I have a 2004 Hitachi 51G500A rear projection TV. The TV Flickers up and down and screen is shifted to the right w/ red color dominating the screen. Under the assumption and the advise of a "Tech" was advised it was the IC's Digital chips. I replaced them by soldering the new ones to the board. It took about 4 total to do it. With much dismay the exact same screen appeared. Can anybody recommend some other solution??
the last hitachi that had this problem i fixed it bad finding bad solder conenctions throughout the board that the convergance ic's are on, also i foind some on the two main board in my repair. hopefully resoldering the convergance foard will fix the jitter or jumping around problem. if the picture is too red you can also try turning down the screen control slightly. good luck
Was this helpful?
Yes
No
Popular Solutions for Hitachi 51F500 51 in. Rear
Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
Solution for ''how to fix a tv that has been bumped and the screen and there is a red line and is...
(More)
Solution for ''how to fix a tv that has been bumped and the screen and there is a red line and is messed up''
horizontal lines located at the top and bottom of the screen. for hitachi 51f500 in. rear projection...
(More)
horizontal lines located at the top and bottom of the screen. for hitachi 51f500 in. rear projection hdtv
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
