Hi, I got a serious problem with my PC. The PC was working as "normal", but the monitor display was not "perfect" :-). So I went to control panel->display->setting->advanced->monitor. I cannot remember what exactly I have done, maybe I disabled the only monitor, which is the "default monitor". Then the computer automatically re-started. When the window come-up, there is no display on the screen. I think the computer was started correctly, but just no display. By now every time when the computer was started-up, I can still go the Bios setting screen by press the "del" key. But the worst is coming. I went into Bios setting and did some changes, which I hope can help me to restore to the display setting error I made before. I am obviously wrong. Now there is absolutely now display any more. I even try to insert the window operation system CD to re-install the system, but it never works. I am in absolutely desperate status. Can you let me know how to fix the problem if it is possible? :-) Thanks, Mike
  • mike2008p Nov 26, 2008
    Hi Dave,
    It works! Thank you very much for the help!
    I basically followed your option 2). A slight variation is that when I choose the "safe mode", the computer went to start the window and then screen became blank again. However it did not bother me too much on this. The important thing is now I can see the bios screen so that I can choose to boot from CD drive. Since I do not have much files needs to be saved in my harddrive, I re-install the window operation system from CD and now I can use my computer again.
    For your information, I can now recall what error I had made about the display configuration. I went to Display Properties.Settings.Advanced.Adapter.Properties. Under Devices usage, I choosed "Do not use this device(disabled)". Then the computer automatically restarted and the display gone. Maybe this is also the reason there is display even if in "safe mode"?
    Anyway thanks again for your help.
    Mike
    Sergeant:
  • 207 Answers
Mike,
I'd have to know the manufacturer and model of your PC to know for certain if this is the case. But based on the information I have, heres what I think happened.
Your 1st symptom sounds like you accidentally adjusted the resolution to something the monitor couldn't display. Which I could've walked you through starting up the computer in "Safe Mode" to resolve. But 1st we have to fix the BIOS setting.
If my theory is right this will be easiar to fix than you might guess. What I think happened is that your Computers Motherboard has an onboard video card. Now if your Monitors cable is plugged into a card in your expansion slots, then its as easy as moving the cable to Another VGA connector by the Mouse and Keyboard connectors, and then go into the BIOS and change that setting back. If you are currently plugged into THAT connector, then it's a little more challenge.
You have two options to fix this situation
1.) Get a video card to plug into your video card SLOT (There are a variety of slots that could be installed, If you have the Manual it can tell you what type. If not Message back here and I can look it up for you. Make sure you get the RIGHT card for that slot) Plug your monitor into that and you should get a display again. (If you borrowed the Vid card from a friend change your BIOS back. If you purchased a NEW card it is likely better than the ONBOARD so leave things as is)
or
2.) Unplug the computer. Open up the case, there should be a silver disc (Watch battery) on the Mother board. Pull this battery out. Near this there should be 3 pins sticking up with a label of CMOS. There should be a plastic block (Called a jumper) connecting the middle pin to one side. Move this jumper so it connects the OTHER side to the middle pin. Now let the computer sit for an hour. (This clears the settings in the BIOS so they change back to the factory defaults)
After the Hour move the Jumper back to its previous position, put the battery back in, close up the case, plug it back in. Now for the moment of truth, Fire it up and see if we have a display.
NOW that the BIOS is resolved back to the first problem
Boot up the PC just after the company logo disappears push <F8> to bring up the Windows startup menu. Select "Safe Mode" from this list
Once the computer starts in safe mode go into the display settings screen. There is a slider there, for now we're going to set it at a modest level 800X600 (Most video cards can easily display this resolution) Now restart the Computer and you should be able to get into Windows as normal, Where you can set you display to your liking. If the problem reocurrs simply use safe mode to correct it again and the setting just before the one that blanked your screen is Likely to be the MAX that the monitor can handle.
Hope this helps
Dave
Posted on Nov 24, 2008
Soyo monitor MT-NI-DYLM1998 "out of range."
