I got a peavey rage 158 practice amplifier but it makes bad noise
Whenever i use the clean channel theres way to much feed back, i get awkward osselations and popping sounds. it also cuts out and makes really really wierd noses when ever the instrunment cable isnt sitting just right! itss pissing me off ... SOMEONE HEEEELP
From what you're saying, it sounds like it's a problem with the cable itself. It can be explained by insulation problems or otherwise. First thing I'd try is a new cable. If that doesn't fix the problem it's most likely either a problem with the guitar input of the amplifier's imput. If that's the case, either or may be loose and can be fixed by simply tightening both. If none of these solutions work, its most likely an electronics issue- although I wouldn't jump to that conclusion. Hope it helps
Posted on Jul 08, 2009
Er a *** my bro get new ****
Posted on Jan 09, 2009
Hooking up other external systems
Peavey XR 1212 You may find helpful info from the Peavey site. I'm not sure how you want to configure your setup, but the tape out may be able to feed the power amp.
Mar 24, 2014 | Peavey XR1212 12 Channel Powered Mixer
Peavey Rage 158 guitar amp
I don't believe there is a power "outlet" on this, only an "inlet".
Usually the inlet will have a lead, often green, that goes to the chassis.
There will usually be two other wires, often black and white that connect to the other two pins.
From the back of the connector, with the center pin tied to the grenn wire of the triangle lower, the pin to the right should be the white and the pin to the left is the black wire
Jul 24, 2010 | Peavey Kb2 1x10' Keyboard Amplifier
Peavey cs800x a channel drive board what goes bad?
A bit late, but I'll give it a try.
You can measure the outputsignal before the relay.
Often there's a coil, measure if you've got a DC level at that point.
If so, you're power amp is down.
Normally when the relay doesn't switch there's a DC level in your amp.
Cheers, Gerard
Sep 07, 2009 | QSC MX1500A 2-Channel Amplifier
Change the voltage from 240v to 120v
Unless there is a 240/120 switch on the back, this amplifier cannot change voltage. The only way is to replace the power transformer, and when you do that you need to use the exact model transformer Peavey uses for the 120 version. I have also seen differences in handling power outside of just a different transformer for USA/Euro models.
The differences between these two market models might be beyond what is cost-effective to convert.
If it is the Peavey blazer 158, they go for as cheap as 100 bucks here in the states. Or buy one new for 120.00 bucks and 4.99 shipping: http://www.dcmusicstore.com/Peavey-blazer-158-guitar-amplifier
Best advice: sell it for what ever you can get and buy one here.
Hope this helps!
-mike
Mar 28, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Mic feedback. I sing on a shure beta 58 mic, into a 350 watt peavey amp, into 2 - 200 watt peavey speakers. My band is loud, and I simply cannot get my mic loud enough for them to hear me, without constant...
It sounds as though you are pointing the peavey at the band in a practice situation? If so make sure that each speaker is at about 60 degree angle to either side of the back of the mike (you facing the speakers), most mics reject feedback when the the user is directly in front of a monitor, but Beta 58s' tend to feedback more in that situation. Alternatively (if it is a practice room situation), why not place the speakers behind the band at 60 degrees each and turn to face the band.
Mar 12, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Need the instructions for a peavey 158 Rage amp
Here is the link to the Peavey 258 Rage. The difference is the 158 is 15w and the 258 is 25w.
http://www.peavey.com/assets/literature/manuals/00583600_4.pdf
Dec 27, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
A Buzzing noise from my Reverb section of the amplifier
i am sensing 60 cycle hum. the reverb will draw more power. i would try what is actually powering the units. power strip??? off of an unknown amperage power outlet? if the electrical system that feeds the a/c outlet is ran in series, you may not be getting enough juice or the outlets have bad grounds. i dont see a capacitor causing the buzz noise, but more of a pop and then sudden loss of signal. may be a resistor. also if you have a reverb tank the lines maybe mixed up in/out, or the tank is going bad.
Nov 16, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
When I turn the power on on my Peavey blazer 158 guitar amp nothing happens. Is there a fuse?
Hi I have written two troubleshooting guides on the issues you have try them at http://www.howtodothings.com/electronics/how-to-fix-the-fuse-on-your-guitar-amplifier
Let me know if you still face a problem
Oct 13, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
530 people viewed this question
 Grubhead
Grubhead
