Question about Makita AN901 Coil Nailers
I can't get the Makita AN901 to fire nails consistently
We have taken delivery of two AN901 coil nails and are using them with a 2.5" annular ring shank grade 316 stainless steel nail. We can not get the gun to fire the nails in consistently.
In essence the gun fires the first nail in more or less to the correct depth then the next few nails are only part fired home, in some cases it will not fire a nail and the piston comes out and strikes the wood. When the nail is fired in the piston leaves a mark in the board, occasionally the wood is also splitting when the nail is fired fully in.
Any help or advice would be much appreciated.
Regards
K
  • zmq78 Nov 24, 2008
    We have changed the firing mode to Bump (single) This had no effect.
    We also tried various depth settings from 1 to 6 again without success.
    Sergeant:
  • 276 Answers
This problem occurs due to the use of wrong type of nails.
Posted on Nov 25, 2008
  • 4,806 Answers
Have you adjusted or changed the firing mode to Sequential or Bump ?
Posted on Nov 24, 2008
  • Lee Hodgson
    Lee Hodgson Nov 24, 2008
    i take it you have the user manual, but if you don't get it free from here:
    http://safemanuals.com/user-guide-instru...
    regards
  • Lee Hodgson
    try altering the PSI i know it operates at 65 to 120 psi, also are you using the right nails?
    these are the nails it supports, standard 1-3/4" to 3-1/2" coil framing nails
    regards
Coilated framing nailer will drive 2 1/2 nails but gun jumps and only sets nail about 1/2 way in with 3 1/4 nails with full airline pressure.
Hi Paul,
The reason is that you are allowing the nail to "push" you off the wood when the tool fires. Probably you're using a very hard wood with a ring shank (Annular) nail. The best way of overcoming this is to push just a little bit harder down onto the tool before firing.
We see this quite often when people are just starting out with these tools, don't worry though, it gets better with practice!
Dec 31, 2014 | Air Tools & Compressors
Paslode 900600 Trim nailer not sinking nails
The firing pin can be completed or part of it crooked worn and can have a little burr on its way and stuck in the cylinder somewhere o-rings worn and hardened, have a tilting piston on the firing pin somewhere in the cilinder
Jul 27, 2017 | Air Tools & Compressors
My makita an451 roof nailer keeps shooting 2 nails I've tried 2 different brands of nails
Nailers that use strips of nails (one nail directly behind the other) will sometimes drive two nails at once and is caused by damage to the driver. The nails are so close together that the driver will hit the first and part of the second nail head. Coil nailers, as your an451, use nails seperated by welded wire making it very difficult the the driver to hit the second nail. Usually when a coil nailer shoots two nails, it is acutally the trigger valve that acutates twice (two very rapid fires). Two very rapid fires is caused by faulty trigger valve. I have seen a roofing coil nailer fire one nail and a second nail drops out of the gun. Caused by weak / malfunction of nail feeder or wire used to weld nails together is too thick.
Sep 17, 2011 | Makita Roofing Coil Nailer AN451
Nails don't feed
could be a couple problems. First are you using the right collation nails and do you have the tray set for the nail length. Second, remove all the nails and open up the feed door and check to see if the spring is still on the feed pawl. Then what I would do is get a block of wood and dry fire the tool lookng for the feed pistion to snap back and forth freely, if it moves slowly could be an o ring that is dry or something got into the air passage causing this. Let me know if you need more assistance.
Feb 12, 2011 | Makita AN611 Siding Coil Nailer
Shoots two nails at a time, gun jams
I found the solution to the double shooting happens when the retainer ring on the feeder paw inside half of the coil nail holder. Part #92 (962112-6) retainer ring R-22. I found the clips broken in two of my guns. Now they work great.
Oct 18, 2010 | Makita Roofing Coil Nailer AN451
Remove boards fixed with ring nails
you need to punch these nails through... unless there are thousands surely this is better than a plug cutter? i'd get a nice cheap phillips screwdriver and bust off the resin handle to make a decent large blunt punch.
Oct 04, 2009 | Drills
Need tofind a used nose peice
This solution may sound way out there, but generally nose pieces are expensive, so you may want to go hunting through the pawn shops for the same model, in crappy condition, in order to get one
Jul 12, 2009 | Makita AN901 Coil Nailers
Makita AF503 Brad Nailer won't fire nail
Take head off of tool. Clean and lube orings on the head valve . Do not use wd40 use air nailer oil.
Apr 11, 2009 | Makita AF503 2'' 18 - Gauge Brad Nailer
Makita AN 901 framing nailer blows nose end apart
not too familiar with makita brand nailers but jams are usually caused by cheap nails but I see you have tried senco brand which is a good brand sounds like a mfg defect try using hitachi brand nailers they are good
Dec 26, 2008 | Makita AN901 Coil Nailers
Makita AN901 Coil Nailers Logo
79 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
