Question about Hitachi 60UX54B/55K 60" Rear Projection Television
Tv kit put in the kit same thing light on then off
  • 934 Answers
I'm apparently missing something, what kit are we talking about?
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
Posted on Nov 24, 2008
Akai PDP4204 has no picture. When its plugged in a flashes 5 red lights. Someone told me its the power supply i have checked some of the things that people say go bad on fix ya. I also was checking the...
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
May 09, 2011 | Akai PDP4294 42 in. EDTV-Ready Plasma...
The screen is dull and you cant even see it in the daylight. do i just get a new tv?
U can do some basic,repair like taking thing aparts,putting parts in or taking things aparts out of,wright?The tv have a CRT tubes coolant problems.Must be replaced it CRT tubes coolant.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a CRT tubes coolant kit to replaced the CRT tubes coolant.The coolant kit replacement,will come with an instructional CD too.
Oct 12, 2010 | Philips 60PP9352 60" Rear Projection...
My Magnavox 9P5511C102 color has faded any thing i can do to fix this?
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
Jun 14, 2010 | Philips Magnavox 9P6034C 60" Rear...
Power light flashes 3 times
You can get the CP150, CP120 and Cp114 repair kit at the following link which will usually repair that issue. Its at the bottom of the page under the RCA repair kits. The kit contains the capacitors and detailed instructions how to do the repair. www.tvrepairworld.com
Sep 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green diagonal lines across picture on Mitsubishi WD-52725 TV
If the lamp light turns red and the set wont power up put the V26 Power repair kit in and that should take care of it. The kit contains the capacitors and detailed instructions on CD
Jul 22, 2009 | Mitsubishi WD-52725 52". Rear Projection...
About a month ago my Phillips 55" widescreen projection TV started to have picture problems. On the left side of the picture it looked like the colors were spinning, then after a while the picture just...
I have a philips magnavox and had two problems that I recently fixed using kits from www.TvRepairKits.com. I can't say enough about their kits and help. Without them I would have never been able to fix my TV set myself.
The first problem I had was the TV was looking 3D. After doing some homework I found out that this is a convergence problem. I bought a kit, followed the instructions, and to my amazement fixed it myself.
After building my confidence with the 1st repair I decided to get their CRT fluid kit. This kit fixes the dull video,red video, or bright/halo looking video. If you have a magmavox set that is more than 5 years old your tv has this problem already. It happens on every set. As before I bought the kit, followed the instructions, and now my video looks factory new. Once again I wanted to say thanks to the team at Tv Repair Kits for putting together kits that the average joe can use.
ML
Jul 18, 2009 | Philips 55PW9363 55" Rear Projection...
Tv comes on but has no picture or sound
There is a board on the right side of the tv called the convergence bd
There are little connectors that are on the left of the board
the last one is the power to the convergence Ic's
That is the one that is closest to you. they are little black conectors with wires in them
Carefully lift it up
Then plug the tv back in and see if it fires up
If it does do not run it long
just enogh to see the tubes light
then shut if off
If it goes on
your convergence ic's are Shorted
They have a kit for this tv it is available through local parts distributors
If you can't find it locally just Google HITACHI CONVERGENCE KIT
If you are not good with de-soldering and soldering do not attempt this repair. Remember to replace all the resistors in the kit
If you are not sure about doing this repair you should have your local tv guy do it for you
If it does not go on then I would suspect the regulator in the power supply But
Most of the time it's the ics
Dec 08, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
TV quit no lights on front panel at all !
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
Sep 13, 2008 | Hitachi 60UX58B 60" Rear Projection...
Hitachi 50ux58k
You can get the parts from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix the following models (50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B).
Aug 27, 2008 | Hitachi 50UX58K 50" Rear Projection...
Hitachi 57uwx20b
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Aug 23, 2008 | Hitachi 57UWX20B 57" Rear Projection...
Televison & Video Logo
150 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
