Question about Copystar CS-2050 All-In-One Printer
Red and blue marks on copies
I have a copystar cs-2050. everything i print or copy, there is a red and/or blue streak of ink down the length of the paper. ive tried to clean out as much as possible but dont know where else to look.
  • edgalvan Jan 25, 2009
    i am not a tech but am an electrical technician. should be able to take apart.
  • jpd8 May 11, 2010
    Are you a TECH? Do you have the training to take machine apart? I am asking because I do not want to tell you something that you do not have the knowledge to do.
    Scholar:
  • 95 Answers
The CS 2050 is a mono color (black only) copier. There is nothing within this machine that I have EVER seen that has red and blue "ink" in it. I suggest you look at the paper that is in the tray itself. I have been on many service calls where the customer said the copier was tearing off a diagonal corner of the page, or the copier was putting something on the page that it was not capable of doing. When I looked at the paper in the tray I would find that the paper itself had the defect before it ever even went through the machine. Since there is 500 sheets per ****, and you may only see it on every 20th or 30th copy, you will have to either just try a new **** or go through whats in there 1 sheet at a time looking at both sides. But, if you find something that has blue and red ink within this machine please let me know.
Posted on May 21, 2009
Black streaks on both side of paper when copy on glass
Throwing the machine away is the best recommendation. You have a bad drum/developer that is leaking some toner. Could be a bad cleaner blade for streaks on the front; fallen toner for streaks on the back. Careful cleaning, replace transfer roller. First, check the condition of the fuser assembly. If the soft roller is bad it will leave toner buildup on the teflon roller, and vice-versa. Start there.
Sep 03, 2014 | Copystar Office Equipment & Supplies
Copystar CS-2050 cutting off edges when copying or scanning
Check your default paper size. It may have been set for A5.
Apr 07, 2014 | Copystar CS-2050 All-In-One Printer
HOW TO CHANGE LASER UNIT COPYSTAR CS2050
laser unit is under cover where copies exit, remove cover unplug laser unit and then remove 4 screws holding it down. replace unit
and scerws and plug in unit and replace cover and all is well
Oct 12, 2012 | Copystar CS-2050 All-In-One Printer
Kyocera Mita 2050 there are streaks of toner appearing on the pages printed.
If you send a print job or print a report from the copier and there is no streaks then the problem is most likely the thin **** glass to the left of the large glass. It just needs to be claened.
If the streaks are happening when printing and copying then the problem is most likely your drum unit (MK-410) or possibly the fixing unit (FU-410), the fixing unit is the one that gets hot.
As the drum gets old it can cause print/copy issues and the cleaning blade that cleans the drum gets to the point it doesn't clean the drum properly causing streaks.
The heat roller has a teflon coating on it and as the roller gets older the teflon starts to come off and can effect prints/copies.
The drum unit should be replaced every 150,000 pages and the fixing unit every 300,000 pages on the KM-2050.
I hope this is helpful,
Shawn
Nov 15, 2010 | Kyocera Mita KM-2050 Printer
My Kyocera Copystar CS-2114 Copier is printing a one inch black line of the left side of the paper
have a look at the scanner glass especially the thin strip glass this is the glass that is used when passing paper through the document feeder. if you do a copy from the main glass or print to it and no line apears there is probably dirt or tipex or a ink mark on the surfac, the other thing to look at os the drum charge unit as htese can sometimes fail to connesect correctly at the back and not sit tight in the slot this means the drum isnt charged on the edge.. good luck
Nov 17, 2009 | Kyocera Copystar CS-1620 Black and White...
We have a red line thru our scans? I have cleaned everything it says to clean?
red line? this is a black & white
is the line apear only when you scan ?
try and make a copy of the glass if you do not see line .than you problem is that **** glass that scanner uses.IT MAY HAVE WHITE OUT OR INK CLEAN IT .it long thin along the the paten glass
hope that help
Nov 13, 2009 | Kyocera Copystar CS-1820 Black and White...
I have a Minolta CS Pro EP 1031 Printer that makes streak marks
Drum cleaning blade has gone bad. Especially true if the streaks seem to get progressively worse as you run multiple copies. In other words run 10 copies. If the last one out is worse than the first one out it is the drum cleaning blade. Cheap part...around $25
Oct 12, 2009 | Minolta EP1031/1031F CS/PRO Copier
Kyocera cs 2050 copy has faded print down center
make sure the glass is clean it sounds like you either have a dirty scan glass or the wires need to be cleaned there should be a cleaner on the front cover of the macin that you you pull out and slide back abd fourth to clean it
May 05, 2009 | Kyocera CS-2050 Black and White Copier
Copystar cs-2050
Your developer units are leaking.
Nov 24, 2008 | Office Equipment & Supplies
Copystar CS-2050 All-In-One Printer Logo
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
Oloyede Monsuru
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
