Question about Toshiba TheaterWide 62HM84 62" Rear Projection HDTV-Ready Television
Horizontal lines I am having horizontal lines come on the tv after about 30 to 45 minutes into watching. the lines will only disappear after i shut the tv off. i have just finished replacing the lamp about a month ago then the lines started appearing about 3 weeks later. did everything the manual said and nothing.
    Sergeant:
  • 308 Answers
If this model has a "lint screen" or air filter, I would check to make sure the set is getting proper ventilation. Otherwise, you probably have a bad solder connection or capicators going bad, causing your symptoms. Hopefully you won't have to get a replacement Printed circuit board as they are quite expensive.
Posted on Jan 03, 2007
Picture goes into horizontal lines while watching then you shut it off for 10 min. or so and it resets it self
solder connections in horiz.drive/output circuit.also solder the flyback transformer.if only 10 minutes you need to solder in the
horiz.circuit area.get a magnify glass and usually will see hair line cracks around the
components.
Jul 17, 2009 | RCA TruFlat 27F520T 27" TV
Screen goes to horizontal line
Maybe the vertical IC got some cracked solder joints and the reparation worth it
Apr 24, 2009 | Televison & Video
The image disappears on my tv screen. A horizontal line appears.
You need to check the horizontal IC for deffects, possibly and most likely there are dry joints on the legs of the Horizontal IC. Have all the legs on the IC soldered nicely, this shud sort out your problems as you say you hit the TV then works. Try this before replacing the IC
Apr 16, 2009 | Televison & Video
Tv shows a white horizontal line and then shuts off
for sure the tube is bad be better off buying a new tv or find someone that has a tv repair shop
Oct 07, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
WHITE horizontal lines across screen
You need to adjust Screen voltage (decease a bit) to disappear white lines on TV. If you want to do it yourself, let me know to help you further.
Regards,
Aug 13, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Mitsubishi #VS-45605
We had a blue cone on the screen. We have adjusted the sharpness, contrast, and cross hairs. The cone has almost completely disappeared, but we still have blue shadows. Could this mean a blown color tube?
Any suggestions would be greatly appreciated.
Aug 13, 2008 | Mitsubishi VS-45605 50" Rear Projection...
RED LINES
Your red CRT socket may be loose or have cracked solder if not, try turning down the red gun screen control inside the set just a little. Youre experienceing what is known as retrace lines
Jan 21, 2008 | RCA P52771AT 52" Rear Projection...
Strong red tint with horizontal lines across screen
if you have warrenty, return it. if not, then buya new one...the video fuses are dying...hard to fix it.
Oct 06, 2007 | Akai PT4799HD Rear Projection Television
Toshiba TheaterWide 62HM84 62" Rear Projection HDTV-Ready Television Logo
107 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
