. Your data will be saved but if you have installed some programs you might have to reinstall them. Hope this helps.
Nov 06, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Wont boot up says a disk read error occurred. press ctrl alt del to restart. i do this and the same message comes up
your operating system files is corrupt, that's why your computer is showing you that message.Your computer cannot but except the it is repaired.
To repair your windows, you will need the Cd that came with your computer, that's what you will be needing in other to repair your system.
Also, you can still boot your system by booting in safe mode. To boot in safe mode, restart your computer and immediately, keep pressing "F8" on your keyboard, a black screen will come up and you will see a booting option, scroll to safe mode and press enter.
Once your system boots up in safe mode, you can restart your system and the problem might be solved.
Take care.
Jun 01, 2010 | Toshiba Satellite A135-S2386 Notebook
My ViewSonic computer monitor keeps displaying a Vga Not Support Message upon booting then the message Out Of Range comes up on a completely dark screen. Need Help
It sounds like the computer is trying to use a resolution that the monitor cannot handle. Boot into safe mode by pressing the f8 key during boot up and select safe mode. Once booted, right click on the desktop and select properties. In settings lower the resolution by moving the bar to the left and reboot.
I would move it all the way down, you can then move it up a step at a time once you are in normal mode again.
Hope this helps
May 02, 2009 | ViewSonic VA721 17" LCD Monitor
Computer boot up
This looks like a problem with you video card drivers. I had this problem last week! ;o) The screen turned off while in the Windows logo.
You need to boot in safe mode and reinstall the drivers of your video card.
TO BOOT IN SAFE MODE :
Boot your computer and tap F8 every seconds. If you get to a blue "boott selection screen", press ESC, and restart pressing F8 every second. You will get to a black windows selection menu with the arrows. Select the boot in safe mode option and press enter.
ONCE IN SAFE MODE:
In XP, once in safe mode, you PC will boot with minimal settings and default drivers. Go to START, CONTROL PANNEL, SYSTEM, HARDWARE, DEVICE MANAGER. You should see your display adapters in there. If one has a yellow exclamation mark, then you need to re-install the drivers.
TO REINSTALL THE DRIVERS:
You need to find the graphic card CD you had when you purshaed it, or download the drivers on the internet. Go to a friends house, and download them on your manufacterer's website (ie : ASUS, ATI, etc.). You need to know your card's model name for that. It should be in the Device Manager, where you looked earlier (Ex: ASUS MAGIC 128MB)
Once you reinstall the drivers, you should be ok.
Worked for me. It makes sense because the screen turns off when it tries to load the currupted drivers.
I hope it helps.
Dec 31, 2008 | Computers & Internet
I just installed xp pro and it keeps freezing
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
I would suggest that you run only one stick of Ram at a time to determine if they are the problem.. Also these CPU's had heat problems that damaged the cpu. This also causes freezing. I would consider resetting the CPU and the heat sink, and case fans are clean and working.
Dec 10, 2008 | Computers & Internet
Have an old Gateway PC - message "FREQ. OUT OF RANGE", then the screen goes blank
Start tapping the F8 key during boot, and choose Safe Mode right click on the desktop to get the dropdown menu then go to properties click on the settings tab then the advanced tab then the monitor tab and lower the screen refresh rate click apply
May 07, 2008 | Computers & Internet
UPGRADING PROCESOR
Make sure your BIOS can handle an upgraded CPU. I would go into bios, check the "default" or "fail safe" boot option and then power down. Lift keyboard or access your CPU and change out. Remember to touch something metallic before you operate so you discharge any static electricity (killed a CPU and a video card by not doing this ONCE) Boot up and notice any BIOS messages, may want to start in safe mode just to get a basic working config going, then power down, access BIOS and start getting it back to your best config, maybe stepping one item at a time, rebooting and continuing until you get a stable platform.
Jan 22, 2008 | Sony VGN-S150 MBX109 (M9_32 (A1072469A) PC...
When i start my computer it doesn't open windows, well it basically does all the booting up and up until it has to say "welcome" it then presents a black screen with the message: input signal out of range....
The video driver isn't set up correctly for the computer. You need to boot into safe mode - after powering on the computer, press the F8 key. You will be shown a menu. Choose Safe Mode with networking. The computer will boot using a very basic video driver. Right click on the screen and select properties. Click on the advance tab. Click on Driver => Advanced => Update driver. Once the driver has been updated. Go back to the drivers tab and click on mode. Select one of the modes. Close everything and restart your conmputer normally.
Oct 25, 2007 | Dell OptiPlex GX260 PC Desktop
EliteGroup RS482-M754 Motherboard Logo
65 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