Your windows 7 screen resolution is set too high and your display doesn't support it. There are 3 possible solutions to this problem:
1. Press F8 during startup and choose "Enable row-resolution video"
2. Press F8 during startup and choose "Safe mode" and change screen resolution there, then reboot.
3. You can always use another display (if you have one) to set screen resolution to lower value.
Oct 15, 2012 | Soyo Computers & Internet
Hundai Imgaequest L70N keeps showing " video mode not supported"i What went wrong? . It is in standard refresh and I can't change it. I can restart in safe mode but then what+
If you restart in safe mode, you need to go to the display settings, and choose a resolution that will work. When you restart back into normal mode, this setting should be retained, and you will be back to normal.
Aug 04, 2011 | Hyundai ImageQuest L70N 17" LCD Monitor
The monitor suddenly went blank and displayed "no
no signal coming out from the video card input to your monitor. better check if the vga cable is properly fix on the video card and the monitor. you may need also to disconnect the video card from the motherboard and reseat it properly.
just make sure computer is turn off when you do this.
let me know if i can help you further.
Feb 01, 2011 | HP Pavilion a1210n (ED895AA) PC Desktop
Try to pull out video card and clean the slot on motherboard then put video in. If no result replace video card.
Feb 01, 2011 | HP Pavilion 6730 PC Desktop
Hi, i have an Acer Aspire 5735. Most of the screen has gone black apart from about 3 inches on the left hand side which are perfectly normal. I've connected the pc to my lcd and it works fine on there. Can...
Connect your laptop to an external monitor and I expect you will find it is displaying OK on the external screen.
Browse ebay for a replacement screen.
Dec 15, 2010 | Acer Aspire 5735 Notebook
Acer Aspire 5050 screen is blank
Hi, if it works with an external monitor it's more likely an LCD problem. When you push the power button, noting comes up on the main LCD screen? not even the Acer logo etc.?
Did you set your video card to use an external monitor and disabled the primary LCD? If so, you need to go to display settings, advanced and go to ATI Display and make sure that the notebook monitor is on.
Apr 02, 2009 | Acer Aspire 5050 5430 Laptop
Why is my Monitor blank when i switch on the pc?
Normally, blinking indicator lights and no display on the monitor indicating a wrong resolution or refresh rate frequency, that the monitor can not display it.
To fix, enter safe mode, and configure the display to the lowest resolution. After restart, you should be able to have the display.
Dec 31, 2008 | Intel D945GCCR Motherboard
Hi, i have this acer 1912 19" lcd monitor, it won't turn on (actually it will turn on if i wait for a few hours). if i unplug the vga cable and press the power button, it will display "acer...
That's kind of interesting that it comes on after a few hours; what changes during that time, I wonder?  I also wonder what changed since it worked last, for example a power-manager utility on the computer side which isn't quite compatible with the videocard; it seems unlikely though.  So; please describe what happens over those hours: is there a profoundly blank display, or generally dark display with no backlight?  Does it just pop back to perfect operation, or is the backlight out (as if the monitor's sleeping, though the power LED indicates awake) and eventually coming on so you can see what's there?
  I suspect that the backlight is starting to go and the startup circuit (which takes the most stress) is cutting that section out of operation for a while; perhaps the monitor's microcontrollers or a circuit protection device resets.  if you want to open it up you can clear out the dust and look how the backlight and its power units are fitted, and maybe take some pictures for reference, thermocouple readings (temperatures!) on the backlight power sections and backlight itself, solder wires on the backlight so you can get voltage and current readings, and get the backlight make and model.  You can probably convince the same backlight to go for a while longer by cleaning up the supply circuit and replacing a component (FET or circuit protection VOM) that's too hot because of its own derating.
Jul 16, 2008 | Computers & Internet
Computers & Internet Logo
61 people viewed this question
Alun Cox
David Payne
David Payne
