Question about Dryers
My Kenmore 80 series quit working suddenly after removing a piece
Of clothing and turning back on. I basically took it apart and removed all lint even around the motor. It will run for about 2-3 minutes then quit again and will not restart untill it has sat for a little while. Also it now squeaks loudly when first starting back up. Please help.
    Genius:
  • Dryers Master
  • 1,198 Answers
This puppy needs help. You're going to have to take it all apart. Check all roller wheels, find heat resistant grease. Maybe graphite will do. With the belt off, spin the motor by hand, it should roll freely. If not, first feel for worn bearings by trying to move the motor shaft up and down. I've never lubed a dryer motor. Replace it if you can! These motors are very generic, keep your eyes open for replacements by the road if that's your thing. Sure works for me. When re-assembling check the front sliders for damage or misplaced felt, if your unit doesn't have wheels there. The drum should not rub stuff it's not supposed to. Make sure you are putting the belt on right. And of course check the fan area for loose stuff.
Posted on Nov 25, 2008
DRYER MAKES HUMMING NOISE BUT WONT START
Sounds like the capacitor on the motor is faulty
Mar 21, 2014 | Kenmore Series 70 80 90 PN281798 Dryer...
Kenmore 80 series electric dryer. metalic sound/burning smell
drum bearing on the rear has gone making the front of drum rub on the caseing re metalic sound
Aug 17, 2012 | Kenmore Dryers
I have a kenmore 76712. clothes only gets warm but does not dry even after 3 cycles. I have looked in the back cabinet and i see the ignition working and lighting up. But it goes off after about 5-8 secs...
The unit must be taken apart to clean. Also the duct work (vent tube) will have to come completely apart for those tubes will be solid full of lint as well. That is why the dryer is not drying your clothes. I guarantee you will find a handfull of lint for every foot of tubing you have. OInce cleaned the dryer will operate like new again
Apr 21, 2010 | Dryers
Kenmore Series 80 gas dryer, clothes take 3 hours to dry
Hello, This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis The coils are mounted to the gas safety valve, This should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Nov 04, 2009 | Kenmore Dryers
My Kenmore dryer keeps cutting off
Vacuum all of the air passages including the hose to the outside vent. Remove the lint filter and wash it in hot water and detergent; rinse and replace after drying. Restricted air flow may be tripping an over-temp switch.
Oct 12, 2009 | Dryers
Something in vent
id screen is on top remove the 2 screws under screen lid remove back cover ..remove the 4 screws holding bottom portion of screen housing over blower pull out and clean ..if screen is in door remove bottom cover (clips top edge press down) remove lint screen remove 2 or 3 screws holding housing to blower
Nov 26, 2008 | Kenmore 62802 Electric Dryer
Dark stains on some clothes after drying
I had this same problem. I turned out to be the seal around the drum. You have to remove the drum and put in another seal. Not real hard to do. You can order the seal from sears and I think the glue came with it. Just have to remove the lint vent screws and then the top lifts off. then remove the screws to the front panel. Hold the drum because it will fall. Unhook the belt. Remember how it connects. Then take the drum off and remove the seal and as much leftover glue and fabric. Glue the new seal on and let dry. I did overnight. It should have directions. then replace everything. just make the seal is on the same way you took it off so look at everthing before you remove anything. Once the seal was replaced no more stains.
Nov 21, 2008 | Kenmore 65924 Electric Dryer
Kenmore 80 Series Heavy Duty Dryer won't work
hi thanks for the question the belt has probably broken there should be a bottom panel use screw driver to pry the front on each side pry outwards remove panel now you should see a broken belt replace thanks the appliance dod
Sep 25, 2008 | Kenmore 63942 Dryer
Kenmore Series 80 Dryer. Heats doesn't spin clothing. Imagine its a belt or spin motor. Need a schematic
No need for a schematic, there are two kenmore dryer belts, 'full size' or 'apartment size', if it is a belt you will be able to here the motor racing unloaded, turn heat to cold before testing, dont want to blow a thermal fuse.
Kenmore dryer comes apart from the front,
  • UNPLUG dryer 220V is not fun
  • remove the lint screen
  • remove the screws under the lint screen holding the case top to the screen holder
  • with a putty knife or other blunt blade release the catches at the front corners of the top and raise top
  • remove screws holding front of case on, from inside the dryer
  • remove door switch cables
  • lift front of case off and set aside,
  • can reach motor, belt, felts and rollers.
  • broken belt will be obvious, lying on the floor
If belt is broken, examine rollers and felt bearings for wear, stuck rollers or no felt left, is the most common cause of belts breaking, extra tension is required to spin the drum, If damaged replace them, they are cheap and easy to do, and it woud be no fun if another belt broke quickly
reasemble after repair in reverse order.
Aug 25, 2008 | Dryers
Dryers Logo
110 people viewed this question
Top Dryers Experts
