Question about Husqvarna Designer I
Can't update my new husqvarna diamond embroidery machine
Error message- VSM reader/writer and Embroidery machine USB driver type a
the data area passed to a system too small
  • 1 more comment
  • gmford1 Dec 16, 2008
    I have the same problem with my diamond. I have a new 64 bit vista system and get the same error no matter which driver I try to install ...the 32 or 64 bit drivers and I used the disk that came with the machine. It worked fine on the old system
  • Anonymous Jan 30, 2009
    Please help with this problem, I cant buy a new sewing machine right now.
  • radcal May 11, 2010
    Have you installed the drivers from the cd that came in the box with the Diamond?
Thanks for the response. The problem turned out to be my fault. I had my Diamond connected to my computer when I tried to install the drivers. As soon as I disconnected it, the drivers all installed and everything is fine.
Posted on Feb 27, 2009
    Sniper:
  • 87 Answers
I have seen this before. You can't have 2 differnt parts of the software installed and have it work. If you had an SE then got the Diamond. It can cause this. I had to uninstall all my 4D software and drivers and reinstall them. in the right order and then it worked.
Posted on Mar 18, 2009
    Problem Solver:
  • 5 Answers
It sounds like the problem is your operating system (Vista) not your Viking Diamond software.
Using 3D software with 4D reader/writer on XP operating system. Getting error message "reader/writer not found" "VSM reader/writer & embroidery machine USB driver Type A" If I...
Hi Sheila,
Click on start, click on My computer, then look in the left hand menu for View system information and click on it, click on Hardware, click on Device Manager, your VSM reader should show under Universial serial bus controllers, normally at the bottom of the page. If there is a yellow ? mark next to it, it means the driver has not been installed successfully. If so, double click on VSM reader, click on driver, make sure your software CD is in your cd drive and click on Update driver. Should solve your problem.
Aug 31, 2011 | Husqvarna Viking 1
I have not used my Husqvarna reader/writer for a while. I put the program on windows 98 because I bought a new Mac, and it says the reader/writer cannot be found. Therefore I cannot get my embroidery on...
You might just need new drivers for the reader/writer. Try the Husqvarna website first, or else do an internet search for "Husqvarna Reader/Writer drivers" or something similar. Is the reader/writer a USB or serial connection? You are going to have problems if it is serial and I am not sure there is a solution, but USB connection should definitely be able to get working.
Nov 14, 2010 | Husqvarna Designer I
Hello, I am hoping you can help me with this. I have recently installed 3D Professional (ver.7.2.51.1) running with Vista. Everything runs, with no apparent issues at this time. I had to get a parallel...
I dont believe the parallel reader writer will work with Vista. You need to purchase a Husqvarna USB reader writer and problem will be solved.
Good Luck
Oct 17, 2010 | Husqvarna Viking 1
I have a Husqvarna 1+, how can I connect my laptop to it to download embroidery designs?
Sorry,... there is not a connection to allow you to do that. However there is a Reader/Writer unit that you can plug into a USB port on your computer and write a design to the card that comes with the reader/writer and then put the card in the machine to embroidery a downloaded design.
Doug
Aug 05, 2010 | Husqvarna Designer I
4D d-card reader/writer - seems to be installed but not working
I have been having the same problem. I was told that the 4-d software is not compatible with Windows 7.
Mar 23, 2010 | Husqvarna Designer I
I am trying to hook up a reader/writer to my computer so I can use programmable embroidery cards. In what order should the cords be hooked up and to where. I can't get it to work. I get errors that the...
Your reader writer will not work unless you have the Husqvarna Viking software to drive it. The first level of the software is called 4D Embroidery. Their web site does a great job at showing the features and benefits. It sells for $400 and if you buy it from your local dealer, they usually offer classes. It is not difficult software to figure out.
Dec 30, 2009 | Husqvarna Viking 1
I need a driver for a husquvarna 3D reader/writer card, where can I find one
Info on Husqvarna Viking website - http://www.husqvarnaviking.com
When installing the 4D Embroidery System onto Windows 7 computers, the dongle drivers may not initially work correctly, as the 4D Embroidery System installs a set of dongle drivers which were created before Windows 7.
Download and install the latest dongle drivers prior to installing the 4D Embroidery System. Failure to do this, may result in the "Dongle driver not found (E0009)" when you try to open the 4D modules.
Please follow the steps below to install the latest dongle drivers BEFORE installing the 4D Embroidery System
  1. Download and install the latest Dongle Drivers.
  2. Insert your 4D Dongle.
  3. Install your 4D Embroidery System software (and all updates).
  4. Open your 4D Embroidery System software to confirm that your dongle is working correctly.
If you installed the 4D Embroidery System software before installing the latest dongle drivers and if you experience problems such as the error message "Unable to start hasplms service..."; download and install the latest Dongle Drivers.
Link to dongle drivers - http://www.vsmsoftware.net/downloads/HASP/haspusersetup.exe
Dongle issues - http://www.husqvarnaviking.com/global/8588_4197.htm
Good luck.
Dec 10, 2009 | Husqvarna Viking 1
Can't get computer and embroidery machine to connect via USB. Computer doesn't recognize embroidery machine. (Husqvarna Designer Diamond) I also have a new DELL laptop.
If your using Windows Vista, you have to have the multi user account in the off postioin. Also if you had 3D embroidery software and you upgraded to 4D software you have to be sure to uninstall the 32 bit drivers from the 3d for the 4d to work properly.
You do have to install the communication software that came with the diamond also. It won't communicate through the 3d or 4d only.
Jul 12, 2009 | Husqvarna Sewing Machines
Husqvarna Diamond Embroidery unit problems
Make sure that the red disk (smaller than a floppy) on the underside of your embroidery unit has been removed. Remove and discard the red disk. It is used for shipping purposes only. Joyce
Jan 10, 2009 | Husqvarna Viking 1
Connecting Reader Writer Box To New Computer
After checking with the Dealer, I was told my old Reader/Writer Box & embroidery software is not compatible with Windows Vista. I will have to purchase a new R/W Box which has a USB cable & a different type of dongle.
Feb 20, 2008 | Husqvarna Viking 1
Sewing Machines Logo
1,326 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
